Question about Cuisinart CBK-200 Bread Maker
The menu button is staying on 4. I can't choose another number
I have unplugged, cleared display pressed menu over and over and it'll only display 4
    Sergeant:
  • 475 Answers
Call or e-mail the company or the manufactor and see what they say.
Posted on Jan 11, 2013
How to Clear the "Unable to Print" Brother DCP 7055 Printer Display
Reset Methods for Brother Printers
  1. Disconnect Brother Printer from power cord.
  2. Press Set button and while holding the Set button re-connect the printer to the power cord (electric source).
  3. It will display an error message "Machine Error 46? on the LCD
  4. After the Error code appear, press the "arrow up button" ( ^ ) there will be numbers that are going to be display.
  5. Choose 8 then press Set Button
  6. Press Arrow Up button again then choose Zero (0) and press Set Button Again, now you will enter Service Mode.
  7. Press "Mono Key/Button" 25 times or until "Purge Counter Appear"
  8. Now press arrow up (^) again then choose "2" press Set Button
  9. Press Arrow Up (^) again then choose "7" press Set Button
  10. Press Arrow Up (^) again then choose "8" press Set Button
  11. Press Arrow Up (^) again then choose "3" press Set Button
  12. The purge counter will be reset to Zero.
  13. Now Press Stop/Exit Button
  14. The printer will return to "Machine Error 46? again
  15. Press Arrow Up (^) then choose 9 press Set Button
  16. Press Arrow Up (^) again then once more choose 9 press Set Button
  17. The Printer will reset then wait until it power up again.
Mar 06, 2015 | Brother Office Equipment & Supplies
Screen stays black after boot up
Use Recovery Console:
When a Windows XP boot problem is severe, you'll need to usea more drastic approach. The Windows XP CD is bootable and will provide youwith access to a tool called Recovery Console.
To boot from the Windows XP CD, insert it into the CD-ROMdrive on the problem system and press [Ctrl][Alt][Delete] to reboot thecomputer. Once the system begins booting from the CD, simply follow the promptsthat will allow the loading of the basic files needed to run Setup. When yousee the Welcome To Setup screen, press R to start the Recovery Console.
You'll then see a Recovery Console menu. It displays the foldercontaining the operating system's files and prompts you to choose the operatingsystem you want to log on to. Just press the menu number on the keyboard, andyou'll be prompted to enter the Administrator's password. You'll then findyourself at the main Recovery Console prompt.
Use system utility software like RegInOut after restarting windows.
Jan 01, 2012 | ASUS Eee PC 1005HA-PU1X-BK Netbook
My washing machine is beeping and showing the key light and not turning on. The door opens though but it seems to be saying its locked!? It doesn't show the cycle time either. How can i get it to go...
Hello, welcome to FixYa.
I'll start by saying your post indicates it is a Bosch, but you didn't specify the model number. It sounds like the "child lock" selection has been activated, either intentional or accidental.
To reset it on many Bosch it is as follows...(if this fails, please provide your model number)
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program.
**Many times you can also push and hold the start key for several seconds and this too will deactivate the selection...on various models**
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly and a short testimony is also appreciated.
Thank you for choosing FixYa. I'll need to watch for your reply if that doesn't work or before moving forward.
Regards,
Macmarkus :)
Aug 16, 2011 | Bosch Washing Machines
Hi, There's a key symbol in the display and it beeps, won't allow you to start a cycle. Regards, BG
I'll start by saying your post indicates it is a Bosch, however if you could post the complete model number I can speak directly about possible remedies instead of generalizing.
I can tell you it means "child lock" has been activated. To reset it on many Bosch it is as follows...
Regards,
Macmarkus :)
May 04, 2011 | Bosch Washing Machines
Printer maintenance
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp190#ServiceAndSupport
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press the <ON> button. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON button does not shut off the printer.
  2. Wait approximately ten seconds and then press the <ON> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
    Note: It may be necessary to unplug the power cord and retry if the above steps do not clear the error.
(This is for 2,113,0 error not 2,114,0 error which isn't listed.)
Aug 03, 2010 | Canon PIXMA MP190 All-In-One InkJet...
How do you set the speed dial phone numbers on the Clarity D613 amplified cordless DECT
Clarity D613 Cordless Telephone
SPEED DIAL INSTRUCTIONS
To set, replace, or delete one of the nine Speed Dial numbers:
1. If you want to set or replace one of the Speed Dial numbers, and the new number is not already an entry in the phonebook, add the new phonebook entry before continuing here.
2. Press the PHONEBOOK button. The first entry in the phonebook displays.
3. Press the MENU button. The first two items (VIEW and ADD) of the seven-item PHONEBOOK menu display.
4. Press the UP/DOWN buttons (right side of the handset) to scroll to SPEED DIAL.
5. Press the MENU button. The first two items (KEY 1 and KEY 2) of the nine-item SPEED DIAL menu display.
6. The SPEED DIAL menu is displayed. If you do not want to make any (more) Speed Dial changes, press the BACK button until the HANDSET number displays, and stop following these instructions.
