Question about Jacuzzi Home
My jacuzzi motor is not working
The motor will not work when I press the button
  • Jacuzzi Master
  • 717 Answers
When you push the button and the motor does not turn on there a couple of things to check.
Is there power to the pump? check the circuit breaker
If there is power to the motor then the air button on the top of the tub may be bad or it could be the air switch inside the motor.
Rod
US Parts Center
521-6183
Posted on Feb 07, 2013
4 Suggested Answers
uspartscente
  • 717 Answers
SOURCE: Jacuzzi tub power button not working, can hear it
that is the sounds of a bad air button on the side of the tub.
Posted on Sep 06, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: the button on the jacuzzi
Sorry to read about your problem, I hope this helps you out.
The unit uses a air switch, you should see a plastic tube going from the switch to the power switch.
remove the tube at the power switch end, and then push the switch, you should feel air, come out.
If you feel air, then you must have a defective power switch.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Posted on Dec 29, 2010
landjayc
SOURCE: I have a jacuzzi tub with the whirlpool WOW motor.
Is there a point where you can lubricate the motor on a regular basis so that it will not stick? Hate to think that I have to use a screw driver to turn the motor everytime I want it to work.
Posted on Apr 11, 2012
Why won't one of the spa motors start at low speed?
bad two speed relay on that motor
Oct 10, 2015 | Pool & Spa
Wiring diagram omni step
It sounds like the motor is driven with a "H" bridge which appears to have one of the drivers blown.
Jun 18, 2014 | Office Equipment & Supplies
Sharp Ar 5320E Xerox machine having A problem to start & when machine switch on showing a massage L 4 on machine screen what is the problem
Check the Main motor and the Flat cable..... Put this Simulation also,We can Found it the main motor working condition or not. Press # key then press interupt key and then press c key then again press interupt key, its all enter to very fast.then enter 25 and press START BUTTON and then press 1 button and again START button. Now the Main motor will run.if it is not run the main motor in damage condition.
Jun 30, 2011 | Sharp AR-5320 Black and White Copier
MINN KOTA MAXXUM TROLLING MOTOR WON'T WORK PROPERLY
I'm having the same problem - does the motor have brushes and could this be the problem? mjj2103
Jun 27, 2010 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Leaking water from bottom draw
To put machine into test mode: Press and hold keylock, then press and hold start button. Hold both in until machine beeps (if you have display, it will show all symbols). Press power button- display should now show HO. Press start button until LD shows in display- this tests lid motors. Activate lid motors by pressing keylock button- if you open drawer about 3 inches, you should see lid come down. Pressing keylock again will raise lid. Raise and lower lid several times by pressing keylock button to ensure lid is working properly- if not, lid motors need replacing. Good luck!!
Mar 18, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Unable to open the door of the dvd --when you press the eject button to open the slot---the door does not open---everything else works
Quick trick
First let's find out if the motor is dead or
the magnetic clamp is to strong for the motor.
Press eject then listen closely for the sounds of struggling motor
if you hear it trying SLAP the top right over the DVD drive
and that should break the magnetic seal and release the tray
you may have to try a few times Press eject and open hand slap kinda
hard the top of the DVD drive , don't worry you won't hurt it.
if that works email me and ill tell you how to fix this.
Rob
rsheehan@northernsteeldesigns.com
Oct 14, 2009 | GoVideo Go Video DVD/VCR Combo
Garage door motor reset button must be pressed to work again
It sounds like you have a bad wall control. You can check this out by replacing it with an inexpensive door bell button.
Sep 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
All of a sudden all three remotes stopped working at the same time. Battery is okay, hard wire opener works
You probably have the lock enguaged on the opener. On the wall control, there is a button labeled "lock". Press and hold for 3 seconds and then release. the light on the wall button should be solid now. Your remotes should work. If the light is solid and the remotes still do not work, press the learn button on the back of the opener motor and then press the button on the remote. The light on the motor will blink once. Repeat on the other two remotes.
Feb 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Home Logo
94 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
armylifer
Level 1 Expert
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
