Sewing Machines Logo
Posted on Jan 11, 2013
I bent my sewing machine and tried to replace it, but the needle is stuck in the machine even though the clamp is all the way out. I tried pulling the needle with pliers but it won't move.
Singer Promise
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 11 Answers
  • Posted on Feb 02, 2013
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
11
Questions
Helped
1255
Points
21
Try removing the whole clamp that holds the needle. The clamp is replaceable. What type of machine do you have?
3 Related Answers
thepurush
Purushotham Racharla
  • 25 Answers
  • Posted on Oct 17, 2009
SOURCE: I have a Singer Sewing Machine Model 4562 T I
Change needle. It should be alright
Anonymous
  • Posted on Nov 28, 2010
SOURCE: sewing machine needle is stuck and the machine will not move.
you should go with the flow, just take a deep breath hayete w byemshe el hal
Anonymous
  • Posted on Jul 31, 2011
SOURCE: i have a singer stylist model 413 that the bobbin
I have the same problem! Did you ever figure it out?
Replaced broken needle clamp, but presser foot blocks needle shaft from going all the way up & the drive wheel cannot complete a turn to pull thread.
I'd need to know what type of machine you have, but maybe you aren't putting the clamp on correctly. They are fussy! Be sure you have the flat side of the needle facing the correct way and that you wiggle and jiggle it while pushing up on the needle. Also, make sure you are using a new needle and not the old bent one. Sometimes the clamp will come in 2 pieces, so it may not have broken, just came undone.
How do I change a needle on a brother 770?
Here is what I found Hope it helps. I didn't download anything, I just clicked on the pages and scrolled down. Here is the contents page
http://homeappliance.manualsonline.com/manuals/mfg/brother/cs770.html?p=5
Here is the page you need:
http://homeappliance.manualsonline.com/manuals/mfg/brother/cs770.html?p=23
21
Checking the needle
Sewing with a bent needle is extremely dangerous since the needle may break while the machine is being operated.
Before using the needle, place the flat side of the needle on a flat surface and check that the distance between the needle and the flat surface is even.
aFlat side
bNeedle type marking
?Correct needle
aFlat surface
?Incorrect needle
If the distance between the needle and the flat surface is not even, the needle is bent. Do not use a bent needle.
aFlat surface
Replacing the needle
Replace the needle as described below. Use the screwdriver and a needle that has been determined to be straight according to the instructions in "Checking the needle" .
a
Raise the needle by turning the handwheel toward you (counterclockwise) so that the mark on the wheel points up. (With models equipped with (needle position button), raise the needle by pressing once or twice.)
b
Turn off the sewing machine.
c
Lower the presser foot lever.
aPresser foot lever
My sewing machine does not move at all
Is the bobbin winder on? If so, turn it off.
Otherwise, is there power to the machine?
And this happened while you were sewing? Cut the thread above the needle eye. Rock the handwheel back and forth firmly to try to cut the thread jam below the needle plate with the sewing hook. If that doesn't work, open the bobbin case area of the machine and try to pull the bobbin case out, cutting any threads you can see with a seam ripper. Still won't come? Take the needle out of the needle clamp and throw it away (it's bent!), and take the screws out of the needle plate (=throat plate) and take the needle plate off after cutting any threads you can reach under the fabric. Keep cutting and pulling out any thread you find, and eventually, you'll be able to turn the handwheel. Clean all the thread bits, lint, and junk out of the area under the needle plate, the bobbin and bobbin case, and the shuttle area... there will be directions in your manual on how to clean the machine, including the shuttle area. Reassemble. Put in a brand new needle, right way around and fully up in the needle clamp. Rethread from scratch.
Always hold the thread ends behind the presser foot for the first couple of stitches of each seam.
See also: http://www.picturetrail.com/sfx/album/view/22521551
How do I remove the needle clamp from the needle bar on a Singer Futura Quartet sewing machine?
try undoing the lock screw fully and gently move the clamp in the opposite direction the the lock screw, it should drop off.
2answers
Thread breaking, not even threaded in needle anymore, thread gets caught on spool sometimes
Upper thread breaks
1.the needle may be bent or damaged--try rolling the needle on a flat surface to see if it's bent or not
Or the needle could be in backwards
Correct needle insertion
Correct needle insertion is mandatory for proper use of sewing machine.
Raise the needle bar to the highest point, then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine or if using a round needle--the groove in the needle should face away from the shaft.
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
2.upper tension may be to tight--try 3 to 5
3.thread may be hanging up in bobbin case--check area for loose threads or lint
Lower thread breaks
The most probable cause of lower thread breaking is improperly wound bobbin
1.always start with a empty bobbin
Never wind one color over the other
2.choose thread that is identical in color & type as the one to be used for upper threading
3.wind the bobbin evenly across & in layers
4.don't wind the bobbin so full that it would be tight & hard to insert into bobbin case
5.bent bobbin--replace
6.lint built up in the bobbin case--frequent cleanings will eliminate this problem, the more often you use the sewing machine the more often it needs to be cleaned
7.thread catching on the bobbin spring or latch on bobbin case, check to see that the bobbin is inserted completely & correctly, & that you are using the right kind of bobbin
for the top & bobbin thread keep thread tails of 3 to 6 inches long pulled behind the needle before you start sewing
yes,sometimes the thread will get caught on the spool, you might think about getting a extra holder that sets behind the machine to hold those spool's that the thread get caught on, that's what I did.
Upper thread breaking while quilting
Upper thread breaks
Lower thread breaks
7.thread catching on the bobbin spring or latch on bobbin case, check to see that the bobbin is inserted completely & correctly, & that you are using the right kind of bobbin .
When sewing the thread under the material gets all tangled up. The thread is also tangled in the bobbin. At times the needle doesn't even pick up the bobbin thread, but that is another issue.
have you tried a new needle?
4.also clean under the needle plate for lint & loose threads
check to see if the thread has come off the thread take up lever
My thread keeps breaking at the end of my sewing session. not sure why, I've been sewing blocks for a quilt and I've tried to change the thread
Upper thread breaks
1.needle may be in backwards
3.the needle may be bent or damaged--try rolling the needle on a flat surface to see if it's bent or not
4.thread may be hanging up in bobbin case--check area for loose threads or lint
Lower thread breaks
2helpful
The thread keeps bunching up near the bobbin and no amount of rethreading and lubricating is helping.
1.upper tension may be to tight--try 3 to 5
2.the needle may be bent or damaged--try rolling the needle on a flat surface to see if it's bent or not
3.Correct needle insertion
4.also check to see if the thread has come off the thread take up lever
8helpful
Needle clamp won't attach to needle bar
There is a set screw above the needle pin screw which tightens with an allen wrench--try that.
Top Singer Sewing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
