Question about Frigidaire FGF378AC Gas Kitchen Range
FGFL79GSA leaking gas
Leaking gas after broiling; local appliance tech found leaky gas valve in oven. 5 yrs old. common problem?
4 Suggested Answers
marka19
  • 1430 Answers
SOURCE: Gas oven will not heat up when turned on. No gas
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Posted on Dec 07, 2010
heatman101
  • 43501 Answers
SOURCE: frigidaire oven. broil/bake stop
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Posted on Dec 21, 2010
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: Leaking intake valve on frigidaire ultraquiet III, model: FDB750RCC1
    Hello Dan Wetmore - Do you notice if the dishwasher have deflectors installed in the bottom left and right corners of the tub gasket channel? If so, confirmed that they are properly installed and present. In case that it is not, they may possibly need replacing. However, keep in mind that the springs or hinges may possibly be damaged, gasket not sealing properly or the leak could possibly be coming from the drain motor/pump (which would be more cost effective to repair). I would strongly suggest contacting a professional to move forward accurately.
    Posted on Dec 14, 2012
    Magic Chef cgr3765adc, oven will not turn off. If the unit is plugged in the oven ignites and would continue heating unless disconnected from electricity.
    follow this test and fix it. God bless you
    Bake Element
    If the oven won't turn on, check the bake element. The bake element is a black tube near the bottom of the oven about as thick as a pencil. When it is operating normally, the bake element will glow red hot. If the oven won't turn on the bake element may have burned out. It is often obvious to see where the bake element has shorted out because there will be a hole or break in the element. If the bake element has burnt out or shorted it should be replaced.
    Oven Igniter
    Even though the oven igniter may be glowing, it may be too weak to allow the gas valve to open. If the oven won't turn on and the oven igniter glows for more than 90 seconds without igniting the gas flame, the oven igniter should be replaced. This is the most common part that fails when the oven won't turn on.
    Broil Element
    If the oven won't turn on, check the broil element. The broil element is a black tube near the top of the oven about as thick as a pencil. When it is operating normally, the broil element will glow red hot. If the oven won't turn on the broil element may have burned out and caused something else to short out. It is often obvious to see where the broil element has burned out because there will be a hole in the element or blisters on the outside of the element. Test the broil element using an Ohm meter. If it has continuity it's OK. If not, it should be replaced.
    Incoming Power Problem
    Although not as common, if the oven won't turn on it is possible that the appliance is not receiving proper voltage. Electric ovens require 220 volts of alternating current. If for some reason the appliance is receiving significantly less, the oven won't turn on. Check for proper voltage using a volt meter at the socket where the appliance plugs in.
    Oven Control Board
    The oven control board has a set of relays that turn on and off power to the bake and broil circuits according to the customer settings and sensor input. If the oven won't turn on the problem is usually with the heating components. However, if the oven control board is bad, it might not send voltage to the heating components. To determine why the oven won't turn on, first test the simpler components in the circuit. The oven control board usually can't be tested and will have to be replaced if it is defective.
    Thermal Fuse
    Although not as common, if the oven won't turn on the thermal fuse may have blown. The thermal fuse is designed to protect the appliance and help to prevent a fire. If the oven gets too hot, this fuse trips. The thermal fuse is not resettable and will have to be replaced. It can be checked for continuity. If it has continuity, it's OK. Not all ovens have a thermal fuse.
    Relay Board
    If the oven won't turn on and the appliance is equipped with an oven relay board, one of the relays on the board may have failed. Normally the oven relays are located on the main clock control board and not on a separate oven relay board. If the oven won't turn on it is more likely that the cause is one of the more common problems listed for the model. If the other, more common problems have been checked and Your oven has a relay board, it may need to be replaced. Oven relay boards are not repairable.
    Oven Thermostat
    If the oven won't turn on, the oven thermostat might be defective. Although this is not as common as other components, the oven thermostat sometimes fails completely and does not allow current to pass through. After checking other, more common components, consider replacing the oven thermostat.
