Question about Jacuzzi Bath Perfecta EZ33 959 White round high-performance toilet
Why is it taking so much long to tank to fill?
Worked fine when it was first installed but now it takes take 3-5 minutes to fill tank. Has good water pressure from fill hose. Takes 45 seconds to a minute to fill when fill hose is taken out of over-flow and put directly into tank. Seems like too much water is going to the bowl and down the drain while filling. What's going on?
  • 979 Answers
Disassemble the valve assembly. It probably has mineral deposits in it. If this doesn't do it, replace the whole assembly. Costs 8-10 dollars
Posted on Jan 30, 2013
5 Suggested Answers
  • 19 Answers
SOURCE: After flushing, the tank takes ten minutes to fill
Sounds like flush valve needs to be replaced , more then likely just ful lof lime deposits and it makes it slow to fill
Posted on Mar 02, 2010
  • 12 Answers
SOURCE: When I flush the toilet,
Attached to the Flushvalve is a rubber stopper commonly called a flapper. If the flapper is worn this would cause the problem. Also sometimes the chain that attaches the flapper to the handle gets caught and the flapper sdoes not seat right. Check this, if it is clear and not obstructed try repalcing the flapper.
Posted on Feb 02, 2011
SOURCE: jacuzzi toilets installed one year
sounds like you may have debris in your lines. I was not aware of this until recently but, you should drain your water heater once a year to get rid of sediments that linger and travel through your lines causing possible blockage problems. Try turning your water valve off. Flush toilet so there is no water in the toilet or tank. Unscrew your line to shut off valve to make sure there's no debris. Good Luck!
Posted on May 18, 2011
  • 129 Answers
SOURCE: I have a Jacuzzi Perfecta
keep going...i mean disconnect the supply line from the fill valve, hold the line into a bowl/bucket and slowly turn the water on. is there pressure? sorry for delayed response if you text me back i will try to answer expeditiously:)
Posted on Jul 27, 2011
What would be a solution to correct the problem?
Hi
I'm assuming you are talking about a washing machine.
You posted this under Cars & Trucks?
I suspect there is an inline filter (coarse plastic mesh) in the standard fill line. It's probable blocked itself with the accumulated calcium in the water.
You could use CLR (Calcium Lime & Rust) solution to dissolve the calcium.
Or
Disconnect the hose and push a small snake device (curtain spring) through the hose until you find where the filter or obstruction is.
Good Luck
Calcium Lime and Rust Remover
Feb 23, 2016 | Cars & Trucks
Tip
The secret how to keep your espresso machine for years
Its like anything in life you got to take care of it cleaning it and the most important decalfication hard water residue kill espresso machine its a big invesrment some cost over 2000 dollard even the less expensive machine can last you a long time use producT to remove hard water residue fill your water tank add the decalsifier start the machine if you got a steam wan open the valve let the water out for 20 second turn the machine off for 15 minute let the decalsifier work and repeat the step 1 untill your water empty after fill the water tank and rinse evething very good dont forget decalsifier is acid so rince the water tank very good the harder your water level is the more often you need to do it 1 decal every 150 liter of water or every 2 to 3 mouth do that and its gonna last you 10 time longer
on Mar 27, 2015 | Coffee Makers & Espresso Machines
Toilet tank fills slowly
My sister has a two year old Jacuzzi toilet that worked fine until a few months ago. Then it started to take 10 minutes to shut off after each flush. I lifted the tank cover and immediately saw the problem; at least 90% of the refill water was going into the refill pipe instead of the tank. Upon examination I discovered that the plastic part that holds the flexible refill tube to the vertical refill pipe was broken. This part not only holds the refill tube in place, it also has a small orifice at the end to restrict the flow into the pipe. The part was broken in such a way as to let nearly all the water go into the refill pipe instead of the tank, hence it would run for 10 minutes after the toilet bowl was full and waste all that water. I found a small coarse thread stainless steel screw that fit into the plastic attachment piece to help plug the orifice and cut down the amount of water going to the refill pipe. Now the toilet flushes and refills in less than 2 minutes. I'm in the process of trying to find a replacement for that part but so far no luck.
