Question about Garden
Engine starts revs and then cuts out .It will only restart if i purge carb again
  • 169 Answers
Carb it clogged up....check out my youtube channel and search for carb rebuild
Posted on Jan 16, 2013
1994 Subaru Legacy 250T engine cuts out
It could many things, please go for a scanner test
Mar 11, 2013 | Cars & Trucks
Briggs & stratton v-twin engine cuts out
acid dip rebuild carb make sure fuel selinoid on bottom of carb moves freely
Sep 07, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Stihl hs45 hard to start when started won't rev and cut's out
Most likely a fueling issue, Check fuel line for air leaks or it could be a carb problem.
Jul 03, 2012 | Stihl Garden
Engine cutting out intermitantly at high revs. Gets worse as engine gewts hotteR. the only coincidental is Ihave just put new rings in and it has started since then. Any Ideas - Andy
Most likely, your main jet nozzle is clogged- causing the engine to starve for fuel at high revs. Remove carb, take the bowl off the bottom and locate the main jet. The main jet is screwed into the main nozzle, which you can't see until it's removed. Remove the nozzle(brass tube with holes down sides that your slide needle goes into) and clean the nozzle and jet thoroughly. Its a good idea to do the rest of the carb the same way while you're at it. Replace the carb. If the carb adjustments haven't been messed with, this should put your little katoom back screaming again.
Jun 10, 2010 | 2002 KTM EXC 200 GS
To keep my engine running i have to pull the throttle obviously to rev it, else it the engine cuts out, and when i ride it splutters and cuts out, so i kick down a gear n it starts again but then dies...
has the bike been sitting for some time? Sounds like a classic case of gummed up low speed jets in the carbs. Pull the carbs and clean then out.
Mar 11, 2010 | 2000 Aprilia RS 125
Cuts out on high revs 240 chain saw
Many saws made today are using electronics for engine control. If the engine rpm's starts to rev to high, the electronics in the coil will start to 'cut out' some of the spark. This is normal in this senerio.
But, now the real problem causing the senerio;
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
5) replace gaskets/diaphragms
b) use a spray carb cleaner to clean jets, holes, and body of carb
Nov 10, 2009 | Husqvarna Chain Saw 20" Bar
Mercedes c 180 engine fault
sounds like a faulty airflow mass meter
Dec 29, 2008 | 1995 Mercedes-Benz C-Class
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
