Heller panel convector heater ND22-01D not working
How can I clean inside a rinnai convector 417 gas heater
http://rinnai.co.nz/tradesmart/upload/files/productfile/portable_convector_rce417_operation_and_installation.pdf
Beside cleaning the filters with a vacuum, There are no instructions on how to clean the inside of the heater. The back and front panels would need to be removed. Unless you are confident to remove the panels, just blow it out as you ahve done and make sure the filters are clean.
May 03, 2014 | Heating & Cooling
" 1500-w wall convector" from uberhaus compared to "1500-w electronic converter" Stelpro
One of the main differences is the stelpro is 110 volts and the uberhaus is 240.
Dec 02, 2013 | Fahrenheat Electric Convector Baseboard...
How to operate an economy 7 heater
storage is when it stores up heat at night and convector is when you use it in the day , best I can tell you .
Oct 21, 2011 | Heating & Cooling
I want to buy form Costco a Sylvania Convector 2000 watts with built-in thermostat. I already have a wall electronic programmable thermostat.can I install this convector anyway and not plug the built-in...
No, you will only be able to use the heater's Thermostat.The programmable wall thermostat you already have is either an 18 volt or 24 volt thermostat. It won't work with a portable electric heater.
Hope this helped you and thanks for choosing FixYa.
Aug 26, 2011 | Heating & Cooling
I've got a Heller 10-fin standing oil heater, H-2400T. I would love it if someone can show me where to find the online instruction manual for this. Or just explain how to make the timer function work....
G'Day
I have one of these Heller H-2400T heaters. To operate the timer try this: Plug into power and turn on. Set power control to either Low/Med/High. Set temperature control midway between Low & high.Rotate timer dial to the right to align time of day to the reference point. Ensure all of the red tabs are pulled out. Then push in the ones for the period you want the timer to operate. Works for me. Good luck
Jun 13, 2011 | Heating & Cooling
Please i need help with 240v wiring to heater
i have the answer, i just did mine...though u already have your answer since this post was published a while back ago...if not write me back...
Sep 12, 2008 | Fahrenheat Electric Convector Baseboard...
Rinnai Convector 404
Hi pinkinfinite,
The 404 is a great heater. I am assuming it is a Natural Gas Heater. All it needs is a good blow out with compressed air. They tend to carbon up in the pilot light area. You will probably also find it is very dusty inside. Easiest way to clean the carbon out is to remove the hose at the heater and with compressed air blow through the fitting where you have removed the hose. Make sure you hold down the start button so the air can get through to the pilot light and jets. Don't connect the electricity for the fan when you do this.
To clean it out internally you only need to remove the front panelling. There are two screws holding the top panel (not to be confused with the side and top). The screws are located inside the bottom grill at the front. There are also screws for the bottom grill there which you will also need to remove and probably best to remove the bottom panel that house the front feet. It should expose all the inside workings of the heater except for the pilot light and jets etc. You should be able to see the fan - it is round and looks like a filter and sits behind the vent section. Make sure you give it a good blow out - it gets all dirt and dust around it. When you do it remove both the rear filters/covers. They are mesh. Blow the top one which is the larger metal one and make sure you blow inside where it fits over to remove the dust and dirt. Same with the other one which should be plastic with mesh. Once you do this put it all back together. Make sure all wires are connected and be wary with the compressed air as it may blow the connectors off from loose fitting parts. Once you get it all back together Test it and hopefully it should work. Hope this helps. I did one the same today that was having trouble starting and it now works like a new one.
Regards
Bryan
May 06, 2008 | Heating & Cooling
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
