Question about True 72 cu. ft. / 2039 liter Commercial Freezer T-72F
Where is the thermostat 0n theTRUE 72 freezer
Where is the thermostat located on this freezer . it gets too cold and runs too long
    New Friend:
  • 39 Answers
Right side of the evap. coil housing inside.
Posted on Apr 18, 2013
True freezer
Things to check are:
Is the thermostat set to the correct temperature (Low, Med, High)?
Are the door seals in good repair and making a good seal with the freezer cabinet frame?
Is the door warped or distorted in any way, will lead to leaks.
Can you hear the compressor/motor running?
Dec 28, 2013 | True Refrigeration True T-49 2 Door Bottom...
Where is the thermostat on this unit it gets too cold and runs too long
what is your model number is then we can get started then
Jan 11, 2013 | True Freezers
Freezer sounds like it's running, but doesnt get cold
Hi,check that the thermostat is set correctly,if so the it could be the compressor has gone down.
Nov 13, 2012 | Haier Freezers
True gdm 72 goes below 20 degrees
Usually a blocked condenser fooling the thermostat into running overtime. Possibly thermostat fault but less likely
Apr 14, 2012 | True 72 cu. ft. / 2039 liter Commercial...
Replaced thermostat ,dial at 0 still wont get above 33
Verify that the sensing bulb on the thermostat is inserted INTO the evaporator coil.
Jul 25, 2011 | True 72 cu. ft. / 2039 liter Commercial...
The compressor is running but the fans are not spinning so no cold is coming out.
Coil must be cold enough for the fan delay to turn fans on. If it is and no fans replace delay
Mar 08, 2011 | True 72 cu. ft. / 2039 liter Commercial...
My freezer is having uneven temps throughout. Some areas freeze the items solid and some not at all. the fans are running and all areas are at a temp below freezing....I am in a panic . This freezer is a...
I would check all seals and make sure there are no air leaks. From what you describe there may be several areas that allow warm air to enter and cold air to escape. If the humidity goes up in your location and the door is open a lot it can cause havoc with consistency.
Sep 21, 2010 | True 72 cu. ft. / 2039 liter Commercial...
Fans not running, everthing else runs. True model T-72F reach in
In most cases, there is a device located in or on the evap that senses the temp of the evap. This can be a defrost terminator/fan delay. Sometimes they are separate devices and sometimes they are a 2 in 1 device. If the evap does not get cold enough, the fans will not come on. Usually about +20 degree F. It is to prevent circulating warm air after a defrost and to keep from overloading the compressor after a defrost as heat is generated by electric elements. I would look to see if the defrost terminator / fan delay has malfunctioned, then I would check the refrigeration system performance.
Apr 23, 2010 | True 72 cu. ft. / 2039 liter Commercial...
True 72 cu. ft. / 2039 liter Commercial Freezer T-72F Logo
74 people viewed this question
Top True Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a True Freezer Expert? Answer questions, earn points and help others
