Question about Lifesource Ua 767 Blood Pressure Monitor Medium Cuff
My life source monitor gave me a error message of A03 what does that mean?
My monitor pressure life source UA 767 show in display error cuf , what mean thats error
The Err CUF probably means that the blood pressure cuff isn't properly arranged on the arm. Check that the cuff is around the upper arm 1-2 cm above the elbow. The hose should be near the center of the elbow. Make sure that a rolled up shirt sleeve is not too tight. Next check that the indicator arrow is in the correct range when the cuff is firmly fastened.
Make sure that you are using the correct cuff for the user. There are different blood pressure cuffs (medium, large, wide-range) available for some blood pressure monitors. If the arrow doesn't line up in the indexed range, use a different blood pressure cuff for the unit.
I hope this helps. I used the information about the A&D Medical UA-767 for some of the trouble-shooting details. See https://medical.andonline.com/product/premium-blood-pressure-monitor/ua-767f and click on the Downloads tab to see the manual for this model. (I suspect the Life Source and A&D Medical products are extremely similar.)
Nov 21, 2017 | Health & Beauty
Printer screen had update message. After I pushed the OK button, it gave error code Oxba10AACC
Hi Wendy!
Sorry to tell you but OX___... messages means "failed printhead or ink system"
You should try to change the printhead because an error occured and the printhead it's no longer working
Hope you found it useful, for every futher question i'm here
Source: HP Troubleshooting
Dec 04, 2015 | HP Office Equipment & Supplies
Error 3 is showing on my monitor ... What does it mean ?
On other blood pressure monitors from Life Source, the error 3 means that the blood pressure cuff isn't inflating properly. The cuff could be incorrectly fastened or the air connector is backwards or not connected to the cuff or the monitor. Check this on your monitor.
I hope this helps.
Jul 08, 2014 | Health & Beauty
Get directions on life source 767 monitor
Would suggest you try looking in the manual section of www.retrevo.com
Feb 25, 2011 | Life Science Life Source Blood Pressure...
Life source 767 monitor does not work
The cuff sensor must be placed directly over the vain in order for it to pickup the beat. This takes a little practice
Feb 04, 2009 | Life Science Life Source Blood Pressure...
Lexmark c510 error message ;83 photodeve cart missing
See User Reference
http://www.lexmark.com/publications/pdfs/c510/eng/userref.pdf
Understanding printer messages
pages 184 and 185
"Message:
83 Photodev Cart Exhausted
What this message means:
The photodeveloper cartridge is completely used.
What you can do:
Replace the photodeveloper cartridge.
See also: Replacing the photodeveloper cartridge [page 73]
Continuing below
Message:
83 Photodev Cart Life Warning
The photodeveloper cartridge is nearing the end of its life.
What you can do:
• Press Go to clear the message and continue printing.
• Replace the photodeveloper cartridge.
Continuing below
Message:
83 Photodev Cart Missing
The photodeveloper cartridge is either missing or incorrectly
installed.
What you can do:
Correctly install the photodeveloper cartridge to clear the message and continue printing.
See also: Replacing the photodeveloper cartridge [page 73] "
Nov 26, 2008 | Lexmark C510 Laser Printer
LG Flatron L1750H
Hi there, my name is Alex and I am here to help solve your problem.
When adding a new monitor to your computer, it is not necessary to install the monitors drivers as it should detect 'Plug and Play monitor' and will install the monitors drivers automatically. Are you getting any error messages?
If you have any questions or needing further assistance, then please contact me.
Oct 10, 2008 | LG Flatron L1750H (Silver) 17" LCD Monitor
Printer
Duh, what does the error message say? Use the status monitor to get more info about the message. Chances are it will say "parts inside the printer have reached the end of their life..."
This means the waste ink counter has hit it's limit and needs to be reset after cleaning the pads.
This rescue kit will fix you up.
Oct 29, 2007 | Epson Stylus CX3200 All-In-One InkJet...
Lifesource Ua 767 Blood Pressure Monitor Medium Cuff Logo
61 people viewed this question
Top Lifesource Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Lifesource Health and Beauty Expert? Answer questions, earn points and help others
