Question about Lenovo ThinkPad R60 Notebook
Lenovo R60 connection problems
I cannot get the laptop to connect to my home network. Neither will the browser (IE 6 or 7) connect to the internet. The hardware is all OK as SKYPE is working fine and any installations connect and download updates with no problems. The problem seems to have occurred after using the Norton removal tool to get rid of Systemworks 2005 and Norton internet security 2007. I did this as the overheads with Norton are now unacceptable. I have tried various settings including deactivating the firewall (windows native) I have also tried resetting the Workgroup membership parameters several times. I have monitored the connections and they are all checking out as good (wired and WIFI). The DHCP is allocating the IP address and it working without any problems in the dynamic mode with a quick registration. So:- IP OK, Hardware OK, Can connect but will not browse and will not network within the workgroup.
  • Stefan Bartkowiak Jul 05, 2007
    Using XP Pro
    DNS Flushed OK, still no browsing available.
    Ethernet wireless adapter Intel Pro/wireless 3945ABG
    (Same symptoms apply to Broadcom NetXtreme Gigabit ethernet adapter)
    IP address
    Subnet mask
    Default gateway
    DHCP Server
    DNS Servers
    ( = Voyager ADSL Modem/router)
    This computer is part of a home network where the other computers are working OK.
  • Stefan Bartkowiak Jul 07, 2007
    Thanks for the suggestions, but I got impatient and ripped up the registry. In fact all I did was remove any registry reference to Norton or Symantec and it won't go into Windows as a system file is supposedly now missing.
    Basically Norton gets into everything and it's difficult to shake off. I'm going to use the recovery utility to save any files worth saving and run a clean install of windows.
    The laptop is my daughter's and she starts university in September so it won't do any harm to dump all the rubbish she's accumulated.
    A nice shiny new setup and a ghost image and I'll be happy.
    Thanks again.
  • 624 Answers
Stefanus, First off go to the command prompt, enter ?ipconfig /flushdns? and hit enter. Then try browsing the Internet. Lots of odd issues involving Internet connection failures are DNS related. Sometimes flushing the local PC cache helps. If that fails in the same command prompt enter ?ipconfig /all? and hit enter. Find the section that pertains to the network adaptor you are connecting to your network with. Find and supply us with the IP addr, subnet mask, default gateway IP and dns servers IP. Also are you using XP Home or Pro? Once you respond we?ll pickup from there.
Posted on Jul 05, 2007
  • 1 more comment
  • tomj23 Jul 05, 2007
    Can you "ping" outside your network? Try entering the following at the command prompt "ping". You should get back three replies if everything right.
    If you can ping I think you may be having either TCP/IP stack or Winsock corruption issues. You can try the following; however, note that you should backup all your data not to mention your registry before attempting. These tools can do amazing things, however, they could make a mess as well.
    1) You can reset the TCP/IP stack and restore it to its original, out of the box state when the operating system was installed. At a command prompt enter:
    ?netsh int ip reset c:\resetlog.txt?
    Note that programs such as antivirus, firewalls, proxy clients may not operate correctly after performing these steps.
    2) You can reset the Winsock catalog to the default configuration. At the command prompt enter:
    ?netsh winsock reset catalog ?
    Note that any previously-installed LSPs will need to be re-installed.
    What is an LSP? Winsock, Windows? network socket facility for applications, is extensible by a mechanism known as a Layered Service Provider (LSP). Winsock LSPs are available for a wide range of useful purposes such as internet parental controls and web content filtering. Also note that this is a new tool added to XP Service pack 2 and replaces the manual process.
    If you aren?t too comfortable with the command prompt usage you can download a free utility called WinSockFix. It can create a backup of your registry and performs the following functions:
    ? Detect your current Operating System
    ? Release the IP address, taking you "Offline"
    ? Reset the TCP stack using Netsh.exe (Windows XP only)
    ? Delete the current Registry TCP and Winsock Values
    ? Import new "Working" Registry Values
    ? Backup any Current "Hosts" file
    ? Replace the "Hosts" file with a default one
    ? Reboot the Computer
    Here is the download link for WinSockFix:
Can't start my wireless modem
I think the problem is you cannot connect to the internet wirelessly using your laptop. The problem may lie in the modem or in the laptop itself.
First you need to isolate the problem. That is, determine if the laptop or your modem is the one that has the problem. If you can connect to the internet using your laptop in someone elses home network or free wifi outside your home, then the problem is your modem. BTW, modems don't have the capability to connect wireless devices to the internet. You need a wireless router. If what you have is a router, you're on the right track.
If your laptop can detect your home network, try connecting to it. If you're getting an error, call your Internet Service Provider. They should be able to help you fix the problem. Also, try updating the driver of your laptop's wireless card. You can do this by hardwiring your laptop onto your router, go to device manager, right click on your wireless card, then hit update driver. If nothing works, call your laptop's OEM.
Sep 28, 2011 | Lenovo ThinkPad R60 with Wireless Wide...
I have an IBM Lenovo ThinkPad R60 laptop and the hard drive recently broke. I put in a new one and once i downloaded windows XP and stuff I could not figure out how to connect to wifi, can you help? The...
Welcome to Fixya
Make sure that all driver are installed. Especially the wireless LAN driver. Go to control panel then click on system then click device manager. Look for the network adapter category. There should be no exclamation mark to any of the devices listed there. You can download all your computer drivers here. If everything are ok then all you need to do is to go to control panel. Click network connection. Look for icon named Wireless then click on it. Search your router and connect to it.
Thank you for using Fixya!
Jan 09, 2011 | Lenovo ThinkPad R60 with Wireless Wide...
Why wireless and Lan are not working in my lenovo shows connected but it willnot access internet
DNS service is not working.
Reinstall network card by removing the hardware from device manager and reboot. Reinstall network connection set up
Aug 24, 2010 | Lenovo ThinkPad R60 with Wireless Wide...
I am having a lenovo R60 laptop.i am not able to properly read the text in the screen as either the ligthing in the laptop or the brightness in the laptop is not proper in normal day light. Please help to...
The problem is that the "inverter" inside the LCD screen has failed.
It's about a $20 part to replace, but I recommend that you take the computer to a qualified technician for proper disassembly/repair/reassembly/testing of the LCD.
May 20, 2010 | Lenovo ThinkPad R60 with Wireless Wide...
Can't connect to secure wireless network with Lenvo R61i
juss try installing "pod" on server and use "i connect to internet through other computer on this network" option in network settings
Aug 01, 2009 | Lenovo ThinkPad R60 with Wireless Wide...
Wireless connection problem on samsung r60 plus
Try this:
Plug ito your router with a network plug (ethernet adaptor) in a web browser enter the router access code ( or check with your router manual to access the router. once in the router add the PC to the network this should allow you to access the network at full strenght
Feb 01, 2009 | Computers & Internet
Wireless Network Problem - IBM Thinkpad Lenovo R60
FN + F5 is normally starting your radio connection on Lenovo Think pad
Aug 12, 2008 | Lenovo ThinkPad R60 with Wireless Wide...
Lenovo ThinkPad R60 Notebook Logo
254 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
