JVC 32" LCD TV SMPS high pitch buzzing noise
The TV works fine, it switches ON fine and everything works fine, just whenever its switches ON it gives high pitch buzzing noise, this is random and does not always happen but it does most of the time. The SMPS is Vestel 17PW15-9. I have the schematic as well for this SMPS. I have another SMPS 17PW15-8 which is fine and quite similar to 17PW15-9 with just a little bit of difference. So I took most of the parts, including transformers, exchanged it into 17pw15-9 but it still is making that noise. This noise comes even if no other connections are done on the SMPS. I tried changing (exchaning) following parts, few capacitors, 1 optocoupler, 2 transformers. What else can I do?
bigg t
  • 640 Answers
SOURCE: Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Posted on Feb 24, 2008
aborcass
  • 2651 Answers
debris caught iside pump assy is what it sounds like
  • 700 Answers
SOURCE: TV making high pitch noise, stop working.
It must be the horizontal output transistor, it maybe short circuited. A short in flyback.
Posted on Apr 03, 2009
  • 192 Answers
SOURCE: High pitch noise coming from the tv.
I suspect you have a bad set of capacitors in the control module. This problem usually starts out as a high pitched noise but can lead to the TV not turning on. Please see the link below, posted by StivO. It gives step by step instructions on how to replace the capacitors. This is a very inexpensive fix.
http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen
Posted on Apr 26, 2009
  • 159 Answers
SOURCE: when my rca 36F530 tv is plugged in it makes a high pitched buzzing noise picture does not come on
There is a short circuit in the high voltage circuit. the transformer who helps to create the high voltage or his power transistor is damage. replacement needed. the repair is not expensive, because the parts are average repair. Ask for an estimate.
Posted on May 02, 2009
Tv just started making a very high pitched noise, although picture and sound are fine?
Barb, noise may be from a power supply/ transformer on it's way out.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
HELP what is that high pitched noise when tv is on
Is your LCD making buzzing or high pitch noise
Mar 04, 2016 | Sanyo Dp55441 TV
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
Hi I have a very annoying, ear piercing high frequency pitch coming from what seems to be the television. However, I was trouble shooting and based on the cable technicians thought; said to be the...
Hello
The LOT [Line Output Transformer] of your TV has damaged. It is the one, that supply all the voltaged needed to CRT. Its internal windings will get shorted in between, and is irreparable. Replacement is the only remedy to this proble. Replace the horizontal output transistor also with this. you haven't specified whether there is picture with your tV or not. If this high frequency sound is along with picture, there is some loose in the cores of the SMPS transformer, or LOT itsef. If there is no picture at all, and this high frequency sound is there, no doubt; LOT is damaged. OK.
May 22, 2011 | JVC TM-2703SU 27" TV
High pitch sound after the TV warms up on my JVC 32" TV
    According to the symptom the problem is in memory IC also called EPROM, Replace the EPROM with data and your TV work fine again.
    Thanks.
Jan 09, 2010 | JVC AV-32D305 32" TV
Loud buzzing noise on vizio tv
It sound like you may have sound processor problem which is part of the main board, I would also look at the 12vdc from power supply to make sure it is clean DC.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=l37hdtv10a
http://en.wikipedia.org/wiki/Capacitor_plague
Dec 22, 2009 | Vizio L37 Television
Y rca 27f500tdv tv high pitched noise
Change the horizontal IC are damaged
Jul 28, 2009 | Televison & Video
No picture, sound works, but along with high-pitched noise
My guess is that you might have the yellow (video) cable plugged into an audio input on the TV. Make sure that the yellow cable is plugged into both the video out on the DVD player and the video in on the TV. Most of these connections are color coded.
As a diagnosis, try changing the TV input (using the remote) and let me know if you still get the buzzing on the other inputs. If no, then, it's most likely your RCA connections. If yes, it's another problem.
Apr 21, 2009 | ViewSonic N3252WS 32 in. LCD TV
Weird noise over everything
According to the Samsung website: "The high pitched sound you hear is probably coming from the flyback transformer. The flyback transformer converts the relatively low voltage electricity that comes from the outlet in your home to the high voltage electricity needed to drive the cathode ray tube in your TV. It is not unusual for a flyback transformer to buzz softly when it operates. However, if the sound is loud and high pitched, it probably means the transformer is failing. To eliminate the sound, you will have to get your TV serviced."
Nov 08, 2007 | Samsung SlimFit TX-S2783 TV
High pitched noise
There is a singing coil in the power supply. This set uses whats called a Switch Mode Power Supply(SMPS) and as the picture changes, so does the amount of current the TV draws. Thats why the sound changes with the picture. This could be an indication that a part is going to fail soon or it is just a loose coil winding or a transformer winding. You should have the set checked out by a pro to be sure. Good Luck
Mar 22, 2007 | JVC HD-52G786 52" Rear Projection HDTV
Televison & Video Logo
81 people viewed this question
Top Televison & Video Experts
Electro Med Services...
