Question about Bosch HGS232UC Gas Kitchen Range
Bosch gas range HGS235uc oven does not ignite. replaced igniter and still does not ignite. says preheat but doesn't call for gas
Oven click to when turned to bake , broil ect but never heats up . changed the igniter bar and when plugged back in, the panel say Gas 168 and then clock set comes up. still doesn't heat.
4 Suggested Answers
bestdarngood
  • 3037 Answers
SOURCE: Oven does not heat but broiler does
The most common cause of this symptom is a defective ignitor. Oven ignitors can glow and allow enough current through to open the oven gas valve but just not produce enough heat to ignite the gas immediately (see the link below).
In that case, replacing the oven ignitor is the usual solution.
http://www.appliance411.com/links/jump.cgi?ID=823
Posted on Mar 22, 2008
  • 6 Answers
SOURCE: OVER WONT HEAT UP
make sure the hose is connected to the propane tank and that the tank valve is opened letting gas into the grill exhausts... and then light the igniter but make sure the release valves on the grill arent on max... start it on low to med.
Posted on May 27, 2009
  • 457 Answers
SOURCE: bosch hgs232uc gas range oven not working.
unit has to be configurated when you replace board or it wont work. nyc appliance repair can repair it for you.
Posted on Feb 26, 2010
Gas oven is slow to ignite & preheat
What kind of range? Taking that long to ignite and small flame. Sounds like both weak ignitor and safety valve is not opening.
Jan 14, 2013 | Kitchen Ranges
First thing to suspect would be a weak igniter....see if the amp draw while the igniter is glowing matches the amp rating of the gas valve, the value will be on the side of the valve, if the amp draw of the igniter is lower than the rating of the valve you would need to replace the glow coil/igniter.
Mar 22, 2008 | Bosch HGS 255 Gas Kitchen Range
My maytag mgr5729adw gas range oven omits a strong gas smell when attempting to preheat. Sometimes it heats sometimes it doesn't but use to get a small boom when igniting. Ignitor still glows oran
see the next steps and proceed with common sense: God bless you
Main Control / Oven Switch
The main control or oven switch may have failed. You will need to identify the wires from the switch/control that lead to the igniter that is clicking. These wires may pass through the spark module and change colors. Refer to the wiring diagram or tech sheet. If you have power leaving the switch/ control when in the off position replace the switch /control. Manual switches can be tested with an ohmeter.
Spark Module / Igniter Module
If your oven igniter keeps clicking the igniter module or spark module is the likely problem. First be sure the igniter is clean and the surrounding contact points are clean. Make sure power is off when cleaning. If the oven keeps clicking after it's cleaned and the oven switch / control checks good replace the spark module.
Jul 26, 2012 | Kitchen Ranges
How Do I manually light my oven.?
most likely you have a bad ignitor,you can't lite it like older ovens it has an electronic ignition.when the ignitor draws a certain amount of amps.the gas is let in and the flame ignites,if it glows it still can be bad,once it glows it should ignite the flame within 40 seconds.part number 492431 and it's around 70 dollars. go here http://www.searspartsdirect.com/partsdirect/part-model/Bosch-Parts/Range-Parts/Model-HGS435UC01/1794/0124002?searchedModel=HGS435UC&blt=11 go to oven cabinet parts and look at part 309,this is your ignitor.
Dec 20, 2011 | Bosch HGS435UC Gas Kitchen Range
I have a hotpoint gas oven the will preheat , but not maintain temperature
That pretty much sounds like a weak igniter thats causing your troubles, while the igniter first comes on to preheat the oven its seems to be ok,yet once it has been on for a while the igniter is getting weak and not allowing the gas to flow properly once its hot. By replacing the igniter the oven will maintain tempature.
GENE
Sep 28, 2011 | Kitchen Ranges
It take a long time for the oven to preheat and some time you can smell gas during the preheating
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 08, 2011 | Amana RanARG7302 Gas Kitchen Range
Oven flame ignites but will then not increase to the larger size
when oven is switched on the flame ignites,butthe flame refuses to go tothe next stage to preheat the ovento the required setting
Nov 10, 2008 | Rangemaster 110 (Gas) Kitchen Range
Bosch HGS442UC Gas Oven won't light
Usually when an oven won't bake, it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself.
The burner is the tube-type device the gas flows through before it's ignited. It has many small holes on the sides to let the gas, when ignited, form a long, low flame. If the igniter is weak, if it glows red but doesn't get hot enough, or if it's burned out, the gas doesn't flow to the burner and the burner won't ignite. If this is the problem, you may need to replace either the igniter or the gas safety valve. Usually the igniter is to blame.
Other causes Other reasons that your oven may not bake are:
  • The clock settings are incorrect (if you have timed baking or a self-cleaning oven).
  • The thermostat is defective.
  • The safety valve that prevents accidental gas flow is defective.
  • The selector switch is defective.
if this helps please vote me a fix ya
Jul 18, 2008 | Bosch HGS442UC Gas Kitchen Range
Bosch HGS232UC Gas Kitchen Range Logo
79 people viewed this question
Top Bosch Kitchen Ranges Experts
Oloyede Monsuru
Jim Thurston
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
