Question about Radio Shack RadioShack Professional Weather Station
Back light on RadioShack professional weather station 63 256 not working
Why can't I receive input from the outside sending unit?
Make sure that all the batteries are good!!
This procedure outlines the typical process to pair the sensor and base.
Base Station Battery Installation
·Remove the printed vinyl label from the LCD screen of the base station
·Position the remote sensor near the base station
·Open the battery compartment at the back of the base station and insert (2) AA batteries according to the polarity markings. Replace the battery compartment cover.
·Within a short time the RF signal icon (located to the left of the outdoor temperature channel indicator) will start flashing. This indicates that the base station is ready to pick up the RF outdoor temperature signal from the remote sensor. It will continue to flash for 3 minutes or until the signal from the remote sensor is detected.
Register the Remote Sensor
·Open the battery compartment at the back of the remote sensor and slide the channel selector switch to your desired channel. For the first remote you may select any channel, for additional remotes select any unused channel
·Insert (2) AAA batteries according to the polarity markings. Be sure to install the batteries in the remote within the time that the RF signal icon is flashing on the base station. 1541 WeatherGuide Wireless Weather Forecaster with Barometer
Jan 07, 2016 | Measuring Tools & Sensors
The time zone is set to Pacific. I need to change to Mountain? Can this be done manually?
You should be able to change time zones manually. It would be helpful to have the manual handy to refer to the exact procedure.
Nov 10, 2015 | Honeywell Te923w Professional Wireless...
HOW DO I GET INSTRUCTION MANUAL FOR NEXA WEATHER STATION
NEXA KL4883 Wireless In Out Weather Station Barometer RadioShack com Didn't you get a User's Guide with it? Did you even do a search first before coming here? Did you think about going to their website? I did and found the User's Guide and it took 15 seconds.
Mar 02, 2015 | NEXA Weather Station Radio with In/Out...
I'm looking for operating instructions for a Professional Wireless Weather Station with Outdoor Sensors WH5302
Go on e-Bay, look up weather stations, and send a note to tech support via e-mail to Raul. He seems to care about issues with the DR Tech weather station (I've had many, issues and weather stations!). Rick
Apr 30, 2014 | Measuring Tools & Sensors
I have high temperature of 101.9 I'm not home what do you recommend
take some rest and when you feel sick, call or visit a doctor.
Mar 09, 2014 | Radio Shack RadioShack Professional...
How do you replace the batteries in model 63-1090? I can't get the back cover off.
Below is a copy of the owners manual for the device you are inquiring about. This will show you how to replace the batteries.
http://support.radioshack.com/manuals/ome63-1090.pdf
May 31, 2011 | Radio Shack IndoorOutdoor Thermometer with...
Radio Shack RadioShack Professional Weather Station Logo
69 people viewed this question
Top Radio Shack Measuring Tools & Sensors Experts
 steve
steve
Are you a Radio Shack Measuring Tool and Sensor Expert? Answer questions, earn points and help others
