Question about Amana ALW480DA Top Load Washer
How do you replace the belt on an Amana lw7503w2 washer
SOURCE: belt replacement amana lwa50al washer
instructions on how to change belt
Posted on Nov 10, 2008
  • 65 Answers
SOURCE: REPLACE BELT ON AMANA WASHER
REMOVE THE FOUR BOLTS HOLDING ON THE MOTOR MOUNT TO THE MILK STOOL. DISCONNECT THE DRAIN HOSES, UNPLUG THE WIRING HARNESS AND THEN ROLL THE BELT OFF THE MAIN PULLEY OF THE TRANSMISSION. FLIP MOTOR OVER AND REMOVE THE DRAIN PUMP, NOTING HOW THE BELT WAS THREADED THROUGH THE PUMP MOUNTS.
Posted on Jan 27, 2009
srsrs_1999
  • 9 Answers
SOURCE: AMANA WASHER WON'T SPIN. HOW DO I REPLACE THE BELT?
is this a whirlpool built amana? if so, its most likely a direct drive model, and when it doesn`t spin its likely a coupling between the gearcase and motor assembly...youtube has videos on how its replaced, which isn`t too complicated to do...good luck
Posted on Apr 30, 2009
  • 127 Answers
SOURCE: Amana washing machine LW7503W2. Works fine in
well it could be the timer or it could be the motors other high speed winding has gone bad.
you will need to find a wiring diagram to figure out which wire is the high speed winding and verify whether you are getting power there when the timer is supposed to be making it run in the hi speed setting. if theres power there and the motor won't run the motors bad..
part # 27001215 - 2 SP MOTOR sorta expensive tho $160+
if theres no power there then the timers bad
part # 31239 - TIMER ASSY.$115+
hope this helps,
best of luck,
ttfn
Posted on Oct 26, 2009
Tighten the belt on an Amana washer?
The belt should already be pretty tight after wrapping around the barrel and the motor pulley. The belt may be worn and should be inspected and probably replaced.
To prevent similar problems in the future I suggest you be aware of how big of a load you put in the washer.
Mar 13, 2010 | Amana 3.2 cu. ft. Top-Load Washer
Just put a new belt on an Amana mod. no. LW7503W2 and it gets hot enought to smell and hot to the touch. Why?
The belt is either too loose or the part being turned by the belt is bound-up. Remove the belt again and turn the driven pulley by hand--it should not be very hard to move. Turn it in the direction that the motor runs.
Aug 15, 2009 | Washing Machines
Replace Broken Belt
Here is the link that will explain how to do it:
http://www.applianceaid.com/amana-wash.html#belt
check this link u ll get if u dint really sorry for in convinience
Jun 17, 2009 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
The water ran out onto the floor after the wash cycle on lw7503w2
remove the front panel. You will see two hoses connect to a water pump. The leak can be from lose hoses or leaky pump.
Nov 15, 2008 | Amana ALW480DA Top Load Washer
Washer over fills model lw7503w2
hi not common for the level switches to fail ,check the small hose the feeds the controlfor holes or kinks or blockages
cheers grant
Oct 23, 2008 | Amana ALW480DA Top Load Washer
Amana ALW480DA Top Load Washer Logo
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
