Question about Samsung HP-S4253 Television
Hdmi stopped working
1 hdmi only supports video, 2nd nothing
How do I add a 2nd independent monitor when a splitter cable does nothing but carry the #1 monitor display?
The rear of the unit has both an HDMI and a VGA output connector. If you have a digital-ready monitor with HDMI and a monitor with a VGA analog port you can run a cable to each. The on-board video adapter will detect the second monitor and support it. My computer has a VGA, DVI-DD and HDMI output and I am running THREE monitors off the onboard video.
Apr 14, 2015 | Acer Aspire XC Compact Desktop PC Intel...
The inputs (scart & hdmi on my celsus tv have suddenly stopped working. Nothing has changed, but now my ps3 won't come up on any ext. Was fine yesterday
From standby press and hold power button for 8 seconds (2nd beep). This will reset the video settings. If this doe not work, remove the battery and try again, if displays now then the HDD has a problem.
Nov 28, 2014 | Video Game Consoles & Games
Emerson hdmi not working
Double check to see if your TV can support the resolution that your laptop is using. You can try reducing the resolution on your laptop to one supported by your TV.
If the laptop is configured to use the HDMI port as a second (in Windows 7, you can configure multi-monitor support in the display preferences) you will need to adjust the resolution for that monitor.
Failing that, try rebooting your laptop with the TV plugged in - I have found in some cases that this helps the system to propery detect a new display.
Dec 16, 2013 | Televison & Video
My ht-r690 receiver's video out stopped working. sound works, tv and cables work (tested on another system) but no video shows up on tv through the receiver. any ideas?
Well there are two possible reasons. 1st- make sure that to do a factory reset on the amp. while it is on Press DVR/VCRat the same time press the power button (Standby) clear will show on the screen.system is now back to defaults try the video.
2nd If the video still not working check the TV out settings. Press Setup - Input Out put assign - Monitor Out- Make sure it's set to HDMI. and the resolutions is set to Through. if this setting is ok and you problem is not solved. it could be an issue with the board or your hdmi device it self.
Let me know?marc
Nov 10, 2011 | Onkyo Audio Players & Recorders
Is this system came with inbuilt speakers?
General
  • Type Personal computer
  • Product Form Factor Ultra-slim desktop
  • Width 7.6 in
  • Depth 7.6 in
  • Height 1.4 in
  • Localization United States
  • Desktop type Budget desktop system , Small-form-factor PC
Processor
  • Type Intel Atom N280 / 1.66 GHz
  • Installed Qty 1
  • Max Supported Qty 1
Cache Memory
  • Type L2 cache
  • Installed Size 512 KB
  • Cache Per Processor 512 KB
Mainboard
  • Chipset type Intel GN40
  • Data bus speed 667 MHz
Environmental Parameters
  • Environmental standards EPA Energy Star
RAM
  • Installed Size 2 GB / 2 GB (max)
  • Technology DDR2 SDRAM
  • Memory Speed 667 MHz
  • Configuration Features 1 x 2 GB
Storage Controller
  • Type Serial ATA - Integrated - Serial ATA-300
  • Storage controller interface channel qty 1
Storage Controller (2nd)
  • Type None
Storage
  • Floppy Drive None
  • Hard Drive 1 x 160 GB - Standard - Serial ATA-300 - 5400 rpm
  • Hard Drive (2nd) None
  • Hard Drive (3rd) None
Optical Storage
  • Type None
Optical Storage (2nd)
  • Type None
Storage Removable
  • Type None
Monitor
  • Monitor Type None.
Graphics Controller
  • Type Integrated
  • Graphics Processor / Vendor Intel GMA 4500M Dynamic Video Memory Technology 5.0
  • Digital Video Standard High-Definition Multimedia Interface (HDMI)
Audio Output
  • Type Sound card
  • Sound output mode Stereo
  • Audio output compliant standards High Definition Audio
Telecom
  • Modem None
Audio Input
  • Type None
Networking
  • Networking Network adapter
  • Wireless LAN Supported Yes
  • Data Link Protocol Ethernet , IEEE 802.11b , IEEE 802.11g , Fast Ethernet , Gigabit Ethernet , IEEE 802.11n (draft)
  • Compliant Standards IEEE 802.11b , IEEE 802.11g , IEEE 802.11n (draft)
Expansion / Connectivity
  • Expansion Slots Total (Free) 1 ( 0 ) x Processor , 2 ( 1 ) x Memory , 1 ( 1 ) x PCI Express Mini Card
  • Interfaces 1 x Display / video - VGA - 15 pin HD D-Sub (HD-15) , 6 x Hi-Speed USB - 4 pin USB Type A ( 4 in front ) , 1 x Network - Ethernet 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x Display / video - HDMI - 19 pin HDMI Type A , 2 x Keyboard / mouse - Generic - 6 pin mini-DIN (PS/2 style) , 1 x Headphones - Mini-phone stereo 3.5 mm , 1 x Microphone - Mini-phone 3.5 mm
Printer
  • Type None
Miscellaneous
  • Features Security lock slot (cable lock sold separately)
  • Compliant Standards PC 2001
Power
  • Device Type Power adapter
  • Power Provided 65 Watt
Operating System / Software
  • OS Provided Microsoft Windows XP Professional
  • Software Acer Smartboot , Google Desktop , Google Toolbar , Acer PowerSaver , Acer Client Manager , Acer QuickMigration , Adobe Acrobat Reader , Veriton ControlCenter , CyberLink PowerDVD (OEM) , Acer eRecovery Management , McAfee Internet Security Suite (Trial) , Microsoft Office Professional 2007 (60 days trial)
Manufacturer Warranty
  • Service & Support 1 year warranty
  • Service & Support Details Limited warranty - 1 year
Card Reader
  • Card reader Card reader
  • Supported flash memory cards Memory Stick , MultiMediaCard , SD Memory Card , xD-Picture Card
Sustainability
May 27, 2010 | Acer Veriton N260GU2802CP (PSVA506017)...
PS3 HDMI - Sony Bravi KDL-40V2000 Problem
  • Have your ps32_bing.gif in standby mode (red light).
  • Now, press andhold the power button in the front down. Your ps3 will beep twice. Letit go almost exactly after you heard the second beep.
  • Wait 10-15 seconds. A display will show up, and just answer yes to all!
try this
May 08, 2010 | Sony Playstation 3 (PS3) Console
Input 1 for hdmi stopped working. Input 2 works
Reset all setting back to factory setting.Unplug,replug,should work,if ur backlight video it good,not any coponnents damages.
Dec 22, 2009 | Pioneer PDP-5060HD 50 in. Plasma...
Hitachi 50V720 No sound with HDMI - no Component video inputs
Right now there seems to be many people with the same TV problems with sony and HDMI cables. Most of the solutions are resetting the TV and sony product. Try leaving your TV unplugged for a hour to let it reset itself.
Feb 17, 2009 | Hitachi 50V720 Television
Televison & Video Logo
47 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
