Question about Hampton Bay Ceiling Fan. Altura 68 in. Indoor Brushed Nickel Ceiling
Hampton Bay Altura 68 Ceiling Fan makes a tapping noise
Without taking the fan down completely I have it apart while still hanging from a 13 - 18 foot ceiling. Fan blades are off, bottom cowl (covering the remote control and other wiring) are off and hanging. Still no luck finding the source. It seems to be coming from the inside of the upper fan housing. There are some screws up on top but I'm a bit reluctant to try dis-assembly while the fan is still hanging. Any suggestions or ideas - short of removing the fan from the ceiling.
  • 625 Answers
SOURCE: Installing ceiling fan with two switches AND a remote
in your ceiling box should be three wires. a red goes to the three way switches, a black goes to the hot and the white is the neutral. the fan wires are black, blue and white. since you have a remote, connect the [fan] blue & black together with the [line] black. connect all white wires together. the remote will now ramp up your lights from off to full on and the fan remote will let you choose lo med high and off. just tape up the red wire in the box.
Posted on Aug 22, 2007
SOURCE: Hampton Bay Ceiling Fan - Clarington 503837 52"
It slides in above right above the ball, in the mounting bracket where the canopy is. You may have to kind of encourage it to go in there, and you will need to push wiring off to the sides and out of the way to help it have clearance to get in there.
Posted on Apr 15, 2008
SOURCE: hampton bay ceiling fan...where exactly is the code for the remote on the fan
i have 2sets of wires coming down from my ceiling and the prints did not come in my box for wireing them what do i do
Posted on Jun 17, 2008
  • 37 Answers
SOURCE: How to wire a remote control ceiling fan, without using remote.
If you don't want the to use the remote you don't have to, but you don't have enough wires to switch the upper light, the lower light, and the fan. You can, however, switch the upper and lower lights together if that's okay. In order to do that you'd connect the white from the ceiling box to the white (neutral) on the fan, then the green from the ceiling box to any green(ground) wires on the fan, then the black from the ceiling box to the black(motor) from the fan, then the red from the ceiling box to the blue and orange (lights) from the fan. I'm assuming that the black and red in the ceiling box are also in the switch box where the fan/light control switch is going. Those are the ones you'll connect to the controller.
Posted on Jan 27, 2009
  • 75 Answers
SOURCE: lost screws to attach fan blades on ceiling fan
This is not a 'promo' for Home Depot but you will find the screws there that you need.
You will need 15 screws, with an 'unfinished' appearance, for the attachment of the five blades to the arms, and 10 screws that have a smooth rounded finish to attach the arms to the motor housing. If they do not have it in stock they can order ot for you.
If you have an electrical fan store in your area you should be able to find the items there as well.
If you have an old discarded ceiling fan, take the screws out of it and try them on your current fan, they should work.
Good luck. :)
Posted on Apr 26, 2009
My Hampton Bay, Altura 68 in ceiling fan (Model # 26668) has bad MR77A This receiver has been discontinued. Does anyone know of a "universal" receiver that well replace it?
Home Depot has drop in models that will work for your application. You will have to remove the old and wire in the replacement inside the fan housing.
Feb 12, 2017 | Dryers
On its own went from low to high speed and can't slow it down
Windings in the motor shorted out or the switch shorted out.
Sep 11, 2012 | Hampton Bay Ceiling Fan. Altura 68 in....
Fan won't reverse though it has before
It could be 1 of 3 things. 1) Receiver unit, 2) Sender (Remote), 3) Motor. For my brand new ceiling fan it turned out it was the motor.
Jun 13, 2010 | Hampton Bay 24002 Ceiling Fan
Altura 68" fans will not operate on high speed.
I jtoo, ust bought The Altura (68" fan from home depot)
Home depot makes hampton bay through various chinese manufacturers.................
The fan ran slow on high speed, and barely ran on medium or low.
home depot gave me a number for their tech department that knew right away.....that the capacitor(s) are defective in many of the Altura fans.
They are sending the capacitors in 3 days to me no charge.
They are located under the fan ( remember the white square plastic plug you had to connect and the 2 wires for the optional light kit?.....)That plug is for the capacitors that everyone is having a problem with.
My guess is they are under rated for a fan that big and are sending better ones to those with problems.
Hope this helps.
The number is:
Aug 18, 2009 | Hampton Bay 24002 Ceiling Fan
Altura 68" ceiling fan noisy
Jan 13, 2009 | Hampton Bay 24002 Ceiling Fan
Hampton Bay w/ remote and will not reverse.
To eliminate this problem and any humming noise, remove any wall switch that turns off and on the fan, just remove the switch from the line and use the remote to operate the fan.
Jul 29, 2008 | Universal Remote Control Hampton Bay...
Altura 68" Ceiling Fan
That's because it's 68" across, even though it uses the name motor inside as a 52" fan.
Jun 19, 2008 | Hampton Bay 24002 Ceiling Fan
High speed only 60rpm
I too just installed a 68" Altura and noticed a huge difference in fan speed. I spoke to a rep for the manufactorer and found out that the high, medium, and low rpms are 70, 45, and 25. The typical 52" fan has rpm speeds of 190, 130, and 75. The kicker is airflow. The 68" moves 7,808, 4,417, and 2,953 cfms on high, medium, and low; the 52" fans move 5,503, 4,087, and 2,509 cfms.
Jun 10, 2008 | Hampton Bay 24002 Ceiling Fan
Hampton Bay Ceiling Fan. Altura 68 in. Indoor Brushed Nickel Ceiling Logo
42 people viewed this question
Top Hampton Bay Televison & Video Experts
Tom Chichester
Michelle Balcom
Are you a Hampton Bay Televison and Video Expert? Answer questions, earn points and help others
