Question about Kenmore 23313 Whispertone Bagged Canister Vacuum
Kenmore model 116 56212604
Vacuum works with all attachments except the main one the power nozzel base. We have cleaned the brush and removed all debris but when attached back to hose vacuum still works but no suction is coming from the nozzle base. Does the belt need be replaced?
4 Suggested Answers
SOURCE: Kenmore Progressive Model # 116 25914507
I had the same problem with my vacuum. I called in for technical service and was told to push the "reset button". It turns out that there is a small red button right next to the dirt indicator light. I pushed the button, plugged the vacuum back in and started it up and it worked like a charm! :) Hope this helps!
Posted on Mar 26, 2008
  • 22 Answers
SOURCE: kenmore vacuum model 37105 no suction
are the brushes moving?if so , it is clogged somewhere, that is my guess
Posted on Feb 10, 2009
  • 49 Answers
SOURCE: vacuum shrinks, power is still on but no suction
perhaps there is something stuck in the vacuum. Look where the hose fits in. There is obvioulsy no blockage in the hose because you have suction. Do the power brushes spin on the vacuum?? Take the bag off, and inspect the area the bag fits in for blockage.
Jer
Posted on Jan 16, 2010
Kenmore vacuum cleaner model no. 116. 5861279 belt replace
Do you need the belt or the directions for changing the belt? Sears Parts Direct has the manual for the 116.58612790 here: http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Vacuum-Parts/user-manuals/manual-downloads/Model-11658612790/0582/0640500?modelNumber=11658612790&diagramPageId=&documentId= . The direct link to the manual is http://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/L0802691.pdf . See pages 14-15 of the manual.
To replace the belt, you need to remove the light cover and then the light bulb. Press in the sides of the cover and lift to remove it. the bulb needs to be pushed in and then turned couter-clockwise. Remove the cover screws. Then flip over the Power Mate and use the flat blade screwdriver to release both tabs. Turn the Power Mate back to right side up and press on the handle quick release pedal and lower the swivel. Tilt the cover forward until it snaps free. Carefully, use your screwdriver to pop the brush supports free on both sides to remove the brush. Slide off the old belt. (If needed, slide off the brush supports and washers. Clean the brush before reassembling the unit. Then replace the brush supports and washers.) Push the belt on motor drive and then onto the brush sprocket. Push the brush supports back into place on the base. (Make sure that this isn't assembled upside down.) Then line up the front of the cover with the base and tilt the cover back into place. Press firmly until you hear both sides click into place. Replace the cover screws, light bulb and bulb cover.
The belt is available here: http://www.searspartsdirect.com/Kenmore-Vacuum-Parts/742024/0020/116/Model-11658612790/0582/0640500.html . This is part number 5285; it's the direct replacement for the original 742024 belt.
I hope this helps.
Jun 16, 2016 | Kenmore Vacuums
How do I change the belt on the 116 model?
To properly fix a belt on a Kenmore vacuum, you will first need to indicate whether this is an upright or a canister vacuum. The model given, 116, is only the first part of the model number, and all Kenmore vacuums, upright and canister style, start with 116. There is a period first, then a whole string of numbers, 116.255553 etc.
Kenmore vacuums are mainly made by Panasonic for Sears, and most will use a Panasonic belt. If the belt is an upright, this makes it simple, and will be a Panasonic "UB" belt.
For a canister vacuum, most models use what's referred to as a cogged belt. This type of belt has little teeth on the inside of the belt, and is Panasonic CB-5 belt.
Instructions on How to Replace the Belt for an Upright;
There will usually be to plastic screws on the top of the agitator housing on the base of the vacuum, that will say belt access. Simply take a flat head screw driver, and turn the screws so that the screw is pointing up and down on both sides. Then pull the plastic agitator housing, or the top of the base of the vacuum off. Inside you will see a the roller brush, and the belt (or broken belt). Simply take the new belt and wrap it around the silver pulley located in the back of the machine, opposite the roller brush, and wrap the other end of the belt through the roller brush. Stretch the roller brush back into the housing of the machine, and replace the top of the base of the vacuum back on the machine. You should give the belt a tug, to ensure that the brush is spinning when the belt is being pulled..
Aug 02, 2012 | Kenmore Vacuums
Unit works until we put an attachment on and then it loses sucking power
Which attachment is it? If it is the turbo attachment, it may just need to be cleaned out. Hair (both pet and human) can get wrapped around the brush, gears, and belt, causing the vacuum to lose suction. If you clean the head out, the vacuum should run much better.
Also make sure you have the base unit set to "full power" and not the gentle setting.
If this solution was helpful, please consider rating it. Thank you!
Sep 26, 2010 | Electrolux Harmony Canister Vacuum -...
My model F5906-900 --- problem is the brushes have stoped working... I pulled the brush assembly out by holding the two tabs, and all seems clean and the brush assembly rotates easly... onced the brush...
(1) Assure the Brush Control on the hood is NOT set to the OFF position.
