Question about Xerox WorkCentre 4250CM AllInOne Laser Printer
Reset password on xerox
How to reset password if not known or reset to factory default if necessary?
5 Suggested Answers
SOURCE: Centreware password on Xerox 7335
I called Xerox and they had to send a tech to reset the password back to factory. The factory set is username x-admin and password 11111.
Posted on Apr 20, 2009
  • 2072 Answers
SOURCE: How do I reset a Xerox Phaser 4500 Centreware
this should restore it to default.
By default there is no username or password required to access CentreWare Internet Services. If a username and password have been configured for CentreWare Internet Services and you do not remember the username and / or password, reset the printer to factory defaults (NVRAM reset).
To reset the NVRAM, go to the front panel's Main Menu:
  1. Select Troubleshooting, then press the OK button.
  2. Select Service Tools, then press the OK button.
  3. Select Reset NVRAM, press the OK button.
  4. Select Reset NVRAM and Reset Printer NOW, then press the OK button to reset all the settings to their factory default values.
Posted on Mar 03, 2010
SOURCE: How do I perform a factory reset on a Xerox device
lol m looking for the same thing if u have found the answer can you please post it here ?
Posted on Jul 21, 2010
  • 4 Answers
SOURCE: HOW TO RESET XEROX M20I
The closest that you can get to a full factory reset is by doing the following
First: Press the [Machine Status] key
Second: Using the Navigation Keys select [System Admin Tools] and press [Enter]
If the System Admin Tools have already been passcode protected, type in the password and press [Enter]
Third:Select [Clear Memory] using the Navigation Keys and press [Enter]
Click System Data and press [Enter]
You May want to click on each of the given options to make sure everything is gone.
reference: http://download.support.xerox.com/pub/docs/CopyCentre_C20/userdocs/any-os/en/UG_Eng.pdf
section 9 pg 24
Posted on Apr 04, 2011
Reset Averatec 6200 series laptop to factory default.forgot administrator password and dvd player not working
If you reset machine to factory default, there is no password necessary. Appears you have a bad drive.
Aug 15, 2016 | Averatec Computers & Internet
How to reset a Xerox Workcentre Pro 123 to factory settings?
The default userID is 11111, and the default password is x-admin http://www.office.xerox.com/userdoc/CC_WCM_WCP_123_128/CC_WCM_WCP_123_128_Web/pdfs/Quick_Networka_Setup_En.pdf
this guide should let you set dhcp and otherwise control it
I was unable to find a "factory reset" solution
Aug 03, 2015 | Office Equipment & Supplies
Reset to factory settings xerox 3635 mfp
Solution : Perform a Software Reset The Software Reset utility allows for the reset of the machine software without powering the machine off and on.
  1. Press the [Log In / Out] button on the Control Panel.
  2. Enter the password using the numeric keypad, and then select [Enter] on the Touch Screen.
    NOTE: The default password is "1111". It is recommended that the System Administrator change this password. For additional information, press the [Help] button on the Control Panel.
  3. Press the [Machine Status] button on the Control Panel.
  4. Select the [Tools] tab on the Touch Screen.
  5. Select [Device Settings].
  6. Select [Tests & Resets].
  7. Select [Software Reset].
  8. Select the [Reset System Software] button. A pop-up window will be displayed warning that jobs in the system may be lost, and asking you to confirm that you wish to continue.
  9. Select [Confirm] to perform the reset.
Dec 16, 2014 | Xerox Office Equipment & Supplies
How can I reset my I'd username and password?
If admin page allow to create another user account, go ahead to add a new user with known password.
Otherwise, reset to factory default is the only way to remove the password (reset the password).
Be sure to back your configurations before doing factory reset because factory reset will erase everything you have set.
Oct 01, 2014 | Computers & Internet
How set factory default xerox 7800
Solution : Reset the Printer to the Factory Defaults (Reset NVRAM) WARNING: Only use the tool when directed to by Xerox Service. All user and system settings will be lost.
  1. Select [Printer] on the Touch Screen.
  2. Select the [Tools] tab.
  3. Select [Setup].
  4. Select [Service Tools].
  5. Select [Reset NVRAM]. A confirmation screen will be displayed.
  6. Select [Reset NVRAM] again.
Related Knowledge Bases:
Mar 05, 2014 | Xerox Printer Division Xerox Phaser...
Xerox phaser 3600 factory reset
If you're locked out of the NVRAM reset from the control panel, you can still try performing a network reset by going to the Network menu and selecting Clear Setting. After rebooting, you should be able to get in through the administrative web interface at http:// using the default username of admin and password 1111
Aug 22, 2012 | Office Equipment & Supplies
How do you reset a password?
Easy, reset the router itself, should have a tiny pin hole in the back that has a button that you must compress, just google reseting your model.
If you have any problems let me know.
Apr 03, 2010 | NetGear DG834G Router
How do I reset a Xerox Phaser 4500 Centreware password to factory default.. or what is the factory default password? I have on which has been changed and nobody seems to know the PW anylonger
Mar 03, 2010 | Xerox Phaser 4500 Printer
On mine it was the other way around username 11111 & Password x-admin
Jan 21, 2009 | Xerox DocuPrint 4517 Laser Printer
Xerox WorkCentre 4250CM AllInOne Laser Printer Logo
769 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
