Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Chain saw died in the middle of a cut
My chain saw had been acting up by not idling, so i turned the idle up and used it for a few hours. Then it completely stopped running right in the middle of a big cut. And it wil NOT start or fire. I have changed the spark plug, cleaned the carburator and still nothing. Any suggestions?
  • Poulan Master
  • 2,239 Answers
Is it still mechanically sound? whip the muffler off and take a look at the piston skirt through the open exhaust port, any sign of scuffing or damage and it will have to come apart.
Posted on Jan 11, 2013
  • 7 Answers
SOURCE: my poulin chain saw wont run
Can you get it to run at all? if not pull it a few times and check if the plug is wet. Let me know
Posted on Feb 25, 2009
  • 97 Answers
SOURCE: Poulan 2450 Woodmaster Chain saw(2.3 cu. in, 18 in)won't start
It may need the carb rebuilt. The diapharm may have gotten stiff and inflexable.
Posted on Mar 15, 2009
  • 205 Answers
SOURCE: Stihl chain saw won't achieve max rpm
Crank seals are leaking, causes lean or low vacuum for the carb to work properly
Posted on Mar 26, 2009
  • 143 Answers
SOURCE: Dies when pressing the accelerator
If your chain brake is not engaged, which i am sure you have checked, look at the air breather filter or the exhaust muffler which could be blocked with carbon.
Posted on Jun 09, 2009
  • 736 Answers
SOURCE: Chain saw will idle, but not run at full throtle
your high speed jet is clogged ... both the low speed jet and the high speed jet are adjustable on the 2375 .. you might try to unclog the jet by removing the high speed adjustment screw (needle) ... first check to see where its set .. turn it in CW until it stops while counting the turns and fraction of turns as you do .. so you can set it close when you replace it ... sometimes just screwing the adjustment in then back out again cleans the jet .. or you can try a little carb cleaner in the hole after removing the adjustment ... sometimes you have to remove the carb and carefully clean the tiny passageways .. its easy for something to get stuck in those .. you can clean it yourself or have it cleaned or buy a new carb (abt $24) ... listed below is one source for carb parts .. make sure the gas cap is venting properly .. if its stuck and wont let air in . then the motor will run for a while then it will have your simptoms as vacuum builds in the tank .. the high speed jet has a very small hole that is easily clogged ..
http://www.superxpower.com/pages/parts/viewbybrand/11/Poulan.aspx
Posted on Nov 05, 2009
Adjust idle up on poulan pro 42 cc chain saw
Adjust the low side out another quarter turn first before messing with the idle screw.
Sep 15, 2014 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
What are the air and gas settings for a poulan micro XXV chain saw
adjust the L screw in fully till right in,then out 1.5 turns,same with H screw.Then start saw,adjust L screw in or out slowly till you get max revs.You may need to lower idle via idle screw if revs too high.When screw cant acheive better revs,reset idle.Then,rev saw to max revs,adjusting H screw to get max revs,then when max revs acheived,turn screw anti clockwise 1/4 turn out.That gives it enough petrol to cool the tip of the plug
Aug 12, 2014 | Garden
My saw runs good at idle and mid rang but when I stick it into a large limb and try to cut it bogs down and will die if I don't let go of the throttle. It acts as if it is starving for fuel. I tried to...
I have had to change a few fuel tank breathers on the 455 and 460 saws, when it starts to die try to slacken off the fuel filler cap, if it picks up again it is a brather issue, the breather is under the starter cover at the top right hand corner.
Sep 25, 2011 | Husqvarna 20" 60cc Rancher Chain Saw 460
Installed new carb-saw will idle fine,but will not rev.Idle scew has no effect on r.p.m.As soon as you hit the throttle,saw dies.Almost act's like the chain brake is on but it is dissengaged.Both...
There are a few things to check, if the muffler has a spark arrester gauze in the out let this may well be blocked, remove the muffler and the gauze, does the engine now rev? if yes either the park arrester is blocked or the muffler itself is blocked, if this does not cure it, check the flow of fuel from the tank to the new carb, replace the filter in the fuel tank and try again, if this does not help try running the saw with the air filter removed, if it revs normally the filter is blocked.
Aug 28, 2011 | Poulan Pro PP4620AVX 46cc Gas Chainsaw...
Husqvana 65 chain saw will rev fully when idle but dies when introduced to timber
Sounds like the saw is running lean. Check the fuel filter, air cleaner and muffler for plugging. Check the condition of the fuel lines and that the fasteners on the carburetor are tight. If all ok, turn the 'L' and 'H' jet needles on the carburetor CW to stops (lightly), then back out each 1-1/2 turns CCW. This is a basic setting and the engine should start and run. Allow the engine to warm up, pull the throttle full on, and adjust H CW until the engine starts to speed up, but continues to 4-stroke. Proper adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. This produces the most power and least heat. Allow to idle and adjust L CW until the engine runs fairly well, yet will allow it to 'follow the throttle'. Set the idle speed screw til the chain stops moving, but keeps the engine running. Hope this helps!
May 12, 2010 | Garden
The saw starts and runs on fast idle but dies when you use the throttle? it,s a troybilt 18in saw
It sounds like it is flooding when you use the throttle, both are connected. Turn the idle back all the way until it dies, then try turning it a 1/4 turn the other direction.
Feb 19, 2010 | Poulan Pro Chain Saw 46cc 20"
I have stihl chain saw it runes full throttle
After you let off of the throttle it dies instantly or just kind of quits slowly ?
It could be :
- 1 ) Your clutch is hanging up and not allowing the engine to idle while the chain is not moving.
- 2 ) You need to set the idle higher. You will need to remove the air cleaner, and find the small idle adjustment screw, and turn the screw clockwise, until it idles.
Please let me know.
Feb 08, 2010 | Poulan Pro Chain Saw 46cc 20"
After running for about a half hour or so it begins to stall in between cuts . . should i adjust the low,high or idle screw
Is the chain being properly oiled? You should get a thin line of oil after running the tip of the saw near to a piece of paper or cardboard for moment or two. Is the saw getting overly hot after running? Clean the cylinder and air passages with compressed air if it is. Check the muffler for any plugging of spark arrestor screen. Turn both jet screws CW to stops (lightly) then turn both out 1-1/2 turns CCW for a basic setting. Pull throttle full on (after warm up) and adjust H for high engine speed, but 4-stroking that smooths out immediately when cutting. Release throttle and adjust L for fairly smooth idle, but rich enough to allow the engine to 'follow-the-throttle'. Adjust idle speed so that the chain stops moving. Hope this helps.
Oct 08, 2009 | Husqvarna Chain Saw 20" Bar
Poulan Wild Thing starts great but as soon as I try to cut it die
The carb low idle needs to be adjusted this is fairly common among the Poulan chain saws. Once you adjust the low idle from factory setting it will work
Feb 16, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Idle is off??
hi leobowdy
disassembly the carb and carefully clean it.Check the air filter,the fuel line and fuel filter,check the needle,lever,small spring and the screen filter from the carb.Check the sparkplug.
high speed H=2 turns,low speed L=2 1/2 turns,adjust T
When chain saw starts adjust H,L and T accordingly.
cheers savumihai71.
Nov 22, 2008 | Ryobi Factory Reconditioned 18" 40cc...
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
288 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
