Question about Mitsubishi CS-40503 TV
CS- 40503 No Power
I have a Mitsubishi CS-40503. It is completely dead. No video/ audio. Power cord appears fine. Is there an external reset? f not what might be the problem?
I have the same problem and the technician changed the CRT socket double focus and it worked. Try it.
Posted on Sep 26, 2007
  • 398 Answers
There is no external reset, and if the set is completely dead (not even a click when the power button is pressed) then there is probably an open main fuse or defective stand-by power supply. If the main fuse is blown then there is usually a heavy short in the main power supply, and either way the set should be looked at by someone with experience in Mitsubishi sets.
Posted on Jul 06, 2007
Is there a reset switch on my mitsubishi tv & where is it?
if tv power light flashes after it goes off then it due to system check failure and is flashing error code.
Nov 12, 2012 | Mitsubishi CS-40503 TV
CS-40503 takes about 10 minutes for the picture to appear once the set is turned on (sound comes on immediately)....when the picture does appear, it's dim for approx. 5 seconds then comes up to full...
IF THIS SET HAS PIP (PICTURE IN PICTURE) THAN I'D SAY THE PIP MODULE IS GOING BAD. YOU CAN REPLACE IT OR GET THE BYPASS PLUG FOR IT. IT JUST PLUGS IN.
Dec 10, 2009 | Mitsubishi CS-40503 TV
Remove parental lock on a mitsubishi CS-40503
model# cs-40503 default parental code is 6629
Nov 16, 2009 | Mitsubishi CS-40503 TV
Cant get my cable hooked up
check your unit if it is cable tv compatible.then, hook your cable to antenna in.then do the manual tunig/search for channel.if not,you'll need to buy a cable converter ,much better if it has audio/video out.
Mar 29, 2009 | Mitsubishi CS-40503 TV
Mitsubishi CS-40503 Zapped by high voltage
the only option is to bring your x-former as sample or take a pic of it and post it.
Mar 26, 2009 | Mitsubishi CS-40503 TV
Narrow blue horizontal line across screen on intial power up
You have trouble with the vertical deflection circuitry. Probably something in the driver circuit or power supply to the driver. Maybe even a cold solder joint since it comes up after a little warmup.
Jan 17, 2009 | Mitsubishi CS-40503 TV
Mitsubishi CS-40503
Just discovered last night that my set has the same problem, the TV is also about the same age. I can't find the manual but I was wondering if it might be fuse related, just don't know where that might be. I've had blown fuses before in circuits designed to protect the speakers so I thought this might be possible. I'm currently using my DVD/VCR which uses a surround sound system, to view TV with sound so I have to use VCR tuner.
I'm going to try to connect speakers to the audio out on back of the TV to see if it can drive external speakers.
Aug 04, 2008 | Mitsubishi CS-40503 TV
FORGOT PASSCODE ON TV PARENTAL LOCKOUT
that's a big problem. sometimes using the 0000 can unlock it but it's not 100 percent.try the trial and error.
Apr 19, 2008 | Mitsubishi CS-40503 TV
Mitsubishi CS-27405 no picture but sound
your problem is the PIP board,tough to repair,can be taken out and replaced with two 10 mfd caps 50v bipolar from pin5 to 11 and from pin 7 to 9
Sep 27, 2006 | Mitsubishi CS-27405 TV
Televison & Video Logo
331 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