    Heat Selector Switch
    If the oven won't turn on, be sure the heat selector switch is set to the right position. The heat selector switch completes the circuit to either send voltage to the bake or broil circuit. If the oven won't turn on, the heat selector switch might also be defective, although this is not very common. The heat selector switch is not repairable, if it is defective it will need to be replaced.
    Oven Safety Valve
    The oven safety valve works with the oven igniter to provide gas to the burner. If the oven won't turn on it is possible that the oven safety valve is defective. However, this is very rare. Most often, the oven igniter is too weak to allow the oven safety valve to open. If the oven won't turn on, check the igniter first.
    Oven Valve and Pressure Regulator
    If the gas oven won't turn on the oven valve and pressure regulator might be at fault. This is not common. Very often people misdiagnose a defective oven valve and pressure regulator when the oven won't turn on However, this is almost never the cause. Look at other, more common components before replacing these.
    Nov 04, 2013 | Magic Chef Kitchen Ranges
    I have kenmore gas oven ignitor glows but will not light
    Hello there:
    It doesn't bake dot_lineone.gif Bake igniter
    When the bake igniter becomes weak or burns out, your oven would not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
    If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
    A faulty igniter is probably the most common cause, however there are others:
    -- defective thermostat
    -- defective selector switch
    -- defective gas safety valve
    If you are certain the igniter is ok, it might be a good idea to call a professional appliance technician.
    Need a new oven igniter? Click here for most common oven igniters or enter your oven model number in our PART SEARCH. ^ top clear.gif It doesn't broil dot_lineone.gif Broil igniter
    When the broil igniter becomes weak or burns out, your oven would not broil. The broil igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
    If the broil igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
    Read more: http://www.appliancepartspros.com/repairtips/repairtips_range_oven.aspx#ixzz1CgFQ7lBJ
    Feb 01, 2011 | Kenmore 33169 Gas Single Oven
    Small gas leak smelled inside house from GE Adora (just 2 yrs old). Have moved stove and have put soapy water with paint brush on every connection including regulator...don't see any leak evidence...any...
    You may have to use dish soap straight, do not use the brush. I use an old spray bottle and dish soap straight, not watered down, to find my leaks. Gas is a very low psi. Soapy water will not bubble up. It can and will just be pushed out of the way. Do not forget any other gas appliances in the house, hot water heater, stove, any thing that uses gas. Please check all. Recheck your stove and even any connections inside, on/off valve etc. Hope this helps Fixya up.
    Dec 13, 2010 | Microwave Ovens
    Kitchenaid gas oven very slow to start - can be 5 - 10 minutes before I hear it kick on. For a while I could get it to start by turning on a gas burner, but that is 100% effective. Any suggestions? Also...
    Replace your ignitor, this is a very common problem. As the ignitor gets older, it gets weaker. When it gets weaker, it usually starts out by not giving good temps in the oven, then it starts to take longer and longer before it lights the oven burner, then it stops lighting the burner completely. A good ignitor heats up fast, allows the current to flow through to the gas valve, opens the gas valve and lights the oven burner within 30 to 50 seconds. When you order your ignitor ask if their is a cheaper generic ignitor for this model. Their can be a huge price difference in some units. You can also have a bad sensor, control board, gas valve, or wiring problem, however for the last 15 or so years every job I have done with your problem has been an ignitor. Good Luck, Appliance Specialists
    Jan 26, 2010 | KitchenAid KESC307 Electric Kitchen Range
    Stoves 900GRa spark ignition
    i have a 900g stoves oven how do you change from auto to manual
    Nov 02, 2008 | Stoves Premier 900GRa Gas Double Oven
    Where do I light my gas oven?