7. Press the UP/DOWN buttons to scroll to the KEY number that you want to set, replace, or delete; for example, KEY 4.
8. Press the MENU button. A phonebook entry appears. It is either the entry, if any, that is currently associated with the selected key or it is the first entry in the phonebook.
9. Press the UP/DOWN buttons to try to scroll to a different entry in the phonebook.
10. If you are able to scroll through the phonebook, the selected key is not currently associated with any phonebook entry and you have two options:
a. To leave the selected key without an association, press the BACK button and return to step 6.
b. To associate the selected key with a phonebook entry, go to step 16.
11. The displayed phonebook entry is currently associated with the selected key. If you want to leave it that way, press the BACK button and return to step 6.
12. Press the MENU button. A menu displays with two items (ADD and DELETE). By default, the ADD item is initially selected.
13. If you want to associate a different phonebook entry with the selected key, press the MENU button (to choose ADD). The first entry in the phonebook displays. Go to step 16.
14. Press the UP/DOWN buttons to scroll to DELETE.
15. Press the MENU button. DELETED displays. The selected key is now not associated with any phonebook entry. Return to step 6.
16. Press the UP/DOWN buttons to scroll to the phonebook entry that you want to associate with the selected key.
17. Press the MENU button. SAVED displays. The selected key is now associated with the selected phonebook entry. Return to step 6.
To call one of the nine Speed Dial numbers:
1. Press and hold the desired Speed Dial key (1 through 9 on the dial pad). The selected key number displays. If the key is associated with a phonebook entry, the call begins within a few seconds. Otherwise the phone beeps twice.
2. Release the key. If the key was not associated with a phonebook entry, you can either press the BACK key to return the phone to standby, or you can press the CLEAR key and then press a different Speed Dial key..
To review the phonebook entries that are associated with the Speed Dial keys:
1. Press the PHONEBOOK button. The first entry in the phonebook displays.
2. Press the MENU button. The first two items (VIEW and ADD) of the seven-item PHONEBOOK menu display.
3. Press the UP/DOWN buttons to scroll to SPEED DIAL.
4. Press the MENU button. The first two items (KEY 1 and KEY 2) of the nine-item SPEED DIAL menu display.
5. Press the UP/DOWN buttons to scroll to the KEY number that you want to review; for example, KEY 4.
6. Press the MENU button. The associated phonebook entry appears.
7. Press the BACK button.
8. If you want to review more Speed Dial associations, return to step 5.
9. Press the BACK button until the HANDSET number displays.
Dec 27, 2009 | Clarity Lands Phones
I have a Digital Voice Recorder DS-2....how do I erase an item???
Press the FOLDER button to choose a folder. Press the FF or REW button to
choose the file you want to erase. Press the ERASE button. CANCEL” is flashing.Press the down arrow button to choose the
START”.
START” is flashing. When the up arrow button
is pressed, it will return to the flashing display of Cancel.
Press the MENU/SET button
while “START” flashing.
The display changes to “FILE ERASE!” and erasing will start.
“ERASE DONE” is displayed when the file
is erased. File numbers will be reassigned automatically.
Apr 01, 2009 | Olympus Audio Players & Recorders
What does perform service mean on my 2003 town and country
The "Perform Service" Is supposed to alert you that you are due for an oil change, it will light up every 6000 miles. If you get your Oil Changed at a Dealer, they will clear it for you, otherwise you can clear it manually by:
Press the "MENU" button until Service Interval is displayed
- With this feature selected, choose an interval between two and six thousand miles using the "STEP" button (Note: make sure you choose something different than the current setting)
- Press the "MENU" button again, you will then see Reset Service Distance
- Press the "STEP" button so that "Y" is displayed
- Press the "MENU" button enough times to bring you back out of the menu mode
Jan 03, 2009 | 2003 Chrysler Town & Country
Brother fax 560
Try this: Press MENU, select FAX, then scroll down to REMAINING JOBS. If any jobs are displayed , you can choose to print them. To print from the fax memory, first exit out of the MENU functions totally. Then, press MENU,2,5,4. Next, press START. After all faxes in memory have printed, press STOP/EXIT button. Check REMAINING JOBS again, if it is clear, fax memory should be clear, Also.If the fax machine has a PRINTER function, press the JOB CANCEL button to clear the print Queue.
Apr 15, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Won't print faxes that are in memory...
what type of fax machine is this ? model serial #
Mar 25, 2008 | Epson ACULASER CX11NF All-In-One Printer
Cuisinart CBK-200 Bread Maker Logo
35 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
