Question about NetGear WGR614 Wireless Router
I've never setup a wireless router before and I'm nervous. I need someone to walk me through the steps so i don't screw it up. i have a Net gear WGR614v10 router with a yellow cord and a g
Someone gave me the router so i wouldn't have to buy one. My daughter has an ipod, a nook and a 3ds. I want her to be able to go wireless with them here at home. I have no manuals with this router at all
  • 2,878 Answers
Easy Peazy, Nice and Eazy,
Connect the ISP modem, that may be connect to your home computer right now, to the main input in the wireless router. Now connect the computer to any other port available with a second network cable. You just did the basic setup.
Now hold the tiny reset (with a pen) in till the unit cycles through. This will clear all custom / security settings, and leave like new. You now can connect any wireless devices. Just choose you SSID netwotk ID (user).
Security requires some administration via web admin, but this should get you going for now. GL
Posted on Jan 11, 2013
  • 101 Answers
SOURCE: Netgear DG834G Setup
Hi Tradeboy,
This link should walk you though it, step by step!
http://www.geekgirls.com/windowsxp_home_network.htm
If you are using Vista, you will probley want this link, too. Click on Network icon.
http://windowshelp.microsoft.com/Windows/en-US/default.mspx
In the past I have found the biggest issue with networking is firewalls, so I suggest you disable them just for testing and setting up your network.
Good Luck
Posted on Jan 11, 2008
router-user
  • 550 Answers
SOURCE: link the netgear wgr614v10 to linksys wireless adapter
First you will need to check the wireless settings of the router. Do you have any computer connected to the router ? If not then connect the computer to the router and open the set up page of the router, check the wireless settings of the router.
Once you have all the wireless settings of the router then you can try to connect to the wireless network on your wireless computer.
Posted on Apr 17, 2010
CreativeTECH
  • 1719 Answers
SOURCE: i have tried everything, and i can't get this
During configuration, you must enable the router radio and SSID (Name) broadcast, so that the router would be visible to laptops and other wi-fi enable devices.
Select Wireless Settings under Advanced in the main menu of the WNDR3300 router.
Make sure the Enable Wireless Router Radio and Enable SSID Broadcast check boxes are selected.
Hope it helps!
CreativeTECH
Posted on Dec 03, 2010
CreativeTECH
  • 1719 Answers
SOURCE: i have two netgear routers
Most routers (Wireless-G) have about the same range. However, the actual range in real-time environment is much less. I think that your network would work fine if you place the router at a suitable location i.e. at the central location/ height. Also, based on my on-site experience, I suggest that you may relocate the router to another location depending upon your network environment. It has always helped me a great deal. Placing the router avoiding obstacles such as concrete pillars, walls, steel cabinets etc in the signal path have remarkable effect on range and overall performance of the network.
2. There are two ways to increase the range/ coverage area (i) Adding external antenna of appropriate type (ii) Installing additional Access Point (AP) connecting it with the existing AP wirelessly in line-of-sight (creating WDS) OR connecting the two APs with wire, which is a better option as it provides robust and reliable connectivity between APs.
3. So, in short, to extend the range, it is recommended that you may place the additional router at an appropriate location as described above and connect it to the existing router through wire (CAT-6 Cable). (The router would communicate through wire and the range of your networ would extended up to the placement/ location of the additional router. Rename the additional access point for easy identification and make it secure.
Hope it helps! Good Luck!
CreativeTECH
Posted on Feb 28, 2011
SOURCE: I had someone set up my new NetGear Router, but
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Jul 16, 2011
Testimonial: "Thanks heaps."
Lock my d-link
You can access the router through web interface and configure it.
