SOURCE: my panasonic inverter microwave gets
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
SOURCE: panasonic microwave 1250w shows H98 on the screen
the only thing you can do is contact the service center 1 800 211 7262
SOURCE: Error Code
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here. If you're not in the US, see Panasonic.net.
SOURCE: ERROR CODE H98 ON MY PANASONIC MICROWAVE OVEN.
In Canada, you can find an authorized Panasonic servicer here.
If you're not in the US or Canada, see Panasonic.net.
SOURCE: microwave will not work...display reads H98
H95, H97, H98 or
It may be a loose connection in the wiring between the
inverter, magnetron, and/or control board, or maybe one of
those
components has failed.
Due to the lethal
We're
This oven is
programmed with a self diagnostics failure code system which will
help for troubleshooting, H97, H98 and H99 are the provided failure
magnetron and inverter circuit problem areas. This section explains
failure codes of H97, H98 and H99. H97, H98 and H99 appears in
display window a short time after start key is pressed and there is
no microwave oscillation.
There is not a lot the layman can do except maybe to try a new magnetron.
It is a job for an experienced Panasonic Microwave repair man.
