What is causing these lines? - Televison & Video
    Problem Solver:
  • 6 Answers
Could be several things. First I would make sure all my connections are good,both on the tv and from the source of your signal.
Posted on Jan 11, 2013
3.3v6 fuel line has crusty deposits where it clamps to the plenum and also seems to be oozing from where it clamps to the metal line below the plenum.
If you are using fuel that is an ethanol blend, it may have caused the fuel line to degrade or it has absorbed water and is causing this.
Sep 16, 2016 | 2001 Nissan Xterra
Tip
How to Check main causes of Hissing Noise on phone line ?
The main causes of Hissing Noise on phone line
* Weather:
Precipitation can leak into phone lines and cause disruptions. Lightning, even at a distance, can damage the connection.
Checked the connections the cable and the Sockets
If you have the Test socket or the First Socket where the Telephone is is entering .. check the Connections there
* Electrical interference:
Check the Power lines,
Check radio or television transmitters, transformers and other electronic devices may causing noise on the phone line.
* Other phone devices:
Check for the Connection to the FAX check by unpluging the FAX Machine or answering machines,
Disconnect the other phones and line splitters --
Disconnect the Splitters or devices that allow two phones to fit on one phone jack -- can cause phone line noise.
* DSL services:
The high-frequency signals coming from DSL (digital subscriber line) devices sharing the phone line can create problems for other technology connected to the line.
***Note : high-frequency signals coming from DSL helps for FAST Internet Connection speed which sometime cause the problem to the Phone or Voice signals for this need to contact to ISP to check the Voice margin .. that may effect your internet Speed
IF the above wont work..
You can try keeping the device near Heater .. it could be the Moisture which might causing this issue
or
Show the Device to the Service provider to repair it
on Jan 22, 2010 | Cell Phones
Suction line size on midea minisplit heat pump is 1/2" suppose to be 3/8" what problems will that cause?
An undersize suction line decreases the capacity, and causes the compressor to work harder and more frequent starts. It may even experience low suction pressure and high superheat.
Dec 16, 2013 | Midea 18,000 Btu 17 SEER Inverter Mini...
Will air in propane lines on a forklift cause it to miss and run poorly
Air in any gas line water line oil line will cause it to run poorly Yes bleed it if you know how
Jul 28, 2012 | Cars & Trucks
We have 2 inch lines and a pump made for 1 and 1/2 inch lines. Would that cause air in the lines?
Pumps often need to be bled of air to function correctly. A larger diameter pipe may cause a reduced flow be should not create air in the lines unless air is getting in somewhere. Possibly in the connection or a hole in the lines.
May 13, 2012 | Cars & Trucks
Initially getting a few horizontal dark lines on copied page, now beginning to get longitudinal lines as well. Not sure where to start..
Lines that are thin are usually caused by white out or ink or just dust on the exposure thin **** glass, clean it with alcohol or windex. Other lines could be caused by dirty charge units, there should be a rod you can slide out and in when you open the front door to clean that. If the hot fuser rollers are damaged that also can cause dark lines
Mar 23, 2010 | Sharp AL 1631 Copier
Constant static and noise on the cordless, have not had this problem with other phones in the same location. I have tried the frequency scan- no difference. The noise is so bad the cordless cannot be used.
* Weather:
* DSL services:
or
Jan 22, 2010 | GE Telephone pr521w
When water enters fridge for ice maker, it makes banging sounds. I have replaced valve several times, but still gets banging sound after a short time of use
The banging sound more than likely is being caused by your water line that is attached to the rear of your unit banging agains the chassis or wall. It can also be the line inside the bottomg of you unit striking something. This banging most likely is caused by what is called a watter hammer. When the ice maker cycles and the water valve opens momentariily the pressure in the line drops and when the vavle closes post add water cycle the pressure rapidly builds up in the line causing the line to move and strike something. Over time this can cause a water leak from the water line chafffing and the line begins to leak. It is not a serious situation but I would keep an eye on the copper or plastic water line to see what it is doing during the add water / fill cycle of the ice maker.
Jan 04, 2010 | Refrigerators
The screen gets lines in it and then goes black, now it is just all black
sounds like a start up reley
or it could be a flyback
call the tech
Jul 30, 2009 | Televison & Video
2001 dodge caravan power stearing lines
Does that one have the resevoir on the engine of the firewall? If on the engine, I would replace the resevoir/filter (it's in the resevoir) Those lines are just return lines, and thus should not have much pressure on them. You may also have a faulty rack and pinion, or P/S pump.
If on the firewall/fender, see above.
Mar 18, 2009 | 2001 Dodge Caravan
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
