Question about Averatec Computers & Internet
Keyboard Issues/Errors I am having keyboard issues on my Averatec 5400; When I type certain letters/numbers {c, f, j, l, n, x, z, 9} they are immediately followed by the period symbol; and the o is replaced by a . completely. Also, pressing the left arrow key results in a series of periods... I have tried several of the suggestions found here to no avail {Fn & Num Lock; Fn & PrtScr; Fn & Pause}.... Any other suggestions would be greatly appreciated...
  • gruvigrl_1 Jan 22, 2009
    It is set to the English (USA) setting; should have mentioned I'd tried that....
    Also, as mentioned in my original post, I tried the Fn & Nam Lock and the same time and nothing changed....
    As for the stuck idea, it is a personal laptop used only at home... No office supplies get that close to it... Even if something were hypothetically stuck, the o and the . aren't adjacent and shouldn't trigger each other... the . is only showing up after certain letters/numbers/actions... I have popped the . off and there is nothing under that particular key...
    I have also uninstalled and reinstalled the keyboard driver just in case.... It was working fine until my daughter used it and pressed a few buttons as she tried to get up with it on her lap... She has no idea what was pressed, so I am certain it's not a hardware issue...
    Problem Solver:
  • 9 Answers
I would gather that your keyboard has been changed somehow to another country keyboard. Please check in your control panel, keyboard and see if eng usa is selected.
The other suggestion is pressing and holding fn key, num lock key at the same time. You should see a light going off and on when you do this on your system.
If keyboard selected is english, and num lock is off, I would turn your keyboard upside down and give it a good shake. Sometimes a paperclip, or staple gets underneath the keys.
Posted on Jan 22, 2009
Keyboard incorrectly types a mixture of letters and numbers when certain keys are used.
There are a couple of things you could try:
1. Remove the keyboard following a service manual for your laptop, and reseat the ribbon cable underneath it.
2. If the problem still isn't solved, the keyboard should be replaced
Feb 03, 2013 | Computers & Internet
Lenovo laptop in certain programs only types numbers in numeric order
What model and ram is your pc???
what programs have issues... names??
what is your os??
Jan 10, 2013 | Lenovo G550 29582DU PC Notebook
Keyboard issues
Press the "Number lock" key.
Apr 16, 2010 | Acer Aspire 5500 5570-2609 Laptop
Typing errors when using keyboard. letters missing when typing
these are the basic reasons for this problem
  • if you are using the Wireless Keyboard, then try to change the Batteries. Many times when the Batteries get weak this type of keyboard issues while typing occurs. So try to insert new batteries and check whether the problem is recurring. If it is coming again then it is the Hardware fault.
  • This can also happen because of the Virus. There are some virus or spyware that are the causes of this issue. So I would like to suggest you to scan your system using the updated Anti Virus. Once the Virus gets removed that are causing this issue than problem will get fixed up. Don't forget that your Anti Virus should me latest with proper updates. Simple way to check that your Keyboard is working properly, by connecting to some other system. If the same problem is coming that means there is an Keyboard issue and you will have to change the keyboard. And if your keyboard is working properly on another system that means there is fault in your system. Then try to scan your machine with the Anti Virus. Doing this will exactly know you what was the issue and you can troubleshoot that.
  • if PS2 port was having some issue, that was lead to missed and repeated letters on the keyboard. Hope that you are not having any PS2 issues because then you will have to fix your motherboard.
first you had to identify the cause in your pc by connecting it to other systems and then proceed to fix the cause
REGUARDS
Feb 08, 2010 | Acer Computers & Internet
Hp pavilion dv1000 laptop pc keyboard not working properly.
Does this computer KB work alright in SAFE mode? If it does then drivers and/or viruses are the problem. If it doesn't work in SAFE mode then it could be drivers and or keyboard. Now try booting into BIOS. At the date prompt you usually can type any keyboard letter. If the keyboard works here, then you definately have driver/virus issues. If not replace the keyboard.
Mar 12, 2009 | HP Pavilion dv1000 Notebook
Laptop keyboard issues
Is this a laptop? Some laptops will allow you to use these keys as the number pad/arrow pad as well in a certain mode. You will likely be able to turn off with a combination of the FN key plus one of keys F1-F12 (the function key will perform the action shown as a symbol on these keys).
If none of the symbols seems to indicate this mode. Try each combination and test to see which combination sets your keyboard mode back to normal.
Jan 05, 2009 | Dell Spacesaver USB Keyboard J4624 SK-8115...
TYPING ERRORS
Did you check driver issues?
Oct 17, 2008 | Logitech 967437-0403 Keyboard
Jumbled numbers and text
Look for the numlock light somewhere near the keyboard. It's the light with a drawing of a lock with a 9.
If it's lit up. turn it off by pressing the numlock key.
Turning it back on will activate the number keypad (consists of 9-11 keys in the middle of the keyboard). So instead of getting letters, numbers appear.
Hope this is your case. Kindly rate me if the issue got fixed.
Oct 03, 2008 | Computers & Internet
Keyboard problems
yes in some issues i have encountered the ribbon that plugs the keyboard in may be corrupted or you may have a bad keyboard
Aug 10, 2008 | Samsung P10 C XTC 2000 Notebook
Computers & Internet Logo
260 people viewed this question
Top Averatec Computers & Internet Experts
Avishek Samaddar
Avishek Samaddar
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
