Question about Home
Sinanova whirlpool bath faulty air switch on pump sirem ic 250
  • 717 Answers
We have air switches for the bath pump. You can find them at the following link: Air Switch
Let me know if you need further help.
Rod
US Parts Center
Posted on Feb 08, 2013
4 Suggested Answers
  • 2712 Answers
SOURCE: Difference tubs and air baths
whirlpool tub has jets that circulate the water, where an air bath uses bubbles that rise gently from the bottom of the tub. Whirlpools are typically used for therapy, air baths are used for a much gentler experience. Air baths can be used with aromatherapy/essential oils. Both offer a spa-like experience.
Posted on Aug 27, 2008
  • 12104 Answers
SOURCE: Kohler System II bath whirlpool: Pump does not go
check switch and for power and properly working also check motor for proper wiring and power
Posted on Mar 04, 2010
  • 8 Answers
SOURCE: new whirlpool bath installed pump
I would guess there could be one of two problems. First, open the access pannel so you have acces to the motor and air tubes. From your actuator that turns on the jets, there should be a small tube (probably clear) that goes from the actuator to the motor. this tube controls the jets, make sure it is connected, finding the small nipple that this tube connects to on the motor can be difficult and they are often not connected when you buy the tub or come loose during instalation. If that is OK, check to make sure the Air Inlet pipe is not blocked. there should be one (maybe 2 but usually 1) of the large tubes that circle the tub undernieth that is open on one end. It is probably the tube that is the highest off the ground. this should not be connected to anything, it almostt appears that the water would rush out if you don't connect it to something, but that is where the air comes in for the bubbles. good Luck
Posted on May 07, 2011
I have a HydroAir Magna Series Whirlpool pump model #LD7AC that will not shut off with the airswitch. The airswitch does not appear to be disconnected nor does the tubing appear to be clogged. Any...
If your bath pump LD7A-C will not shut off when you push the air button then the AIR SWITCH in the motor needs to be replaced.
This is a pretty common problem with Bath Pumps and easily fixed.
Rod
US Parts Center
888-521-6183
Mar 18, 2013 | Home
Hydroair magna series whirlpool pump model #LD7AC airswitch does not work. It appears to be connected properly and not blocked. Any suggestions?
If your Bath Pump will not shut off when you push the Air Button, it sounds as if the Air Switch is not working in your Bath Pump.
Click on the Air Switch name and it will show you the replacement part you need to fix the Bath Pump.
Rod
US Parts Center
888-521-6183
Mar 18, 2013 | Balboa HydroAir Magna Series Spa Eyeball...
Replacing defective pump switch
The air switch on a bathtub is located in the bath pump. Your description sounds like you are asking about the air button which is located on the top lip of the bath tub.
Click on those links to see your options for whichever part you need.
Rod
U S Parts Center
888-521-6183
Mar 17, 2013 | Home
How to start the jets on an MTI FURO MTDS 59
Checking the circuit breaker for power to the pump is obvious however the control that turns the bath pump on/off may be the real problem.
MTI has what control box to operate the pump?
Check there first because that may be the problem before the bath pump is a problem.
We would need to know the model number of the bath pump and the control box if there is one that the bath pump plugs into.
Rod
US Parts Center
888-521-6183
Mar 11, 2013 | MTI Furo MTDS-59 AST59
Push button on my jacuzzi won't start it despite power going to unit
The air button on your tub may be bad and not sending enough air to the air switch located on the bath pump.
The way to check this is to remove the bath pump and see if you can turn the bath pump on by taking a large straw and blowing into the air switch on the bath pump to see if you can get the bath pump to turn on.
If the bath pump comes on then you know you have a bad air button.
If you cannot get the bath pump to turn on then remove the air switch and plug the two wires going to the air switch together and then plugging the pump into a power outlet you know has power.
If the bath pump comes on then you know you need a new air switch in the motor.
If the motor does not come on then you need a new bath pump.
Rod
US Parts Center
888-521-6183
Mar 10, 2013 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
The air switch on my whirlpool tub will not toggle, i must hold the button in to keep motor running.
What you are experiencing when you push the Air Button down and it engages the BATH PUMP but when you release the the Air Button is a bad Air Switch in the BATH PUMP.
When you push the air button down it sends a column of air to move a small switch in the BATH PUMP. When the switch in the BATH PUMP is bad it will not engage.
What you need is a new Air Switch model TBS-339.
Rod
US Parts Center
888-521-6183
Feb 28, 2013 | Home
I have a Jacuzzi whirlpool bath model U640 Espree 536 and it wouldn't shut off. I cut the air line off at the pump and nbow it won't stay on for more than a few seconds. Any ideas?
I assume you hooked the hose back up to the air switch on the motor.
There will only be a couple of things to check.
Make sure you have a good connection with the air hose to the air switch on the motor. Sounds like maybe the air switch may be bad.
The Air Switch is a latching air switch so if is broken then it won't latch when the air button is pushed.
Rod
www.uspartscenter.com
Jan 23, 2013 | Jacuzzi Home
Jacuzzi whirlpool, air on/off button on tub
If it is a air button that pushes in and comes back up, there is a good chance that the switch (which is mounted on the pump/motor) is bad. If the switch is a touch button on a key pad, the problem is in the control box for the pump/motor.
Sep 05, 2009 | Jacuzzi Signa Whirlpool Tub B540
Kohler bathtub spa does not work at all
you need to see if there is power to the pump 1st, there may be a switch somewhere thats not been switched on or it may have tripped out so check that. the air pressure switch maybe faulty or the plastic hose may have even come away from the switch.think of the basics 1st then look deeper, if you have power at the pump then it can only be the switch or worse case scenario a new pump.
you might have to remove the bath panel to gain access to the pump better?
kindly
Richie
Dec 14, 2008 | Kohler 1107-R-0 ProFlex Bath Tub with...
Home Logo
69 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
