SOURCE: how to remove the door trim in a peugeot 206
The safest bet is to have a professional do it for you. However careful we are, we might make some mistakes doing so. Although you can always have the professional take a look at it the first time, then you can do it yourself the next time.
SOURCE: need instructions on how to fit auto adjusting peugeot 206
cant honestly say i have fitted one on this model,but is it full auto or is their an adjuster on the back of the clutch pedal.??? look first.Ford escort one is a bit of a pig but easy when you have the knack same as a golf easy when you know how .Now golf cable comes with two plastic ties that hold auto adjuster together and you dont relaese them till the cable is fitted.Can you describe the set up then i might be able to help some more.American web site so a lot of models not listed here and the lingo take a bit as well ,i mean whos ever heard of pigs tails or fire wires.Well what else can you expect when they are not taught the queens english and dont drink tea, just waste it by throwing it in the sea.
SOURCE: Torque setting for peugeot 206
hallo
If you have normal 1.6 liter 206:
max bolt lenght:176,5mm
20Nm and aditional 240°
1,6 liter 16valve engine
max bolt lenght:122,6mm
20Nm and aditional 260°
Marko
SOURCE: i need my peugeot 206 radio code
Your code should be either 3728 or 1728, depending on whether your radio will accept a 1 or 0 as its first digit.
