Question about Microwave Ovens
Panasonic inverter NN-CT579S light bulb replacement
ukvacfan
  • 328 Answers
SOURCE: Panasonic Inverter NN-V673S microwave- shuts off after 2-30 secs
If the screen is showing a fault number or a number you havent seen before then its probably a program fault which can't be fixed. Check that the vent holes on the back of the oven aren't dirty and ensure that the whole oven is clean inside. Sadly it sounds like a program fault which cant usually be fixed by the owner though.
Finding a Panasonic oven repairer in the UK shouldnt be a problem though. My parents had a simlar problem wth their Panasonic Inverter oven, called the UK customer services and Panasonic contacted an authorised repairer in Scotland to visit them. Call customer services on 0844 844 3868.
If the call out charge exceeds £80 then you're probably better off buying a new oven.
Posted on Apr 19, 2008
SOURCE: Panasonic Dimension 4 the Genius
i had to take the entire cover off the microwave (it is held in pace by screws at back as well as the bottom). Take the busted bulb to hardware store (bunnings) or panasonic spares and replace. Note I have a slightly different models (nn9853, nn9807).
AH
Posted on May 26, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Hi, I have a NN-C784MF
Chances are there are other bad parts blowing the diodes, most likely a MOSFET.
Also, the ESR of the electrolytic capacitors should be checked and all board connections must be checked and resoldered if suspect.
If you're not experienced in troubleshooting switched-mode power supplies (inverters) then you can probably save a lot of timer and money by replacing the whole inverter.
You can find the nearest spare parts supplier by selecting your country then the support links at Panasonic.net.
Posted on Jan 02, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: Panasonic NN-P295 Cooktop Light not working
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jan 23, 2009
SOURCE: Replacement light bulb for Panasonic NN-9853 Microwave
Hello, I also have a Panasonic Microwave ( model NN-S 564 or 574 ?) They are very similar.
I have just removed the outer cover 5 screws ( unplug of course ) and have located the bulb holder which is a white plastic component with two clips holding the globe, pull it out and remove the two spade clips connected to the globe. The globe will come away attached to a black plastic mount. Next........do the run around to find someone who sells it.
Perth has an authorized distributer/repairer in Myaree whose details I got from Panasonic. He may sell them. otherwise I will try a couple of specialist light globe suppliers I know....PROLAMPS in Belmont and one in BALCATTA whose name escapes me but I have been there before...Hope this helps others.
Martin
Posted on Aug 27, 2009
Testimonial: "Hi - and thanks Martin for an excellent description of the process. Perfect assistance for a handyman-challenged guy like me. Thanks Grant"
How to replace light bulb in Panasonic microwave model NN-S446BA.
Here is the free online manual, but I did not see the light bulb change on my first look through: https://www.manualslib.com/manual/192230/Panasonic-Nn-S446ba.html?page=2#manual
There is a YouTube educational video that may help more: https://www.youtube.com/watch?v=sLidbz2LUtg
I hope this helps you out!
Apr 09, 2017 | Panasonic Microwave Ovens
Change light bulb panasonic inverter nn-h965bf
We recommend you have an authorized service center location replace the light bulb. Authorized service centers can be found in the below link.
www.panasonic.com/repair
Welcome to Panasonic Online Repair
Mar 23, 2014 | Panasonic NNH965BF Microwave Oven
Magic chef overthecounter microwave external light doesn't work
This microwave's replacement countertop light is F60305H00AP. This can be obtained by going to www.panasonic.com/parts.
The instructions for replacing the bulb can be found in the below link.
http://service.us.panasonic.com/OPERMANPDF/NNSD277SR.PDF#page=28
Mar 02, 2014 | Panasonic NN-SD277WR - NN-SD277WR...
Panasonic NN-T994SF Microwave Oven quits after 15 seconds
my microwave shuts off after a few seconds. is there a fuse that needs replacing?
Feb 01, 2010 | Panasonic NN-T994SF Microwave Oven
Martin
May 10, 2009 | Panasonic NN-S540 Microwave Oven
Panasonic inverter model no NN-S540
You can download your owner's manual here.
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
The screws you need to remove should be pretty obvious, and a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 12, 2008 | Panasonic NN-S540 Microwave Oven
Panasonic bulb nn a753
First, get the bulb part #F612E4W00AP or equal. Next, you should find a few screws around a plate in the unit through which the light shows through. Carefully remove them and the glass lens. When replacing the bulb, be sure it is in securely.
Dec 15, 2007 | Panasonic NN-T774SF Microwave Oven
Microwave Ovens Logo
353 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
