Question about Electrolux EIED55H Dryer
How to clear an e64 error code - Electrolux EIED55H Dryer
What is wrong with a code e64
It probably requires a technician to test it.
You haven't identified the manufacturer and model, but it is likely the following result of a Google.com search suggests a problem:
https://www.justanswer.com/appliance/7f3w8-frigidaire-dryer-e64-error-code-dryer-will.html
Why Am Getting Error Code E64 On My Frigidaire Dryer
Mar 19, 2018 | Dryers
Why does my frigidaire dryer run briefly then stop and show a code of E64
Hello Robert, I appreciate your post!
Based off the information you have provided your Frigidaire dryer is displaying an error code of "E64". An "E64" error code means that the heater has an open circuit this could be an issue with your heater, wiring harness, or a miscommunication within your control panel. To help clear out any miscommunications I would suggest performing a reset. You can reset the dryer by disconnecting power from it for at least ten minutes. If the reset does not help clear out the error code, you may need to seek assistance from a professional technician. This will help you avoid any unnecessary part purchases. I hope that this information is helpful to some degree. -Matt
Feb 16, 2016 | Frigidaire Dryers
I am getting a error code E64 on Frigidaire affinity model# FASE7021NW0 It still get hot but keeps cutting off, what should I do
Hello friend, that's a great question!
From my understanding your Frigidaire Affinity dryer is displaying an error code of "E64". An "E64" error code stands for the heater circuit is open. This could be a possible problem with your heater, wiring harness, or even a miscommunication within your dryer. In order to clear out any miscommunication you can perform a reset on your dryer and to do that you need to unplug the power cord for at least ten minutes. If this does not help to resolve your issue I would recommend having a professional technician out diagnose and repair your dryer to help avoid any future issues or unnecessary part purchases. Hopefully this information is helpful. -Matt
Mar 02, 2015 | Frigidaire Dryers
My Frigidaire Dryer (Model #FASE7073LW0) has an "E64" message listed. What error is this in reference too?
Good Morning Yasmin Abdullah, I am happy to assist you!
Based off the information you have provided your Frigidaire dryer is displaying error code "E64". "E63" typically stands for heater open circuit, which means that it could be a faulty wiring harness or heater. I would suggest performing a reset on your dryer by disconnecting power from it for ten minutes. This could be a false error code or a miscommunication within the board and a reset will help to clear that out. I hope this information is helpful to some degree. -Matt
Dec 16, 2014 | Frigidaire Dryers
E64 error code electrolux dryer
You have not specified Tumble dryer model so I can not say for certain that my answer is correct. Fault codes can sometimes vary depending on the platforms appliances because today some manufacturers release new models twice a year and thay have the absolutlly right to make changes and improve the efficiency of new appliances (also change fault codes).
E64 - Heater thermostat
  • Thermostat faulty (replace heater unit)
  • Heater unit faulty
  • Wiring faulty
  • Electronic board faulty.
Dado
Aug 09, 2014 | Electrolux Dryers
What is error code E64 and how can it be fix
Good Afternoon Friend, this is Z. Thank you for your inquiry!
Normally error code E64 is an indication that the heater circuit is in the open position. This is not a simple DIY job; I would highly recommend consulting a professional to move forward accurately. The certified technician will need to check the heater coils and connections for open circuits. Depending on the diagnosis the heater or wiring may need replacing.
Jul 13, 2014 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
We are getting an error code 64. What do we do to fix this
Error code E64 means heater Open Circuit. This error appears when the Heating element or wiring to the heating element is defective. To clear the error code (s): Press and hold the far left key under the display and cancel. Hope this helped Tim
May 29, 2011 | Electrolux EIED55H Dryer
Getting a fault/error code E 64
Error code E64 means heater Open Circuit. This error appears when the Heating element or wiring to the heating element is defective. To clear the error code (s): Press and hold the far left key under the display and ?cancel?
Nov 22, 2010 | Electrolux EIED55H Dryer
I was drying and the dryer shut off and gave an error message of E64
Hi
Error code E64 means Heater Open Circuit. This error appears when the Heating element or wiring to the heating element is defective. To clear the error code (s): Press and hold the far left key under the display and “cancel” buttons simultaneously for 3 seconds. If the error appears again then you’ll need to check heater coils and connections for open circuits. Use a multimeter to check the heater element, use Rx100 setting on the multimeter. It should display 30-33 K ohms as the resistance. If it is less than this or exceeds this limit then the element has gone bad and you would need to replace the element. Hope this helps...
Daniel
Sep 13, 2010 | Electrolux EIED55H Dryer
Error message e64
Hi
Sep 07, 2010 | Electrolux EIED55H Dryer
Electrolux EIED55H Dryer Logo
293 people viewed this question
Top Electrolux Dryers Experts
John Tripp
John Tripp
vince
JP Services
JP Services
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
