TV Sony KV29FX65E ShutDown, LED blink 5 times
Hi Friends, I have a problem with my TV SONY, KV-29FX65E. The TV is shutting down at 20 seconds and then the LED (Red - Power) blinking for 5 times. it keeps shutting down after 20 seconds, so we cant watch TV. HELP ME FRIENDS. Any ideas? Thanks in advance! Read more: http://www.agoraquest.com/viewtopic.php?forum=34&topic=37184#ixzz2HgwBMdzL
4 Suggested Answers
  • 106 Answers
SOURCE: Sony FD Trinitron WEGA KV-34HS510 ... does not power up.
  • 6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.This may help the solution or let no what is wrong!!
  • Posted on Mar 24, 2009
    TOM2-TOM2
    • 110 Answers
    SOURCE: Sony Trinitron KV36FS17 lost color. LED blinks 5 times
    Check the HOT and resolder H. drive transformeer
    Posted on May 22, 2009
    dragon_rag27
    • 89 Answers
    SOURCE: Sony KV-34HS420 Random Shut downs
    i would say this is a internal problem how long have you had it?
    Posted on May 28, 2009
    Sony kv36xbr800 service code blinks 7times after tv shuts itself off
    SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
    Mar 13, 2015 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
    How can i solve sony tv model kv-29fx65e with no problem?
    Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
    Jan 01, 2015 | Sony Televison & Video
    Sony kv34hs420 shut off itself
    Hi:
    If you count the number of error blinks when it shuts this will let you know the error code you are having. If the red led blinks say 6 to 7 times after shutdown then pauses and does it all over again there is a problem with the deflection board or D Boardas sony calls it, It is usually related to the two Power supply regulators IC's on the D-board.
    Nov 09, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
    Sony KV-20Fs100. Same problen as #4620488. TV
    4 blink of power led shows problem in vertical deflection section and most probably vertical output IC is defective, replace it to fix the issue.
    Regarding .rar file type of service manual files, download winrar software trail version from internet, install it and use it to unzip .rar file to get pdf manual file.
    You wont get +B volts because tv switch to protection mode and power supply shuts down. Service manual has blinking standby led error code details as well.
    Thanks.
    Jul 25, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
    Sony FD Trinitron WEGA Tv - LAMP blinking 11 times
    Sony tv has self protection program. The red Led blinking light indicate the probable cause location. For this model it is either 2,4 or 5 flashes every 3 second. Please check the blinking again
    Feb 09, 2010 | Sony FD Trinitron WEGA KV-27FS120 27" TV
    I got a problem in TV. TV starts and shutdown immediately, while from sound its looks like that raster is going up but no picture, no sound. Red light is blinking. This happens only when i power off the tv...
    Hi Sikandar,
    Let me know how many times red led blinks as there would be an interval of 3 seconds so count blinks from pause to pause.
    Is it Sony AR25M61 model or any other?
    Above info will help to diagnose problem.
    Thanks.
    Nov 13, 2009 | Sony KV-AR25M61 TV
    May 28, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
    I have a 36" TV that won't work - Red LED light blinks 5 times
    The 5 blinks indicates a White Balance Failure. This involves checking voltages and components tied directly to the CRT. I would not suggest any attempt for self repair. The cost for this repair should not be significant. Figure a parts cost in the $30-$50 range at worst.
    Dan
    Mar 06, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
    TV will not come on.
    The 7 blinks indicate a high voltage shutdown (high voltage exceeded 33,000V). This is usually caused by a defective regulator. Could you please post the exact model number (KVxxx) and I'll look up the part you will likely need?
    Thanks,
    Dan
    Jul 28, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
    KV-32FS120
    Seven Blinks: High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into shutdown. Check power supply and horizontal circuits.
    Culbert Communications
    New Brunswick, Canada
    Nov 23, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
    Televison & Video Logo
    107 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