(2) Remove the brush assembly by pulling/unlatching it from base on each side.
(3) Does one of the brushes have the drive pin present? It should be about ¼ inch square, and two inches long. It attaches the brushes to the drive mechanism.
(4) Remove and clean the intake filter. One the base of the cleaner, behind the brushes, squeeze the two red abs together and pull the panel down to access the screen. Clean the hair/debris off the screen and reassemble.
Mar 10, 2010 | Hoover F5906-900 Upright Steam Vacuum
We have a Kenmore canister vacuum cleaner. the carpet cleaning attachment, I think is called the power mate has a beater that is intermittently working now
Your hose could be bad. The wires frequently go bad up by the handle switch. also could possibly be the wand, those go bad. You can check that by attaching your powermate directly to the nozzle without the wand and see if the same problem is there. Do you have the mini powermate also? the one that is usually mounted on the wand. If so plug that in directly to the hose and see if you have the same problem. If that tool works fine then the problem is in the powerhead.
Jan 03, 2010 | Kenmore 23812 Progressive PowerMate Bagged...
How do I replace the belt on my Kenmore canister vacuum?
Turn the power brush over so the bottom faces up. On the bottom there are two access screws. Remove the two screws and then the top cover can be removed from the base. With the top cover off you can access the belt. You can get a replacement belt for your model here:
Kenmore Progressive Replacement Belt
Nov 17, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Kenmore 3.9 with power-mate Model 116 2839581. Can't locate screws to allow cover removal for access to motor
You have to take off the top of the power nozzel that has the light lense. There are two pressure locks,one on each side. Use a screw driver to release. You will see the screws.Take the two screws out and on some models, there are two pressure locks on the back of the nozzel. Again use the screw driver to release. The top should come right off.Hope this helps.
Oct 18, 2009 | Kenmore 22313 Bagged Canister Vacuum
The brushes will not turn when on and cannot move them even manually
Drive belt has most likely broke and jammed inside the power head. Remove the bottom plate on the power head and replace the drive belt.
Oct 07, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Wish to remove bottom ofpowerhead-Kenmore Progressive 11629912990
I have a whispertone vacuum, different model #, but maybe instructions will be the same. Turns out I didn't need a new belt, just clean out the crud and reset overload protector. The instructions in the manual tell you to remove the light cover and bulb first. To do this, press in and lift both sides. Push in and turn bulb counterclockwise to remove. (you need to do this because the next step involves turning the unit over). This takes you to
Step 2. Unscrew the cover screws ( on either side of bulb).
Step 3. Turn unit over. To remove cover, insert screwdriver at cover tabs on both sides and twist to release tabs.
Step. 4 Turn unit right side up. Press handle release pedal and lower the swivel. Tilt cover forward from back until front snaps free.
Step 5. Carefully insert and twist screwdriver at each brush support to free brush from base.
Step 6. Remove worn belt.
Step 7. Slide brush supports off to check and clean brush support areas.
To replace belt: slide washers and brush supports onto brush assembly.
Install new belt over motor drive, then over brush sprocket.
Snap brush supports into place on base. Be sure brush supports are not upside down.
Line up front of cover and base. Rest cover on front edge of base. Tilt cover to back. Press cover firmly until side tabs snap into place. Replace cover screws, light bulb and light cover.
Mar 11, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Kenmore Elegance Vacuum cleaner - power bar not working
The problem almost certainly is that the axle of the brush in your power bar has dirt/fluff in it that is preventing the belt from turning it so that the fuse in the power bar clicks off after 2 or 3 seconds. It is fairly easy to fix. All you will need is a Phillips screwdriver and about 15 minutes. Follow the following steps
1. With the power bar disconnected from the vacuum, turn it upside down and you will see two inset screws at the rear side of the base of the power bar. Unscrew these two screws using your Phillips screwdriver.
2. With the power bar in the same position unlatch the two plastic tabs at the rear of the power par. [It may be useful to flip up the metal bar that you see on the base to use as a handle] On each side of the base you will see an arrow saying insert screwdriver here to release. Insert a screwdriver and lever the plastic of the base slightly apart from the plastic of the side. When you have done this for both sides the base should lift off.
3. Now lift the brush including the two end pieces straight up. It should just slide up. You will need to unhook the drive belt from the brush as you lift it out.
4.Pull of each end piece and clean the dust, lint, hair off the end piece and from inside the end of the brush.
5.Once clean, reinstall the end pieces on the brush. Hook the belt back over the brush to its original position and slide the brush back into the power bar.
6. Reinstall the base by hooking the tabs from the front of the base into the small openings on the power bar.then push the base down until it clicks back into place and the tabs are back in their original position. Reinstall the two screws you removed earlier.
7. The power bar should now work. Good luck.
Mar 05, 2009 | Kenmore 22313 Bagged Canister Vacuum
Kenmore 23313 Whispertone Bagged Canister Vacuum Logo
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
