Question about Keurig B70 Coffee Maker
Why does ground flow from the top of brewer instead of coming through the dispenser?
Instead of coffee dispenseng through the proper outlet; coffee ground and water flow from the top overflowing into the coffee cup below. sometimes quite heavily. The cap on the dispenser cup is securely on. the water is going into the dispenser and bubbling back up through the hole in the top of the dispenser allowing coffee grounds to escape and overflow int your cup.
  • 139 Answers
Buy a new K-cup holder from amazon.com. Its the black cone shaped holder.
Posted on Jan 20, 2013
2 Suggested Answers
SOURCE: water overflows
It sounds like your exit needle is clogged. Take a paperclip, unfold it, and run it through the exit needle to get out the grounds that are clogging it.
Posted on Apr 16, 2010
My Saeco Royal Professional says coffee beans empty although it is full
hi,
there is a small measuring device between the grinder and the brewer, that measures grind coffee flowing into the brewer. the brewer is the removable part on the right side of the machine.
it looks like that the measuring device is clocked or in worse case broken!.
my suggestion:
1.open the door on the right side
2. remove carefully the brewer/brew unit
3. clean it under warm running water
4. clean out the surrounding area, coffee pan etc.
5. check the measuring device for clocked coffee. it is square, has a small flap and easy to access with the door open. take a soft brush and clean the area, there might be a lot of ground coffee!
6. carefully re-insert the brewer acc. to manual, do not force in place.
7. close the door and use the unit.
you might also remove all beans and clean the burrs, the ground coffee outlet and check that it is free and not clocked as well. otherwise no ground-coffee will reach the measuring device!
good luck!
Sep 30, 2014 | Saeco Royal Professional Espresso Machine
Won't pull water up into k cup, instead hot water flows back into the reservoir.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Sep 13, 2011 | Keurig Platinum B70 Coffee Maker
Coffee overflows and grounds sit on top of pod
heatman101
May 18, 2011 | Keurig B60 Coffee Maker
Water flows back into reservour instead of in coffee cup
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Apr 21, 2011 | Keurig Elite B40 Coffee Maker
Trying to de-scale keurig coffee maker and many times water flows into reservoir instead of flowing t Into cup
heatman101
Jan 16, 2011 | Keurig Elite B40 Coffee Maker
New Bunn NHBX takes about an hour to make 10 cups of coffee. Water is dispensed drop by drop instead of a stream. 4 dispensing holes are clean
It sounds like you might have a problem with the water tubing. If you will call Customer Service at 800-352-2866 we will be happy to assist you with this issue.
Sep 21, 2010 | Bunn NHBX-B Contemporary 10-Cup Home...
Saeco magic deluxe - no water flow
How old is your machine?
Do you descale it regulary?
I think it´s your boiler that has to be replaced
Aug 05, 2008 | Saeco Magic De Luxe Espresso Machine
Keurig B70 Coffee Maker Logo
254 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
