Question about Carrier Beverage-Air Prestige Plus PR1-1AHS-XDX Stainless steel Commercial Refrigerator
Need door gasket - Carrier Beverage-Air Prestige Plus PR1-1AHS-XDX Stainless steel Commercial Refrigerator
  • Carrier Master
  • 17,129 Answers
Please check this link: Door seals
Posted on Jan 12, 2013
What are the steps to change the rubber that seal each door of the Kenmore Elite fridge? Do I just need to pul it out or I need to take the whole door appart?
The door gaskets are held in place by screws located under the lip of the gasket. The secret is to remove only half the screws on the top of the gasket, remove that half and let it hang. Install the top half of the new gasket, let it hang, then remove the lower half of the old gasket. Finish the lower half of the new gasket. The new gasket will take some time to conform to the door opening. Be patient. (Hint): Fill your kitchen sink with hot water and soak the new gasket for 15 mins or so. It will become pliable and much easier to work with.
Feb 05, 2015 | Kenmore Refrigerators
How to repair a lg dryer dlex3470v
See the groove on the edge where the gasket fits onto the door? As you peel away the gasket, you'll see how you need to thread the gasket onto the door flange so that the gasket will fit properly.
Use a silicone-based spray on lube to help it slide back on. Start at the top & work your way around the edge pressing the gasket groove onto the metal as you go. You might not even need a new gasket unless it is damaged.
Aug 14, 2014 | Dryers
Model# RT18DKXEW05 parts
Repair clinic has booth door gaskets
the refrigerator gasket is $91.60
The freezer door gasket is $72.95
If the unit is working good it might be worth it to replace the gaskets if unit is in good shape and you only need one of the 2 gaskets I would replace it. if needs both you need to see what a replacement unit costs and make a decision
http://www.repairclinic.com/Roper-Refrigerator-Model-RT18DKXEW05-ID-114014-Gasket-Seal-Parts
Jan 29, 2013 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
How do I replace the oven door gasket on my VGIC3686
Replacing a Door Gasket
If the oven won't heat to the desired temperature or heats unevenly, the problem could be a defective door gasket. The best way to test for this is to pass your hand around the door, being careful not to touch it, while the oven is turned on. If you can feel heat escaping, the gasket needs replacement. Replace it with a new gasket made for the range.
On most ovens, the gasket is located on the frame of the oven, and the door closes against it. This gasket is generally friction-fit in a channel and can be replaced. In other units, the oven door has two sections, and the gasket is not mounted on the door frame, but is installed between the front and back sections of the door. Don't try to replace this type of gasket; call a professional service person. Here's how to replace a frame-mounted gasket:
Step 1: Pull the old gasket out of the channel. On some oven door frames the gasket is held in place with screws. To get at the screws, bend back the exposed edge of the gasket.
Step 2: Clean the channel and the door frame with a solution of mild household detergent and water.
Step 3: To install the new gasket, start the replacement at the top of the door frame and work down the sides, easing the gasket around corners. Finish the installation along the bottom, butting the ends of the gasket firmly together.
Apr 16, 2012 | Viking Kitchen Ranges
When washing and water is running water runs out through the front door
If the machine is working alright otherwise , then there is an alignment problem on the door or your seal gasket is worn out. Since this is a mechanical failure it must be inspeccted before we can confirm on the fault. If you find the gasket worn out or the sides cut along, then it needs a replacement. The same type of gasket is available from different sources, try the LG dealer or the appliances hardware shop. If there is any hinge problem on the door remove and adjust. The door must close and seal well. Hope you can sit in front of the door and look carefully to logically confirm and repair. Hope you get this right. Good day
Jul 07, 2010 | LG WM-1832C Front Load Washer
Need instructions on how to replace door gasket of dometic 2310 rv refriterator.
loosen all the screws located in the middle of the old door gasket, remove the old gasket. starting at the top of the door; wedge the new door top gasket corner into one of the gasket frame corners at the door top and, screw it down to secure; because the gasket will not be wide enough; use a hairdryer to gently stretch it to the other top corner and, secure that corner then : using the hairdryer continue to stretch the gasket downward and, fit the rest of the door gasket into both of the remaining bottom corners then: slip the rest of the gasket under the gasket frame and, tighten all the gasket frame brackets.
Jul 15, 2010 | Refrigerators
How does front panel come off (safely) to swap out door switch on kenmore washing machine 41744152400
The front panel does not need to be removed when replacing the door switch. What needs to be removed is the door gasket. Open the washer door. Get a pair of needle nose pliers then look for the retaining hoop securing the door gasket to the lip of the door opening. Stretch the hoop retaining spring at the bottom of the lip of the door opening then carefully pull the hoop out. Make sure not to tear the door gasket or else water will leak through it.
Remove the two screws securing the door switch to the front panel. Peel off the door gasket near the door switch then pull the door switch off the front panel and out of the washer.
Disconnect the wires from the door switch terminals then connect it to the new door switch. Secure the new door switch back to the front panel then put the door gasket back over the lip of the door opening. Properly secure the door gasket to the lip of the door opening with the retaining hoop.
Mar 11, 2010 | Frigidaire ATF6000ES Front Load Washer
Need to reinstall gasket
Unplug the machine and carefully pull the edge of the door gasket near the door opening. Put the lip of the door gasket properly over the lip of the door opening. Check that it is properly seated before putting back on the retaining hoop around the lip of the door opening and the gasket. Replace the retaining hoop if it holds the door gasket loose.
Feel free to update me about the result and if you need further assistance.
Jan 24, 2010 | Maytag MAH8700A Front Load Washer
I needs to replace my refrigator door gasket. I need a manual with pictorial diagram and with details on how to remove and install the gasket.
open door and pull on inside of gasket to expose screws or 1/4 nuts.. loosen[do NOT remove] all screws and pull old gasket out. place new gasket in sink of hot water to soften it and put back around door. snug up a couple of screws on each side and test seal by shutting door..you may need to adjust inner panel until just right..then tighten all screws
Sep 05, 2009 | Refrigerators
Carrier Beverage-Air Prestige Plus PR1-1AHS-XDX Stainless steel Commercial Refrigerator Logo
55 people viewed this question
Top Carrier Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
doggzzz
Level 1 Expert
Are you a Carrier Refrigerator Expert? Answer questions, earn points and help others