The default username is admin and leave the the password field blank - Don't type anything - and Click Login). All you have to do is connect the router to the DSL Modem through LAN cable (or wirelessly) and make configure the router according to the needs and ISP. To secure the connection follow the following steps: -
First you have to access the router through web browser (Internet Explorer) by typing the IP address of your router in the address bar, which is 192.168.0.1 (written at the back of router) and lookup for the options to do the following: -
1. Change the SSID (Name) of the router
2. Change the default administrative user name and password (unless you've configured otherwise, the default username is admin and leave the the password field blank - Don't type anything)
(The above step would prevent unauthorized access to your router)
Next step is to secure it:
1.On the left-hand side, under Setup, click "Wireless Settings" 2.Under "Security Options", select your desired encryption method (preferably WPA2-PSK)
3.Choose a Network Key - it can be anything, as long as it's 8-63 characters in length
4. Click Apply
Now your router and your connection would become secure and the user has to provide the network key to access the internet.
You may refer to Product Manual (Page47 onwards for security settings)
Feel free to contact me for further assistance
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Oct 27, 2011 | D-Link DIR-615 Wireless Router
Dir 615 Instructions
4. Click Apply
CreativeTECH
Oct 20, 2011 | D-Link DIR-615 Router
Cannot log onto wifi due to lack of password
Looks like you are trying to access a wireless router that is secured but you don't have a password. If the router is yours, it's a simple matter to go into the router setup and view or change the wireless password. I suspect, though, you are trying to access someone else's network. In that case, you need to contact the person who manages that network and get their password if they'll let you use it.
Sep 15, 2011 | Sylvania G-Netbook
Can't secure D link router
All you have to do is connect to the router and secure the connection follow the following steps: -
First you have to access the router through web browser (Internet Explorer) by typing the IP address of your router in the address bar, which is 192.168.0.1 (Default router settings are written under the router)
(unless you've configured otherwise, the default username is admin and the password "leave it blank") and lookup for the options to do the following: -
1.On the left-hand side, under Setup, click "Wireless Setup" 2.Under "Wireless Security Mode", select your desired encryption method (preferably WPA2-PSK)
4. Click Save Settings.
Let me know if any further clarification/ assistance is required.
CreativeTECH
May 31, 2011 | D-Link DSL-G604T Wireless Router
Creating a wireless network
1. go into the Windows control panel and click on the network link to get to the Wireless setup Wizard and it will walk you through the setup.
2. Step by step instruction in the "helps" files on your computer. You also can go to Microsoft site and view the videos and the knowledge base to show you step by step instruction
May 30, 2010 | Zyxel Prestige P-330W Wireless Router...
I need to do a factory reset
The router's admin page is http://192.168.1.1 or http://192.168.0.1 and the default password should be either "admin" or "password" without quotes. There should be a choice under "Setup" called "Factory Reset". That will erase the settings and reset it like new.
Alternatively, you can follow the procedure as given below on all the brands I've tried (Belkin, D-Link, Linksys)
1. hold the reset button for 30 seconds (don't release)
2. unplug the power (still holding reset) for 10 seconds
3. plug power back in (still holding reset)
4. hold reset for another 30 seconds - the lights will usually begin flashing in some odd pattern
5. release the reset button
6. wait 1 full minute or until the lights stop flashing
7. unplug the power for 10 seconds, just to do a reboot
8. verify the settings (e.g. SSID) are back to the defaults
Feel free to get online D-Link router/wireless router support at http://www.vtechsquad.com/wireless-router-support/ to fix D-Link router/wireless router issues.
Jan 06, 2010 | D-Link DI 514 Wireless Router (DI-514)
Wireless network seting
It depends if it's Windows XP then just go to START/SETTINGS/NETWORK connection.
Click on wireless and should walk you throug step by step.
However, you must have a wireless router!
The router also has to be setup FIRST to activate the wireless function.
It's a bit complex because you need to set several 'keys' and channels.
My suggestion is to get help with your network setup on the ROUTER first.
Then all the other things should be very easy.
Apr 09, 2009 | Acer Aspire 5610-4648 Notebook
Reset to factory settings??
Step 1 With the unit on, place a paper clip into the hole on the back on the unit labeled Reset. Step 2 Hold paper clip down for 10 seconds and release. Note: Do not repower unit during this procedure. Step 3 The unit will reboot on its own. Once the WLAN light stops blinking, the unit is reset. Resetting the router does not reset the firmware to an earlier version. It will change all settings back to factory defaults.
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
NetGear WGR614 Wireless Router Logo
51 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
