Question about Honda Tiller - F220
Honda f220 tiller clutch always engaged
Honda f220 tiller clutch is always engaged
4 Suggested Answers
SOURCE: Honda FG100 Tiller - Tines wont move
I took the transmission apart and the gears were fine. The friction pads on the centrifugal clutch don't seem to make full contact with the drum. Does anyone know what the thickness of the friction pads are suppose to be? I used some belt dressing on the pads and got some movement on the tines. With no wear on the gears, I guess I'll be replacing the clutch.
Posted on May 24, 2009
wentlanv
  • 710 Answers
SOURCE: Honda FR600 runs when in
Hi Jack,
You should findone or two locknuts somewhere along the clutch cable, either by the engine or by the lever. Put the lever in neutral and loosen the locknuts and turn the adjust a turn or two until you can run the tiller in neutral and not have it creep. Retighten locknuts.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Posted on May 17, 2011
  • 430 Answers
SOURCE: The tines on a honda f220 always spin and don't change speed when clutch is engaged but speed up when throttle is increased. Adjusted cable with no luck.
I believe that unit utilizes a centrifical clutch. try decreasing the idle speed and see if the tines stop. They should then engage as throttle is increased.
Posted on Oct 01, 2012
HONDA HARMONY MINI TILLER STARTS BUT TINES DO NOT ENGAGE
either the clutch is shot or the cable is broken to the head
May 25, 2017 | Honda Garden
Honda FG garden tiller 110, stoped running, took it apart, the timing belt loose, what do I need to fix it? Or is it worth fixing?
I'm not aware of them having a timing belt. Do you mean the drive belt? if so, it is supposed to be loose. in the disengaged position. and tight in the engaged position. and to answer your question it is almost always worth fixing. unless you have a lot of money and want a new one. I've seen tillers 30 and 40 years old work just as good as a new one.
Jun 22, 2016 | Honda Garden
New tiller makes grinding noise when trying to run tillers
if it has a clutch
most small units just run a dog that you engage with a swift motion at low idle speed of the motor
have the tillers free above the dirt so they can turn with out any load to inhibit the dog engagement
May 20, 2015 | Garden
I have a f22o honda rotor tiller.it runs great but when i put the unit in dirt it won't spin.it will if it's not touching anything.
You probably have a belt drive that has is not tight enough to pull under a load. The belt is pulled by an idler pulley that engages when you start the tines. Check the belts by working you engage lever and look for the belt and idler. More than likely there is an adjustment that will allow you to put more tension on the belt thus making it till. Do not do this when the machine is running! The belt should not have flex in it when engaged. It may a little effort to engage the tines when you get it tight enough to till.
Col. Dana Gillespie
May 04, 2015 | Honda Tiller - F220
How to check and replace Honda tillerF220 fuel filter?
Of course you will probably have to remove something to get to it but once you get to it there should be a clamp on either side of it that can be removed with a pair of pliers. Just squeeze the clamps and scoot them back off the filter stem, You may have to work them back and forth to get them to release, then all you have to do is pull the old filter out and insert the new one, You will probably have to hold the filter and work the gas line back and forth to get it to release from the filter like you did the clamps, Oh yea, before I forget ( as I usually do) put the clamps back on,
Col. Dana Gillespie
Oct 13, 2014 | Honda Tiller - F220
F220 tiller does not stay running
-Idle is too low or fuel line is clogged.
Good luck
Mai
Jun 19, 2014 | Honda Garden
Sep 24, 2012 | Honda 25cc 4-cycle Mini Tiller
Grinding when Engaing PTO for the tiller-Troy Built Horse 8hp
It's likely that your clutch needs adjustment. To adjust, you just need to loosen the two screws on the plate and slide it a bit so the clutch better engages the rear dog clutch. Have you ever taken the tiller portion off the transmission to grease the clutch? If not, before adjusting it you might want to do that. It could be that the clutch isn't sliding back far enough to engage the rear end and a little grease is all it needs. This service requirement is explained in the owners manual for the tiller. One last point, the tiller must be in neutral when engaging the pto clutch. From your note, it sounded like you were engaging the clutch with the forward/reverse lever in the forward position. The lever must be in neutral when engaging the pto clutch.
Jun 14, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Honda Tiller - F220 Logo
60 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