Mar 29, 2012 | Jacuzzi BK37959 White Era?? Two-Piece...
I have a Jacuzzi Perfecta commode. It has worked fine until all of a sudden, the tank began filling very slowly. It now takes from 5 to 7 minutes for the tank to fill. I've replaced the flush valve,...
Jul 26, 2011 | Jacuzzi Bath Perfecta EZ33 959 White round...
Coffee just drips out of machine, have left off over nite, worked fine now just drips & we get only about a 1/4 cup. Have not desaged as is only about 6 months old?? Bob Spackman
wer
Sorry to read about your issue.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Dec 25, 2010 | Keurig Platinum B70 Coffee Maker
Just installed aqua/cleer reverse osmosis system and the water doesn't seem to be going into the holding tank, however there is water that is coming out from the tap.
Make sure all the lines are hooked up correctly. It is going to take 3-8 hours to fill a 3 gallon RO storage tank. It depends on the capacity of the membrane (IE: 14, 20, 30, 50 or 75 gpd). It also depends on the TDS of the water. Water that has high TDS 500+ppm will take longer to produce product water than TDS of 100ppm. Check the pressure in the RO tank. When empty (In a 3 gallon tank) there should be 7psi pressure. A ten gallon tank takes 10psi. If it needs air you can use a bicycle pump to add appropriate air. Make sure the tank valve is turned off when adding air.
Do not use the RO faucet for several hours to allow tank to fill up. Also you should dump the first couple tanks of RO water to make sure any carbon fines are rinsed out.
RJ
Nov 07, 2010 | Culligan Under Sink Water Filter
The tank will not fill up, air pressure is good in tank
There are several things to look for here.
1. Turn the feed valve off. Take the product line off the RO tank (shut the tank valve off first), turn
the feed valve back on and see if water is coming out the product line to RO tank
2. Make sure the feed valve is supplying water. If it's a piercing valve they can get plugged with debris.
3. Make sure there is water going to the drain
4. If the filters were just replaced, remove them, inspect them thoroughly and re-install
5. In an empty 3 gallon RO tank there should be 7 psi pressure. If there is too much pressure it will
prevent the tank from filling up.
6. Make sure there are no kinks in any of the RO lines.
RJ
Sep 20, 2010 | Culligan Under Sink Water Filter
Got an old saeco magic comfort 7/8 years old -
bye a good coffee descaler not vinager follow instruction on it normally fill the water tank leave room for the descaler start the machine open side valve leave it running for 15 second turn it off let it site for 10 to 15 minute after open valve for 30 second let it site for 10 minute and open valve repeat untill empty tank after clean water tank very good that descaler is acid nasty stuff after fill the water tank full of water start machine open side valve empty water tank that its good luck pierre p.s it take a while do descale good but worth it
Jan 02, 2009 | Saeco Magic Comfort Plus Espresso Machine
"Fill water tank" prompt
this has happened to me too just yesterday (26 May 2013), I replaced the tank because I was lucky to have kept the spare bits off the old machine I had and it worked fine. Over time, the water gets into the float and corrodes the magnet. Best to just replace the magnet if you can or the whole tank. Good luck
Oct 26, 2008 | Saeco Royal Digital Plus Coffee...
Cuisinart Coffe Maker has no power
vinegar is not the best thing descaler vinegar remove calciumin little piece that might block thr rest of machine descaler produit melt calcium 1 part solution 1 part water fill the water tank start machine leave it running for few second turn off for 15 minute and repeat untill empty dont forget to rince the machine very good that stuff is very corosif but does the jobs thanks for using fixya pierre
Feb 09, 2008 | Cuisinart DCC-1200 Coffee Maker
Jacuzzi Bath Perfecta EZ33 959 White round high-performance toilet Logo
165 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
Donni Steen
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
