I got again F16 error code on my washing machine. It has happened several times before. Than came the assistence, 15 minutes and the washing machine worked againg, and 50 euro flew away... Someone knuwn if I can fix it by myself ? Thanks Fab
SOURCE: Ariston Washing machine A1636 - Flashing lights
always reset your machine ;turn your dial to the end of the cycle [ the dot] it should flash 3 times quickly, then turn off the machine and on again. then start washing again ...hopefully..worth a try.
SOURCE: Zanussi ZWD1471W Washer Dryer error codes help please!
Click on Zanussi (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, voila! u hv your manual on line. And dont forget to rate me, on this great site.
SOURCE: Ariston Front Loading Washing Machine error code F07
Error code F07 is indicating that the heater relay is stuck for one reason or another.
This could be a board problem, as this where the relay is located.
However, it would be worth checking that the heater is o/k before you do anything else., as this possibly could cause the relay to malfunction.
Plz rate my solution.
Thanks.
SOURCE: F1 error
there is a factory defect in the control circuit board of this washer, read and call the number. post is from another owner.
I called 800-659-7026, which seems to be a 3rd party "recall" center for appliance companies, for my F1 error code. All Kenmore HE Elite Oasis machines with Serial Numbers beginning with CS48-CT49 are in the process of being recalled; however the mailings haven't gone out to customers due to hold-ups in legal with wording. Machines with these serial numbers require an upgraded control board and it takes about 10 business days for the part to come in. They ordered it with no questions asked and are coming out July 14th to replace it free-of-charge
SOURCE: My Maytag Neptune TL FAV6800AW Washing Machine is
Hello zacas6,
dC/uC unbalance errors are caused almost all the time by a Clutch malfunction. Take a look this post and see if you want to DIY the repair. I will help you through the process.
I would also check the Tub Displacement Sensor. This a thru the lid check and you get a feel of how to enter Service Mode.
Tub Displacement Sensor Diagnostics check.
It is possible the Tub Displacement Sensor may have failed try this check which is in the Troubleshooting guide stored in your washer console or refer to the SM.
a. Enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
b. Press the Super Wash key display reads “in”…something like that.
c. Press Delicates the Display will show “UC” (Unbalance Closed).
d. Push tub to the back right corner of the machine the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
e. Press Hand Wash.
f. Pull tub to the front left corner while pushing the tub down the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
I have some additional info if you decide to remove the Clutch in the machine if you are going to DIY.
Rich
