Question about Avanquest Partition Commander 10 for PC, Linux (1522)
Partition commander 10 professional won't work on win vista
Program comes up with "you need administrator privileges to run this program". And, after that "this program will not work on my os. On the box the program came in it states Windows Vista' Which is what I am Running.
  • kingcom1955 Jan 22, 2009
    My PC is setup for ONLY my use. I am not networking with any other PCs in my home. Again, I am running windows vista on a HP personal computer, notebook and it is brand new.
  • 101 Answers
Is your vista account set up for administration or for limited use, if you are not a administrator on the account of the os then you wont have installation privileges.
Posted on Jan 22, 2009
I have a ASUS X53E. The webcam works fine through Skype, but when I try to simply open the program it wont work. I double click the icon and a window labeled user control asks if the program has permission...
Access the administrator account user to have full privilege on your computer. That includes making changes automatically without interruptions. You may enable built-in administrator account by opening a command prompt in administrator mode by right-clicking and choosing "Run as administrator". Now type the following command: net user administrator /active:yes. After that restart and login to the administrator account profile and access the webcam.
Sep 12, 2012 | ASUS Computers & Internet
I am not able to install the sprintsmartview to my dell studio 17 computer i keep getting an error 1721.
Since this error seems to reference the "Windows Installer" which is separate from the Installshield engine, I would probably try updating that:
The error by Windows Installer Package happens in Windows Vista because the of custom actions set in the installer package fail with missing permissions, involving custom actions that scheduled for both immediate or deferred execution. Visual Studio custom actions run while impersonating the installing user but only run with standard user privilege, and not with elevated administrator privilege as required in Windows Vista, if the msidbCustomActionTypeNoImpersonate bit is not set. Even though Windows Vista prompts for privilege elevation, however, only custom actions that are running in the Local System account get elevated correctly, while custom actions that impersonate as the current user do not.
Thus, the error usually happens on older versions of setup installer which install or uninstall programs meant for earlier versions of Windows operating system, such as XP, 2000, Me and 9x. However, if you're the programmer or developer for the installer program, probably you can do much to change the bit or installer sequence to solve the issue. But, there are still resolutions to fix the error 1721 that happens in Windows Vista, and probably has more than one one solutions or workarounds that users can try to get the software program installed.
Run an elevated command prompt with Run as Administrator option to start the installation
This method will probably allow most failed .msi installer to install/uninstall probably. Simply open an elevated command prompt with Run as Administrator setting, and then execute the .msi executable.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 22, 2010 | Sierra Wireless 598U USB Modem
Hey there; I couldn't install programs on my PC since I have no admin. previlage. How can I do that on my account? my PC is networked and network administred.
You can install programs on your PC ONLY with Administrator privileges!
It could be either by logging in as an administrator (or any other account with administrative privileges; Sometimes even Power User privileges is enough) OR right-clicking on the setup file of the program and choosing "Run as..." and specifying a suitable user account.
Other way will be cracking/resetting the Administrator's password - but I won't get into it... Anyway, it's probably set on a server and not in your local PC.
PS: You can ask your network administrator to grant you privileges as a local administrator (ie, only for your own PC) - if he agreed - that should solve your problem! :)
Mar 10, 2010 | Microsoft Windows XP Professional SP3 Full...
How do i remove windows vista and install windows xp with out losing all my other stuff
If your Vista still work, go to the control panel> administrative tools> computer management > disk management > create an additional partition (larger then my documents folde size)
Move your files to this partition then install xp.
A few tips
  • Make sure there xp drivers for each componenet
  • Use driver magician and find xp drivers (check the pc mfg site and download all xp drivers and put them on this partiton too.
  • Use a partition program (dos) and format the vista partition and the hidden partition that vista creates or xp won't go in properly
Jan 24, 2010 | Microsoft Windows XP Home Edition
Copying to c:\ in vista using batch files..
You need to left click the batch file and "Run as Administrator".
Nov 01, 2009 | Microsoft Windows Vista Ultimate Edition
Error 75 Path/File Access error
You will have to run the program as the Administrator.
Either Right-Click and select "Run as Administrator", or
Right-click, Properties, Compatibility tab, Privilege Level box, check the "Run this program as Administrator" box. (In Windows 7, don't know if the same for Vista or XP.)
Oct 01, 2009 | Sharp XE-A404 PC Desktop
This software cannot be installed using the 'run as ...' command
there's always an administrator (even if it's the one and only user).
what version of windows? (I'm assuming windows).
if Vista you can try to run the installer as administrator (find the install program, right-click, choose run as administrator).
Apr 07, 2009 | HP Officejet J5780 All-In-One InkJet...
I have quickbooks pro 2006 and I purchasaed a new computer with Vista. Where can I get a patch to allow my 2006 XP version to run on vista
By the looks of it, no patch is necessary. The only thing it requires to run is administrator privileges. To do this you can do it one of two ways.
Rightclick the quickbooks pro icon.
Goto Properties
Select the tab labeled "Compatibility"
On the bottom of that tab put a check in box captioned "Run this program as an administrator"
Then press Apply and OK.
Now every time you startup this program it will be with administrator privileges.
Sep 16, 2008 | Computers & Internet
I am trying to install a photosmart all in one C5180 on my pc running Vista. It keeps saying that the program cannot be installed as use by and asking me to log on as the Administrator. I AM the...
This is normal with Vista, Vista log in users as standard (not Administrator privileges) , then ask if to run programs as administrator for security reasons. Once you tell the system to run program as administrator it should install with no problems.
If you really cannot install the program, you can restart computer and login as administrator:
At the "pick a user to login" screen, hit CTRL-ALT-DEL to get the classic login screen. Then you can type in Administrator for the user name, default password is blank.
Read here for more.
Jun 08, 2008 | HP Office Equipment & Supplies
ReBirth and Vista
Did everything above ,kept getting the same ol errors,i right clicked
on the app,opened properties,and changed compatibilities to win xp. then, instead of opening the rebirth from program files,i went and opened a demo song from the rebirth folder, and hey presto the ***** opened,after that the program would open the usual way.
yippeeeeeee........
Jan 21, 2008 | Propellerhead ReBirth (Virtual...
Avanquest Partition Commander 10 for PC, Linux (1522) Logo
93 people viewed this question
Top Avanquest Computers & Internet Experts
Alun Cox
Chris Larocque
Are you an Avanquest Computer and Internet Expert? Answer questions, earn points and help others
