Question about Uniden Lands Phones
I am using Uniden Phone of 2.4GHz having a Model No: AS8324-SL. I need a cordless handset to be used with it. Please let me know the compatible handsets to be used with my UNIDEN phone.
Please suggest me the cordless handsets that can be used with my base station UNIDEN AS8324-SL
3 Suggested Answers
shaggyrat
  • 1224 Answers
SOURCE: Dead Uniden DCT5280 Handset
if battery just replace battery but the head sets are compatible with other handsets of same ghz say 2.4 you just gotta set in base and let base recognize new hand set these phones are practically built the same way but only with new technology
Posted on May 10, 2008
anmolsxn
  • 93 Answers
SOURCE: I have uniden cordless phone model dxa15588-2, how
1-Press the hangup key (represented by a red phone) and the "#" key at the same time for at least five seconds.
2-Select "Deregister hs." Choose the handset and press the "Select" key (which also shows an envelope for messages).
3- Choose "Yes" to confirm deregistration. The phone clears its registration information from the base and deletes the link from its memory. The message "Handset not registered -- place handset on base to register. See owner's manual for help" now shows on the display. If you are out of range of the base, "Out of range" shows.
4-Place the handset in the base charging cradle. The phone automatically selects a new security code from those stored in the base.
5-Make sure your phone is working again after "Registration Complete" shows on the display
Hope this will Help. Thank you for using Fixya !!!
Posted on Nov 17, 2010
Turning the ringer on my phone. uniden 6.0
Without the model number of your Uniden phone, I don't know which silencing feature you are dealing with.
Some Uniden handsets have a Silent Mode. To toggle this on and off, press and hold the # key (below 9) for 5+ seconds when the phone isn't in use. When the silent mode is enabled, the handset will ask for a length of time for the 'no-ring' option. If no key is pressed, then the Silent Mode will continue until the # key is held again.
Other Uniden phones have Do Not Disturb. The button to enable/disable this will be on the cordless phone base. The answering system will automatically turn on and none of the handsets will ring when this feature is enabled.
You can also set the ringer volume to zero. Depending on the phone, you can reset this by pressing the volume up/down buttons or going through the menu. Look for the Ringer Volume in the same section of the menu as the Ring Tone options.
If you need additional information, please add a comment with the model of your phone. I hope this helps.
Jun 13, 2016 | Uniden DECT 6.0 Cordless Telephone...
Radio shack 43-113 cordless phone
Re: "compatible extension hand set"
Have you tried Uniden DXI-986-2 900 MHz Cordless Phone with Dual Handsets and Extra Charging Cradle. You would have to disable the base of the main unit of the Uniden and simply use it as a cradle/charger. Additionally, it may be to your advantage to bring along your Radio Shack Hand set when trying/buying the Uniden to see it they will pair up.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 22, 2008 | Radio Shack 433575 Cordless Phone
Uniden cordless handet phones
Probaly cheaper to replace phones
May 18, 2014 | Uniden Lands Phones
I need help in pairing my Uniden DECT 3035+1 handsets to my Optus wireless home ph handset
Have a look at this video.
Uniden Phone Reset, Restore, and Deregistration - YouTube
? 3:09
https://www.youtube.com/watch?v=9B0DwYmk-e0
Nov 9, 2011 - Uploaded by votauno
I used it to finally fix problems with my Uniden phone. Read more ... Press and hold delete on the base while ...
Make sure you have the phone lead into the correct socket. I doubt very much you can pair another phone with a cordless set of a different make.
Please remove the bit with your phone number in it. This site get 7 million visitors a year. Many may wish to phone you for a chat :>)
Your Huwai instructions are here. Don't you know any 14 year old lads? They are usually a whiz at this stuff.
Andrew - Fixya Moderator
http://fastlabs.co.za/sites/default/files/Huawei%20F685%20User%20Guide%20EN%20V100R001_01.pdf
Jul 27, 2017 | Lands Phones
How do i add another handset "uniden 6.0" phone to an existing phone and base unit of the same brand.I need the step-by-step instructions please. thank you!
First make to get a compatible handset.
For the Uniden D1660-2, the compatible handsets are DCX160 and DWX337. Make sure that you have not exceeded the number of handsets that the phone can support. The D1660-2 can support 12 handsets unless you use any DWX337 handsets. Then the limit is 6. (If you have more handsets, you will need to deregister some of them first.) Then allow the handset to charge. If the handset is reading "not registered", then place it into the base unit. You should see "Handset Registering" for about 30 seconds; then it will read Registration Complete. The manual for the Uniden D1660-2 is available here: http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1660-2om.pdf . This is the most common Registration for Uniden phones; there are a few exceptions (depending on the base or the replacement handset). Check the appropriate manual (see below to find the manuals).
For the DECT4096, press Menu on the base and then navigate to Handset Register. When you see Handset Registering on the base display, press and hold # on the handset to be registered until you see Handset Registering. (It takes about 2 seconds.) After the display changes to Handset Registered, check for dial tone.
On a few Uniden phones, there is a Page/Handst Register button on the base. On those you navigate through the Handset menu to Handset Register (Menu > Handset menu > Handset Registration). Then press and hold the Page button until you hear a beep. Then wait for the registration to be completed.
Most Uniden manuals are available here: http://www.uniden.com/scat/cordlessphones_mnl . Select your type of Uniden phone and scroll through the list to your model or use the search box to directly search for your phone and the manual.
I hope this helps.
Jul 26, 2011 | Uniden D16602 Twin Cordless Phone
I need the manual for a Uniden 5.8 ghz phone with answering machine and 3 handsets
Thanks for using FixYa.
Please let us know the complete model number.
Jul 06, 2010 | Uniden 5.8GHz Cordless Phone
Uniden 6.0 answer/base/ cord less message set up
Please let us know the complete model number of the phone.
May 15, 2010 | Uniden DECT 6.0 Cordless Telephone...
May 03, 2008 | Uniden Cordless Phone
ELBT595 & TCX905 compatibility
from uniden regarding your base station:
"This expandable base system is compatible with Uniden handset models ELX500, TCX400, TCX440, and TCX805. However, only the ELX500 is compatible the base system's Bluetooth and CellLink features."
Feb 09, 2008 | Uniden TCX905 Cordless Expansion Handset
Lands Phones Logo
49 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