    Hello Slacker3158 how old is this oven? I only ask as GE hasn't built a standing Pilot range in over 18 yrs. The issue may be a bad oven ignitor. Put the oven on broil, if it works then the bake ignitor is bad. It is found under the bottom of the oven. There is 2 to 4 screws inside the oven that allows the bottom to be removed.
    Feb 03, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
    Oven not working
    Check continuity on gas valve. the middle connector is common, upper is broil and bottom is bake. Resistance between common and bake should be about the same as between common and broil. I believe you'll need to set the ohmmeter to KOhms (or x1000.
    If no continuity between any of the connectors - replace gas valve (not much fun, and part is expensive).
    Jan 21, 2008 | KitchenAid KGRC707 Gas Kitchen Range
    Frigidaire gas range
    You could have a gas leak on one of the connections or a leaking safety valve. Mix some dishsoap, (dawn, etc) with water, 50/50. Soak the connections and fittings on the incoming line to the range. If You get bubbles you found the leak. Next find the orfice for the bake burner, take out the drawer and you should see the tube in the center. It will have an opening in the bottom where the orfice goes in. The orfice is brass, spray some soap bubbles on the brass orfice and see if it bubbles, if it does you need a new safety valve. Still no bubbles open the oven and look on the back wall of the cavity for the broil orfice ( if it has a broil burner). Hope that helps
    Jan 04, 2008 | Frigidaire FGF316 Gas Kitchen Range
    Faulty bake or broil element
    The solution to this problem depends on whether the oven is electric or gas. Electric oven. If your electric oven's bake or broil element isn't working properly, either it isn't receiving electric power or the element or the oven control may need to be replaced. In many cases, the wiring to the elements can be burnt or broken. 1) Be sure the controls are set on the proper setting. 2) Be sure the stove is plugged in and/or check the circuit breaker or fuse that serves that circuit. 3) Call an appliance repairperson or replace the element yourself as follows. 4) Unplug the oven and let any hot parts cool. 5) Unscrew the mounting screws that secure the element bracket to the oven and pull out the element far enough to access its terminals. Note which wires are attached to each of the terminals, then disconnect the wires (pull off the wire clips or unscrew the wires). 6) Take the element to a parts dealer, along with your oven's model and serial number, and buy a replacement (preferably the manufacturer's suggested replacement part). 7) Reverse the process to reinstall. Gas oven. When a gas oven doesn't get hot, it generally means that it isn't receiving gas, the gas valve isn't distributing gas to the oven burner, or the ignition system -- either an electronic ignition or pilot light -- isn't working properly. A common problem with ovens that have a pilot light is that the pilot light has gone out. NOTE: Gas ranges younger than 10 years old have a sophisticated fault code system that governs their ignition. Always call an approved warranty service provider to handle problems with these ranges. Here's how to troubleshoot your range: 1) Be sure the controls are set on the proper setting. 2) Be sure the stove is plugged in and/or check the circuit breaker or fuse that serves that circuit. 3) Check the gas valve to be sure the gas supply is turned on (also make sure the house's main gas valve is turned on). 4) On a stove with a pilot light, make sure the pilot light is burning. If it isn't, re-light as discussed HERE, or in your owner's manual. 5) Adjust the pilot flame (older stoves only). 6) Turn off the gas and unplug the stove (or turn off its circuit at the electrical panel). 7) Clean out the oven burner ports, using a stiff wire. 8) Plug in the stove (or turn on its circuit) and turn the gas back on. Re-light the pilot (if it has one). 9) If the oven still doesn't work, call an appliance repairperson.
    Jan 18, 2006 | Jenn-Air JJW8530C Expressions Collection...
    Open Questions:
    See all Frigidaire FGF378AC Gas Kitchen Range Questions
    Frigidaire FGF378AC Gas Kitchen Range Logo
    56 people viewed this question
    Top Frigidaire Kitchen Ranges Experts
    Ismael Rodriguez...
    Paul Carew
    Justin Duby
    Justin Duby
    Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
