Question about Dayton Vacuums
Dayton 6Z769B Manul, hose, filter
My dyson animal sounds like something is stuck and flapping in the hose,filter, etc. I have taken it apart and I can not find anything. Have you had anyone else experience this issue?
try changing the filter. could be it is coming apart and making the noise. Also sometime these hoses will tear on the inside (lining of hose) and make a flapping or knocking sound. Check the hose as well.
Dec 06, 2016 | Dyson Dc50 Animal Bagless Upright Vacuum -...
Carpet setting: the brush drive does not work with the carpet setting. Is there a way to remove the bottom to determine if something is caught in the system?
To determine if you have a clog, first remove the attachment hose like you were going to put an attachment on. With the vacuum in the upright position, turn the vacuum on and place your hand over the hose. Do you feel a strong suction? If not remove the hose attachment by turning the locking ring at the end of the hose on the back of the vacuum counterclockwise, then remove the hose. Stretch the hose to it's fullest length several times. I would do this over some plastic or outside to keep the dust down.
Once you have done this replace the hose turning the locking ring clockwise to lock it in place, give the hose a little tug to make sure it's attached and locked.
Again, with the hose free from the agitator turn the vacuum on and fee for a good suction.
If you still don't have one then you likely have a plugged filter.
You will need to remove the dust bin.44d2af9.jpgOnce the dust bin is removed, over you trash can empty it by pressing the dustbin door release downwards. Now rotate the dustbin lid counterclockwise to remove the primary filter. With the lid removed grasp the filter and turn counterclockwise to remove the filter.
Pull the filter out over a trash can. Once out inspect it, if it's dirty you should wash the filter in warm water until the water is clear. When finish let the filter air dry for 24 hours before reinserting it.
Upon reinserting the filter, turn it clockwise to lock it in place, install the filter cover with a clockwise rotation to lock it in place and reinstall the dust bin.
Now plug the vacuum back in and again with the hose removed from the agitator or brush and ready to install an attachment then the vacuum on and you should have a solid suction.
These vacuums are really prone to poor suction if the filter get dirty. Because they have washable filters, you should take time about one a month to clean the filters.
Thanks Dorrian
Aug 13, 2010 | Kenmore Progressive Bagless Upright with...
Hi my Vacuum is a zante DV-4399 and i dnt know how to use it i turn it on and it doesnt **** it says to put water in it because it is a water filtration unit i got it from a friend and didnt get the manul...
This is water filter model which requires the regular water, tap water be poured into its container. The amounth of water is 1.5 liter (or 1.8-2 quarter) of tap water. This water is used to filter air coming into vacuum, so dust will stay in the water and after water becomes dirty you have to waste it and replece with fresh water. It CON NOT Work WITHOUT WATER, otherwise next step filter wil be dirty very fast and it will clog the air flow. And , by the way that filter is removable and should be periodically washed by fresh water. This is very good vacuum model !! I would like to buy it too but I can't find it. Do you know where your friend bought it? Please, find it out and send it to my email brrr0000 at yahoo.com Thank you too.
Aug 04, 2010 | Vacuums
No suction?
-Check to make sure the dirt cup is empty.
-Check the filters, If your filters are dirty they can restrict airflow.
The black filters only may be hand washed in cold water with mild detergent, re-install filters when they are completely dry.
-Check for good suction at the end of the upholstery hose. If there is limited suction from the upholstery hose detach the hose from the machine. Insert a broomstick into the hose to push any obstruction through to the opposite end.
-Check the lower hose for clogs. Remove the screw from the left side of the lower hose on the back of the unit and straighten this section of hose by pulling it down or lay unit out flat (the detent will need to be pushed twice) and roll unit on its side with the lower hose towards the top side. Look through the hose for obstructions. Push a broomstick through this lower hose to unclog.
-Check brush belt and replace if broken.
Aug 03, 2010 | Bissell 6594 PowerForce Bagless Upright...
I need a manual for dayton wet/dry vac, 4YE65
Contact "Grainger" by Googling the name...wonderful company that practically invented Dayton
Dec 28, 2009 | Vacuums
I have a dyson dc 17 what is the best way to thourghly cleaning , so I can get better suction , also do you have a instruction manul to. I seem to have misplaced mine thanks
The first step towards improving the suction is to clean the circular HEPA filter. The filter also houses a circular sponge which should be rinsed and dried before putting it back. Check the HEPA filter to see if it needs replacement -- will look muddy! Another quick check is to remove the HEPA filter, run the vacuum cleaner momentarily in upright position to check if suction is restored at the hose end.
After doing this if suction is still poor or non existent, you should detach the transparent canister - a bit tricky since the release rod for the flap has to be aligned when you want to reassemble the unit.
Once the canister is removed, you should check and clean the center tube/shaft for any clogged dust (use a wire coat hanger if needed to pry out the dust). This tube gets clogged if the vacuum cleaner was used to pick up damp/wet spills etc.
Sep 30, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Where can a person purchase parts to repair the hose of an filter queen majestic model 360.
If you live in Iowa call 888-637-4692 or 800-344-1840 for the the Service Center near you. or online at http://www.filterqueen.com/contact-filterqueen-locate-distributor.html
FQ Master
888-637-4692 in Iowa
Your Filter Queen Authorized Service Center
Mar 03, 2009 | Filter Queen Majestic Canister Vacuum
Automatic "shut off" not turning off
Check the filter in the tank, if a dual V model you will have a screen, if not a dual V move the foam filter down about 1/4" to help.The lid on either model needs to be securely in place, as well as locking the left and right latches. On the Dual V model, check the hose door on the front.
Feb 23, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Less suction and high pitch whine while vacuuming
most any vacuum repair shop will be able to remove the obstruction causing the problem
Jul 29, 2017 | Dyson DC14 Animal Bagless Upright Cyclonic...
Vacuums Logo
98 people viewed this question
Top Dayton Vacuums Experts
JoeVacs
Are you a Dayton Vacuum Expert? Answer questions, earn points and help others
