Question about Panasonic PT-47WX49 47" Rear Projection Television
The capacitor! i think i found it!
ECA1EM472E is the part # i've already got a price i have one last question and i would not have been able to even know what to look for without thi web site,just to make sure When the capacitor has goo coming out of it IT needs to be replaced? And i guess one more what would make this happen
  • 32 Answers
Mr. D: The capacitor top generally on new electronics components have a "cross like" mark on the aluminum top (+). When this "cross" is open up like a "canopy", capacitor must be replaced, because it is completly damaged on the inside. This occurs for 2 main things: 1. A cold solder (weld) that forces the capacitor to overreach their capacity of energy storing, and... 2. Reversed polarity causing overheat inside of it and then it simply can't stand the low level of resistance and explodes. SithPitt
Posted on Jul 04, 2007
NEED A REPLACEMENT CAPACITOR FOR a PPU6 1/6TH HP SUBMERSIBLE
Motor capacitors are usually available as spare parts from the appliance dealer but usually grossly over-priced.
Also available from specialist electrical suppliers at slightly better prices.
The last time I needed a capacitor the make and type was still visible on the casing and google found the company. One email later and the local agent got in touch with the price and offered to post it immediately.
The supplier of the pressure washer wanted more than £60 for a capacitor that cost me £4.63 plus carriage and tax from the capacitor's Italian manufacturer local English agent. I paid just under £16 and it did arrive the next day.
With some motors any shape or size will do as long as the value and voltage are correct but when it must fit in a waterproof or water resistant housing it is best to have an identical replacement.
Mar 15, 2015 | Dryers
Battery does not last even 20 minutes
Simple, replace your battery.
Search online for Lenovo G550 replacement battery. They range in price from about $25 and up depending on brand and quality. The cheaper ones typically are Chinese import knock-offs, which can do fine, but may have reliability issues. I've had several and for the most part they work ok. For the price, its not likely buying the highest priced will necessarily make it any better in the long run. Just make sure the source you buy from (ebay, amazon, craigslist) are reputable and offer a replacement warranty.
Aug 26, 2012 | Lenovo G550 PC Notebook
OrbiCam Problem. Webcam not Found.
click on right side of screen and then type camera in the search box . mine does not always want to come up. either but when I use SKYPe it is active .
Mar 04, 2017 | Acer TravelMate 4222WLMi Notebook
Have a 4 blink error on a Sony KV36FS120
Yes, there's a posibility that IC561 is partially faulty but on the symptoms you've described, I would advice you to replaced first C539(470uf/25V) and C561 (47uf). I've suspected that these filter electrolytic capacitor is already leaky or dried up...
Dec 08, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Hi there, do you have the schematics for the Panasonic CT-27sf37b. This TV won't power up but making a high pitch sound near the thermistor area. Thanks.
Hi Richard,
First of all thank you for contacting Fixya.com regarding your TV problem.
You have mentioned that you can hear a high pitch near the thermistor area and the TV won't power up. I've saw also in another link that you already replaced the thermistor but the symptoms still persist. You stated that the thermister heats up, that is normal and not an issue in this kind of symptoms. You can power up the unit even without the thermistor in the board and check if the high pitch will gone or not. But I've suspected that the symptoms will remain the same because the pitch came from the chopper transformer.
I've encountered this kind of symptoms not only on panasonic CRT TV's but almost in all brands. And the major caused of fault is the faulty electrolytic capacitor in the Voltage regulator IC. Your unit used STRF6524 (mounted on the aluminum heat sink) as voltage regulator IC and it has an electrolytic capacitor on its circuitry. I would advice you to replaced it to resolve the issue. The largest electrolytic capacitor is not the suspect here (don't replaced it).
Also check for bad solder joints around the regulator IC. Cracked, cold, dried solder can produced that kind of symptoms. It is hard to spot, you must used magnifying glass and work in the brightest area or much better to re-solder the suspected bad solder joints.
I have various of Panasonic schematic diagram but most of them is a LCD and Plasma TV. I don't have this model no. but please check the chassis no. of your unit and I will try again to find it on my supplier to give it to you for free as much as possible because I've saw it HERE but I don't think the price is reasonable.
Please let me know if you need further assistance.
Again, thank you and have a nice day!
Kind Regards,
Jdvillanueva
Dec 07, 2011 | Televison & Video
I have a Aquos LC-37GP1U new out of box. Have the blinking light issue. Power on for 2 seconds and then shut off. Replaced the power supply board as it was cracked. Still didn't help. Should I be...
You have to check if the replacement power supply board is the same part no. as the original one, it is printed on the board itself.
I don't think that the fault came from defective electrolytic capacitor because like what you have said, the unit is new out of the box and you've already replaced the power supply board which is most of faulty electrolytic capacitor came from that board.
You've mentioned also that the original power supply board has cracked, I've suspected that the main board also has been damaged because the blinking led light error codes will be encountered if the power supply board or main board gone to malfunction. If you've confirm that the power supply board is the same part no. like the original one, then I would advice you to replaced the main board.
Have a great day!
Mjsazon
Nov 27, 2011 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
How do I clean a point=and-shoot camera lens (hidden when camera off)?
When the camera is on and the lens is out, the best cleaner I've found is called a "Lenspen". Just Google that and you will find several companies that provide it for a very reasonable price. This thing is so easy to use and lasts for years!
Sep 26, 2011 | Panasonic Lumix DMC-LZ7 Digital Camera
Water temp control wont work, wrong temp comes out periodically set on hot comes out cold or set on cold comes out hot, already changed the temp control and new one does the same thing, any ideas?
There is a sensor switch that allows water from one tap or the other, or both. If this switch is flawed, it will confuse the temperature that is allowed to come from the faucets. You'll need to replace it. If you're skilled at this sort of thing you can do it yourself. If not, you'll need to call a professional. The replacement and repair doesn't take much time and is reasonably priced. If you're calling a professional, now that we've narrowed down the problem, you can call around and tell them you think your water temperature switch is bad and how much will it cost to have it replaced. When you've found a reputable pro with the best price, get them out.
I hope this helps. If it does, please come back to Fixya and rate my advice. Thanks.
Aug 05, 2011 | Washing Machines
I have had the Frigidaire dehumidifier model FDB5OR1 for four years. Starting last year, the unit would occasionally continue to operate after the bucket was already full, resulting in puddles on the...
The faulty float valve is almost always the problem, based on what you described. It is a replaceable part, but you may have to but the entire bucket assembly. Generally, they run around $50.00. However, not all parts are still available for that model, even though it's only 4 years old.
If you want pursue finding the float valve or a new bucket assembly, the best place I've found is online is Appliance Factory Parts http://www.appliancefactoryparts.com/search/index.php they carry parts for just about any appliance you can think of.
Or Frigidaire Parts Select
http://www.partselect.com/Entry.aspx?Source=GAWS&Brand=Frigidaire&Term=frigidaire&gclid=CIfU4u28vqkCFcPd4Aod6CC5hQ
I hope this helped you. Please let me know. Thanks.
Jun 18, 2011 | Frigidaire FDL50R1 Dehumidifier
Hplpw175x7
Thats a good price as long as they guarantee that it works. How were you able to pull a capacitor off without un-soldering it?
May 30, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Panasonic PT-47WX49 47" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
