Question about Royal Scrittore Manual Typewriter
The ribbon on my Royal Scrittore seems to be too close to the paper bale resulting in the letters smudging and red rubbing off on the paper when typing black letters. Why would this happen. The typewriter is new.
  • Royal Master
  • 3,594 Answers
Most likely the ribbon isn't threaded properly thru the guides.
DickyO
Posted on Jan 16, 2013
  • 92 Answers
SOURCE: My adler-royal typewriter doesn't type the correct
bad logic
Posted on Aug 29, 2009
JUSTOLDJIM
  • 453 Answers
SOURCE: adler royal satellite 40 ribbon drive problem
Try holding the code key down and pressing the (.) period key. It is probably in the mullti strike ribbon mode.
Posted on Oct 19, 2007
  • 3594 Answers
SOURCE: How to load ribbon and rewind ribbon.
The ribbon should reverse itself if it working properly. Just to the indide of each ribbon is a reversing that the ribbon should go thru, Move that arm away from the empty spool and type a few letters it should reverse. DickyO
Posted on Jun 11, 2009
  • 46 Answers
SOURCE: my keys are locled on my royal kmm 1941 typewriter
Margin Release should be near the top of the keyboard on the left or ride side of the keyboard. You may have a sticky margin lock bail or a spring loose or broken on the bail mechanism if the margin release doesn't work. Sometimes the linkage for the bail needs to be adjusted. If you are mechanically inclined, you can possibly follow it through, but if not, seek out a service tech.
Posted on Jun 26, 2009
JayBlair
  • 328 Answers
SOURCE: My typewriter carriage doesn't move along as I type.
Does the carriage move if you depress the tab key or space bar? Is there any pull on the draw band. Maybe the main spring is broken.
Posted on Sep 18, 2009
Can't remove old ribbon to replace
Some have latches under on both sides, other the top just pulled up.
Apr 20, 2014 | Royal Scrittore Manual Typewriter
Ribbon Smudge
The only thing I can think of is the ribbon is not threaded properly. (ex. in front of carrier instead of behind or vice versa)
Jan 29, 2014 | Sharp EL-1801P Calculator
Ribbon will not move up so key can strike it
You may be in stencil mode. There is usually a lever that you move to red, black or white.
DickyO
Apr 28, 2012 | Royal Scrittore Manual Typewriter
I have a xerox workcentre XL2130. It had a bad paper jam. I cleared it - now it has an error code E4. I've turned it off and on - hit the clear button - nothing is clearing it? Help! Thanks, Stacia
YOU STILL HAVE A PROBLEM IN THE PAPER PATH...
DOWNLOAD THE USER MANUAL
Clearing the Paper Path
- E-1, E-2, E-3, E-4, E-5
When a paper misfeed occurs the red misfeed indicator flashes
on the WorkCentre diagram, and an E status code will flash in
the Display Window. Paper misfeeds may occur in the areas
shown below. Follow the steps below to locate and clear the
misfeed.
Note: Ensure that the alternate paper tray is lowered
(XL2140df only).
Caution: Do not touch the shiny drum cartridge surface.
Scratches or smudges will result in poor copy quality.
Do not remove paper through the bypass. Unfused toner may
adhere in the area, resulting in smudged copies.
E-1
Steps 1-2 for XL2140df only
1. Lower the right Side Tray 2 Access Door.
2. Remove the misfed paper.
3. Close the Access Door.
If paper cannot be removed, open drawer (2) clear misfed paper.
4. Close the Side Cover.
E-2
1. Press the Release Latch to open the Side Cover.
Exit Area
Paper Feed Area
Fuser Area
Side Cover
35
- E-1, E-2, E-3, E-4, E-5 (continued)
Caution: Do not touch the shiny Drum Cartridge surface.
2. Carefully remove the misfed paper in the direction shown.
If paper cannot be reached, open the paper trays and remove
misfed paper.
E-3
Fuser Area
Warning: The fuser area is hot. Take care when removing
paper from the fuser area.
Note: Ensure that the Alternate Paper Tray is lowered
(XL2140df only).
1. Press the Release Lever to open the Side Cover.
2. Pull down on the fuser lever.
• This will release pressure on the paper.
Caution: Do not pull paper up through the fusing unit. Unfused toner
may adhere in the area, resulting in smudged copies.
3. Remove the sheet of paper in the direction shown.
E-4 and E-5 (2-sided Reverse Copy XL2140df only)
Exit Area
1. Pull down on the fuser lever.
2. Gently pull the paper out through the exit area.
36
3. If not accessible, turn the knob in the direction of the arrow
to move the paper to the exit area.
4. Gently pull the paper out through the exit area.
Feb 12, 2011 | Xerox WorkCentre XL2130f Laser Printer
Black ribbon is not back feeding same amount/speed as label, leaving black smudge at beginning of label
This is due to the quality of the ribbon.
When the paper moves back, since the head is not raised, the paper rubs on the ribbon en is the cause of the black smudge. Use correct Ribbon
Jan 08, 2011 | Toshiba TEC BSX5 Thermal Label Printer
Too much toner on paper which then smudges
Try reducing the print resolution using the menu buttons. Does it smudge with coloured prints? If so then the fuser unit is faulty. If it is only black that smudges it is likely to be the K Developer unit. Ensure that you are using genuine toners, not refills or third party as the quality of toner can cause similar results.
Jan 14, 2009 | Epson Aculaser C1100 Printer
Letters do not form on paper
Seems like the ribbon may be cought in the printwheel of in front of it. Release the printwheel, make sure nothing is caught, and resnap it closed. Make sure the prinwheel rotates when it is first turned on or the proper character will not be struck.
Jan 05, 2008 | Office Equipment & Supplies
Royal Scrittore Manual Typewriter Logo
87 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
