Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
Samsung HC-P4752W Does Not Turn ON
My two year old Samsung HC-P4752W has stuck in standby mode. It started when it was one month old, it would turn off itself and enter the standby mode where it would remain until it is unplugged from the power line. I reported this problem to the manufacturer who directed me to a local TV repair shop; unfortunately, this local shop did not identify any technical problem and hence it was not fixed. I had to live with this problem for another two months after which it dissappeared itself. For te last one year and a half I had no problem with this TV. Two weeks ago it developed a convergence problem, which I was able to fix myself by changing the STK ICs because its warranty has already expired. However, the old problem of self turning off as I described above restarted. This time it survived for only one day after which, it failed to restart completely. Currently, the TV has remained in the standby mode. Nothing happens when I press the button on the TV set itself, however, if I press the power Key on the remote, the TV responds by turning off thr standby LED. I think I have given sufficent information that to descriobe my problem for the expert to help me solve this problem. I guess the problem is not very serious, however, I strongly need help. I have no confidence in the Local TV repairman because they failed me when I was still under warranty.
  • 3 more comments
  • Anonymous Jul 06, 2007
    I think the system did not respond fairly to Techman when I responded that I needed another solution. I was not disregarding the solution given by Techamn, because I am following it. I only wanted additional information regarding the specifications of the board recomended by Techman. Reading the techmical manual for this TV, I couldn't locate the board with part number BP94-01266A; so I hesitated to order the board out of this concern hoping to get further clarifications from Techman. Is there any alternative partnumber of this board?
    Unfortunately my comments did not get recorded because the system was clogged at that time.
  • Anonymous Jul 07, 2007
    That is where I downloaded the manual I am using; it is in 8 pdf files.
    I pulled out the power PCB for this TV. Its part number is BP41-00070D. Samsungparts.com don't have that board; is it interchangable with board BP94-01266A?
  • Anonymous Jul 11, 2007
    I had trouble getting help from Samsung on the alternative board to BP41-00070D which, according to samsungparts.com, has been dicontinued. I left my e-mail address with Samsung Techsupport to find out for me. After several reminders, today I got an e-mail confirming that PCB number BP41-00070D was replaced by PCB number BP94-01266A. This replacement is exactly what Techman had suggested to me, so I have ordered one and it should arrive in three to four days. I will post the outcome.
  • Anonymous Jul 14, 2007
    Good News, I got a new PCB BP94-01266A although it is labelled a different number, I think PB41-00277D, it took me about 15 to 20 minutes to install it and bingo! The TV is working excellently.
    Thanks Tecman
    President:
  • 3,130 Answers
The proble you have is an intermittant power supply or sweep power supply. Unless you can find a bad connection on the power and deflection board, this could be a very difficult problem to find. I have ran across this problem a couple of times, and after spending countless hours troubleshooting, I replaced the main board and all the problems were taken care of. The board part number is at samsungparts.com and I found the board for you. it is located here: http://www.samsungparts.com/part_detail.asp?catalog%5Fname=Parts+and+Accessories&product%5Fid=BP94%2D01266A&search%5Fmodel=HCP4752W Good Luck
Posted on Jul 05, 2007
  • 1 more comment
  • Larry  Dillon
    Larry Dillon Jul 06, 2007
    I guess you want to fix the set by magic. You will need to locate the defective board and replace it. Sorry but there is no magic fix here. No easy fix.
  • Larry  Dillon
    Larry Dillon Jul 07, 2007
    You really should get the service manual on this set. You can download one here. http://www.servicemanuals.net/results.as...
  • Larry  Dillon
    Larry Dillon Jul 14, 2007
    Good to know you fixed it and save at least a few hundred bucks!
SOURCE:
Tv made a popping noise then turned off model HC-P4752W
Know how to solders?Ur power board is dead,capacitors puff up or burst open,must replaced these capacitors to get power back.Or buy and replaced the whole refurbish power board at Shopjimmy.com,Ebay.com.
Jan 21, 2010 | Samsung HC-P4752W 47" Rear Projection...
I'VE HAD THIS TV FOR 4 1/2 YEARS-THINK IT'S THE BULB-REPLACE?
The HC-P4752W doesnt have a lamp. Thats a rear projection it has three picture tubes.
Oct 10, 2009 | Samsung HC-P4752W 47" Rear Projection...
How do you get into the service menu on Samsung hcp4752w
I dont remember it exactly but ..if your TV is on then Press Standby and then press Info + Enter + Menu + Standby to turn on..you will get the service menu on screen.
Just alter the sequence of info + enter + menu to info + menu + enter or something.
hope it works
regards
bhavin
Apr 06, 2009 | Samsung HC-P4752W 47" Rear Projection...
Samsung rear projection tv
I think it could be a faulty diode on the power supply board. If you can check this for yourself otherwise call out a competant technician. Good luck.
Sep 30, 2008 | Samsung HC-P4752W 47" Rear Projection...
Double vision
My television is a hc-p4752w and the color convergence is way off. The red and green are not together and curl away from the top of the screen and bottom too. I tried to auto focus with only making the color separation worse. The tv is about four years old with lots of play time...
I am a aircraft mechanic with some electronics training so I don't mind replacing components I just don't know where to start and have no troubleshooting manual for help. Any help would be greatly appreciated!!!!
Jun 28, 2008 | Samsung HC-P4752W 47" Rear Projection...
Hc-p4752w will not turn on.
you will need to trouble shoot the power supplies most likely a low voltage regulator isnt functioning.
May 29, 2008 | Samsung HC-P4752W 47" Rear Projection...
2 1/2 years new Samsung HC-P4752W from Costco, Canada
Samsung makes a great product and has one of the best pictures out there. I have had mine for a couple of years and only experience a slight convergience issue on left and right sides of the screen after twenty minutes of run time. I am currently trying to figure out how to fix it.
Jan 26, 2008 | Samsung HC-P4752W 47" Rear Projection...
Sansung HC-P4752w 52 in. Rear Projection
you require a deflection board replacement the board cost around $150/
Aug 02, 2007 | Samsung HC-P4752W 47" Rear Projection...
Samsung HC-P4752W Blurry ONLY on HD Channels
Similar problem, then about 2 weeks later the SD convergence went out. Changes convergence Amps,,, Now I'm trying to learn what 2 red flashes mean now when I try to power it up,,, it flashes twice then shut down into standby mode,,, I got no picture after installing STK392-040 chips, thinking about trying another set as atleast I had blury picture before. No solder shorts of opens that I can find. TV has always been a pain,,, locking up once in a while such that you can't change modes,,,
Jul 22, 2007 | Samsung HC-P4752W 47" Rear Projection...
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
612 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
