Question about Mercedes E-class Pillar Posts Trim Set
Got error code P0015
P0015 error code
  • 772 Answers
Hi,looked code up for you and found out its your camsharfed sensor.
hoped this was some help,good luck.
Posted on Nov 26, 2013
What does the obd2 code p0015 mean please
This error code indicates that the exhaust overhead cam is out of position. The belt/chain or sensor has a problem.
Hope this helps? OBD II Code P0015
Feb 23, 2017 | Cars & Trucks
Check engine light code p0014 exhaust and p0015 exhaust
P0015: Camshaft Position, Act B - bank 1, timing over
P0014: Camshaft Position, Act B - bank 1, timing over advanced
Check oil level and quality.
Remove n clean exhaust camshaft vanost actuator.
Do not refit to exhaust cam, but swap with inlet actuator.
clear codes...if eml on again see if fault moved to inlet cam. If so replace the actuator.
Jul 25, 2013 | 2007 Mini Cooper
Car dont start p0015 and p 0118 code
Need,year,make,model and year,also is it doing something wrong.
Dec 16, 2012 | Volvo Cars & Trucks
Smog code P0015
it is a cam shaft timing code this can be triggered by late oil changes try and change the oil and reset the light
Aug 18, 2012 | Mercedes-Benz CL-Class Cars & Trucks
Code P0015
P0015="B" Camshaft position--timing over retarded (bank 1)
Feb 04, 2011 | 2001 Volvo S40
P0015? code check engine light 32000 miles?
Faulty code. P0015, Cameshaft sensor bank. There are 2sensors in bank 1 and bank 2 totally 4. you should scan and get more specific result about exactly which sensor is faulty. After you shoudl replace it.
Oct 18, 2010 | 2007 Mercedes-Benz C-Class
Trouble codes p0597 and p0015 what they mean
po597 did not see poo15 is camshaft b position timing over retarded or performance problem bank 1. have pcm check sound like its in limp mode.
May 29, 2009 | 2006 BMW 3 Series
2001 volvo s40 trouble code P0015
This is a common issue particularly with vehicles that have had some neglect to the oil change routine. The VVT solenoid on the top of the valve cover gets clogged with thickened or sludged oil.
Replace the VVT solenoid and gasket with a new unit and clear the codes.
Mar 16, 2009 | 2001 Volvo S40
Mercedes E-class  Pillar Posts Trim Set Logo
255 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
Matthew Spark
Matthew Spark
Timllfixit
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
