Question about Refrigerators
Modle # TSF-495D will not defrost
Evaporator is frosted over and will not defrost automatically, when put in manual defrost it has a short defrost and the compressor will run at the same time.
  • 17,129 Answers
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts: http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Posted on Jan 12, 2013
  • 958 Answers
SOURCE: Maytag MTB2176HRS not cooling
it could be out of gas...can you open the bottom rear cover and feel the air coming out of the condenser blower. if its not warm, you have a leak where refrigerant escapes...
Posted on Mar 28, 2008
tech master
  • 120 Answers
SOURCE: GE frost-free refrigerator
well you need to know when it was manufacture if it lands under the 5 years seal system warranty then it can be fix for free. on the other hand be sure that compressor is running because if it is not it could be a relay and that is a cheap fix
Posted on Oct 17, 2008
  • 531 Answers
SOURCE: refrigerator evaporator fan won't run but compressor working
is the evaporator coil frozzen you may have a defrost problem
Posted on Mar 31, 2009
Healeyman
  • 1198 Answers
SOURCE: Compressor and Compressor Fan Not Working
Rotate the dial on the defrost thermostat, a big click is when it goes into defrost, a little more and it should turn the compressor back on. By overload protector, do you mean the one under the compressor cover?
Posted on May 03, 2009
jumptrout51
  • 3361 Answers
SOURCE: Frost free failure on a GE fridge. Removed access panel to freezer section to find evaporator coils crusted in frost. Cannot locate defrost timer and cannot locate any repair manuals online. I'm not w
The defrost timer is electronic and built in to the main control board on the rear of the box.
The defrost heater and defrost thermostat are the most likely culprits on this brand.
They are in the freezer above and below the coil.
They usually come as a set.
Posted on May 24, 2009
Unit does not defrost automatically
Faith I would not call that a professional what is the model number of the refrigerator
Apr 30, 2016 | Frigidaire Refrigerators
Sub zero sxs refer modle 532
The problem is with the damper door.Please check that it is not cracked.
May 14, 2008 | Sub-Zero Refrigerators
My ice maker not making enough ice . I have already check the water. thank you
When an icemaker slows production, the problem is not the icemaker at all but the temps in the freezer warming up because of an airflow problem either in the freezer compartment evaporator coils or underneath the unit that being the condenser coils. (Fan not working or lint blockage)
Airflow problems in the freezer compartment are caused by the fan or the automatic defrost system not functioning properly so yu end up with an ice block / lots of frost in the freezer compartment on the back wall of the compartment.
Check for ice or large amounts of frost in the freezer compartment. If you note ice / excessive frost, unplug the unit, empty the freezer compartment and do a manual defrost by directing an external fan into the compartment for just over 2 hours. This will ensure the evaporator coils and the freezer compartment drain have thawed. While the manual defrost is in progress remove the rear fiberboard cover from the compressor access and check / clean the condensor coils and fan area.
After 2 hours clean up the excess water.. reassemble the rear cover and return the unit to NORMAL service. It should start making lots of ice in 4 to 6 hours. Here is the kicker... if there is an auomatic defrosting problem your icemaker will after 2 - 3 days again slow ice producion and ice will build up in the evaporator area. You will have to keep repeating the manual defrosting process every 3 to 4 days until the automatic defrost system is repaired.
There are 3 main components of the Automatic defrost system:
1. Defrost control
2. Defrost heater
3. Defrost thermostat or depending on type thermistor
Most of the time the problem is either the defrost control or the heater that fails and the unit stops defrosting.
Your parts can be found here:
http://www.searspartsdirect.com/partsdirect/part-model/LG-Parts/Refrigerator-Parts/Model-LSC26905TT/3204/0165000
Thanks for choosing FixYa,
Kelly
Jun 23, 2011 | LG LSC26905TT Side by Side Refrigerator
Frost on coil in back of freezer it is a kenmore side by side
Hi and welcome to FixYa, I am Kelly.
Frost on the back of freezer is a sign of an automatic defrosting problem. On very very rare occasions the evaporator drain gets blocked with ice.
Should you discover a block of ice on the evaporator coils do a manual defrost by unplugging the unit, directing a fan into the freezer compartment for just over 2 hours with the freezer contents removed. (Makes a water mess so be ready) After the manual defrosting session... reload the freezer, plug the unit in ad return it to normal service. After 6 - 8 hours check for ice production. If you have ice production now... you most likely have and automatic defrosting problem where as the defrost cycle is not working correctl;y due to control problem, terminating early or the defrost heater and / or defrost thermostat is not working correctly.
If you want unit specif information.... I will need your COMPLETE model number.
Kelly
Apr 28, 2011 | Kenmore Refrigerators
Frost building up on evaporator plate and not melting, freezer is very cold while fridge isn't as cold
u have a defrost problem. if it dont automatically defrost u have to manually do it then replace your defrost timer. so it can go back to doing it on its on. ok
Feb 12, 2011 | Refrigerators
Is the Tubo Air TSF-49 a manual defrost and if so; can it be converted to auto defrost control?
it is automatic. If it is not going into the defrost mode, the defrost timer may not be working.
May 16, 2010 | Turbo Air 49 cu. ft. / 1388 liter Upright...
Automatic defroster stays on to log and water runs
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Oct 23, 2009 | Refrigerators
The freezer automatic defroster element is not coming on enough to prevent ice build up on frezzer coils. Is there a way to trick system to make the hot coil work more. Often?
If yours is not staying on long enough the defrost thermostat may be defective and cutting it off too soon. It's clamped to the evaporator coil.
You have an adaptive defrost control which determines when and how long to defrost. I could be malfunctioning.
Jul 03, 2009 | Maytag MSD2756G Side by Side Refrigerator
Walk-in norlake freezer
Check the evaporator coil for frost buildup on the back. Check for frost on the suction line, the biggest line returning to the compressor. If frost is evident at these places you have a defrost system problem. These systems have a defrost timer that defrosts the coil at preset times. Check the timer for proper operation by marking the position of the dial and check back to see if it changes. If it does not change position the timer motor is most likely bad. If the dial is not rotating automatically you can manually turn the dial in the direction of the arrow and put it through a defrost cycle.
May 25, 2008 | Nor-Lake Freezer Norlake Refrigeration 6'...
Maytag MSD2356 Freezer frosts up quickly, fridge warm
If you jumped the defrost board and it went into defrost then that board is bad. I assume by "freezes up" you are talking about the evaporator is frosting up? That defrost board puts it into defrost automatically. If you have to jump it to get it go into defrost then the board is not doing its job.
Nov 16, 2007 | Maytag 23 cu. ft. Side-by-Side...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
