Screen on tv is half normal the other half is half blue and the other half solid white
Have removed ribbon cables,cleaned and reseated ,no difference
  • 8,617 Answers
Sounds like the Tcon board has an issue.
Posted on Jan 11, 2013
lukster
  • 217 Answers
SOURCE: half screen activated only
When only a half screen is produced, it is usually a upper or lower buffer board, if the top half is blank then it is the upper buffer, and of course if it's the bottom half then it's the bottom buffer board
Posted on Feb 17, 2007
  • 4234 Answers
SOURCE: Panasonic TH-50PZ77U 1 1/4" inch vertical line
Once you open up the unit, you should see a series of flat orage cables coming from the panel itself. These are the cables that can have poor connections. CAREFULLY remove them by releasing the connector "lock" and reseat them inside the connector. Re-lock the connector and try the set. If that fails, you should have the set examined as specialized equipment will be necessary to trace this problem.
Dan
Posted on May 01, 2008
jerryg50
  • 1667 Answers
SOURCE: Screen goes white
The main driver board, or the main processor board most likely has a failure. The authorized Panasonic service rep can replace the defective boards and perform the necessary adjustments to match them up.
If the set is out of warranty it may be expensive to service. Using the set with a defect can cause more damage, and thus may increase the cost of the final repair.
Jerry G.
Posted on Jan 17, 2009
  • 160 Answers
SOURCE: Half my screen turns white after the TV is on for
You have problem with Main Board or LCD Controller. It's impossible to know for sure unless replace one and see if it will solve an issue. If not - than other board is responsible. Repair should be done by professionals unless you can find parts cheap and got enough skills to repair electronics. No soldering involved. Just board replacement.
Posted on Mar 10, 2010
budmrtn
  • 11361 Answers
SOURCE: Memorex mlt3221. white screen, no sound, no function.
Check the power supply module for bad DC filter caps first, then check the backlight inverter board for shorts.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Please post back what you find.
Posted on Jul 29, 2010
How do I fix my Sharp tv from right side to center there's a half inch black line 9 inches down from top on screen and it changes color depending on background and UNDER the line the image is blurry a
If this is done with every input of your tv and also with tv channels this means a bad circuitboard .You can find on ebay one and mod it yourself. Its not such a difficult thing.
Nov 26, 2014 | Sharp LC40E67UN TV
My screen has half screen
This is either a screen issue or t-con board issue. If the tabs on the ribbon cables are not bonded to the screen correctly this can occur and it is not fixable. However you can try reseating the ribbon cables at the other end where they come out of the t-con board.
Sep 16, 2014 | LG 42LG50 42 in. LCD HDTV
Hi there, The little pc's screen got messed up somehow. The left half is completely fine, the other half is mainly white with a few tiny vertical lines. It's only on the netbook, and...
Yes there is a ribbon cable that connects to the back of the monitor, but as a rule, if that cable is loose you lose the monitor all to gather Was the laptop dropped, jarred, fell over on the screen, with the lid closed? Has a driver been updated resently? I had a similar issue but thr monitor was dark no connection, I accessed the rear of the monitor, and reseated the ribbon cable, and secured it with tape. Your problem sounds different like a software issue. You have tried to reboot? remove battery before, plugging the AC in.
Nov 10, 2012 | ASUS Eee PC 1215NPU17BK Netbook
Hello. I have a LG 47lg50-ua that when turned on, the right half of the screen goes white. The left half still plays fine. The warrenty had just expired so. I took the back of the tv off and looked around....
If you changed the Ribbon cable and its still the same then the T-Con board would of probably gone faulty. Lots of weird screen problems can be accounted for the T-con board.
Mar 22, 2011 | Televison & Video
Half of my screen goes out from time to time. how do i fix that.
This is likely a problem with your TCON circuit board inside the back of the tv.
The TCon board usually has 2 very thin ribbon like cables running from connectors on the board to the actual LCD screen panel. Each ribbon controls one half of the screen. If you are lucky, it's possible one of the ribbons came loose or is not making proper electrical contact with the connector on the TCON board.
If your tv is out of warranty and you are comfortable working safely with electronics then you may be able to repair this yourself with a few hours of screwdriver work. The ribbons may just need to be reseated in the little flip up connectors, or you may have to clean the copper at the tips of the ribbons gently with a pencil eraser to remove any oxidation.
If you are unlucky enough to have a bad TCON board or are not comfortable disassembling your tv yourself then you can bring it in to the shop and they can probably repair it for less than $150.
Good luck and please post back if this helps and with how you make out.
Jan 25, 2011 | Olevia Televison & Video
Only right half of screen shows
If this problem affects exactly half the screen, then there is likely a problem with your TCON circuit board inside the back of the tv.
Good luck and please post back with how you are making out.
Jan 24, 2011 | Westinghouse LTV-32w3 HD Television
I have a fairly new LG LED television and most of the times that I turn it on, half of the screen will be cut off by static and bars and weird colors. It gets lighter and usually goes away after having the...
Good luck.
Jan 21, 2011 | LG Televison & Video
I have a Sony Bravia 32" and half the picture is
Good luck.
Jan 20, 2011 | Sony Televison & Video
White line from top to bottom divides the screen in two half . What do I do to remove it?
you can try to clean reseat your ribbon cables from you t-con boar dto the lcd and also the one that goes to the main booard that is called the lvds cable the t-con board is locate at the top middle o0f your unit if that does not fix it then tht-com board is bad
Nov 20, 2009 | Vizio L37 Television
Half screen , left normal but only half usable. right was black now blue and white, Dell inspirson 1501.granddaughters so would love to fix
Reseat the video cable connection under the keyboard. If no change, press the Fn Key while Pressing power button, this will start a PSA diagnostics, there will be 2 sets of color bars appear and a Yes or No at the end of 2nd color bar, press N to start the LCD diagnostic. If the LCD is still 1/2 and 1/2 in the LCD diagnostic, you need an LCD. If the issue doesn't appear in the diagnostic, then replace the motherboard.
Jun 14, 2009 | Dell Inspiron 9100 Notebook
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
Electro Med Services...
