Question about LG WM1812C Front Load Washer
8074 vibrates furiously on spin cycle.Has done so since new.
My 8074 front loader vibrates itself "out the door". I have reinforced the floor it sits on, but to no avail.
I have levelled it with a spirit level many times, so out of level is not the cause.
Any solutions??
Chris
  • eyetch4s Mar 28, 2009
    My machine is doing the same thing, vibrating itself across the floor. We have check the balance and it is fine.
Check suspension shocks and springs. undone back cover, should be 3 shocks attached to tub. remove top cover and check 2 springs attached to tub.
Posted on Mar 01, 2009
GE Front Load washer shakes whenever any type of load is put in. GE service has been out at least 4 times and say that its fine..perfectly level, etc
All front loaders shake to some extent. It depends on the balance of the load. It is especially evident in the spin cycle due to the high speeds. Also these machines are best placed on a solid cement floor. They can shake an entire house if on the first or second floor and the floors are not well reinforced.
Feb 25, 2010 | GE WSXH208A Front Load Washer
Tip
Front Loader Excessive Vibration
When the manufacturers first introduced the front load washers, they did not take into consideration the possible problems created by the centrifugal force of the washer's spinning action. Most of these washers spin in excess of 1200 rpms! A spinning action that fast, coupled with the washers heavy weight and a floor that flexes (even a little) will cause a resonant vibration. In simple terms, it will cause the washer to bounce or walk.
Some of the early manufactured shock absorbers, weren't up to par and were uable to maintain the washer suspension over continuous use. The manufacturer's improved the shock absorbers to make them more stiff and minimize vibration. Replacing the shocks with heavier duty shocks does help, but if the flooring is not substantial enough the washer will continue to have problems.
If the washer is mounted on a pedestal, this can make the problem worse. Early model pedestals had an open back which caused it to "tin can" when the washer spun. "Tin-canning" is the phenomenon of the sides of the pedestal casing waffling in and out as the weight of the washer rides on top of it. This would also cause excessive vibration. The solution: The manufacturers redesigned the pedestals with an enclosed back that would prevent this from happening. If your washer is a later model, you should have an enclosed back on the pedestal. If there is no back panel, a stiffiner kit can be purchased and installed by any Do-It-Yourselfer. All you need is a drill and a screwdriver. Instructions are included. The part number is 134682000. I found it listed at searspartsdirect.com.
Check the leveling of the washer. You need to adjust the feet of the washer ensure it is level front-to-back and side-to-side. The feet are adjusted using a wrench to turn the legs up or down. Use a level to check your work. Once completed, you should be able to place your hands diagonally across opposite corners of the washer top and see if the washer moves at all. If unlevel (just the slightest) the washer will vibrate during the spin cycle. If the washer is mounted on a pedestal, you level the feet of the pedestal, NOT the washer. Make sure the washer is firmly mounted to the pedstal fisrt. Then, level the feet of the pedestal using the same procedures outlined before.
Another cheap method to get rid of vibration is to use foam padding to sandwich between the sides of the washer, the dryer and the wall. Swimming pool noodle foam works real well and is very inexpensive. About $3 or $4.
Overloading the washer with heavy items can cause excessive vibration due to an unbalanced load. If you load items so full that you can barely close the door, the load will have a hard time distributing evenly around the perimeter of the wash tub. Once wet, and the tub begins to tumble, the load becomes entangled and will pack on one side of the tub. This will cause the washer to jump and walk across the floor on the spin cycle. This can also cause premature wear to the door bellow, damage to the door latch and damage to the shock supports and counter-weights. Always follow the manufacturer's wash load recommendations as outlined in your owner's manual.
Now...when you've checked every other possibility, its simply not the washer. Most consumers don't like to hear this (especially owner's of newer homes). The worst places you can put a front loading washing machine is in a mobile home, or an upstairs laundry room. The floors in these areas are usually not as reinforced. Even homes with a laundry room over a crawl space or basement can sometimes have problems if the floor flexes. Most home builders don't take added reinforcement into consideration for the installation of a front loading washer.
An inexpensive way to reinforce a laundry room floor is to install a 4 x 8 sheet of heavy plywood under the washer. The plywood has to be a minimum of 3/4 inches thick and needs to be secured (screwed down) to the existing floor. This distributes the weight of the washer better. You can also safely fit BOTH the washer and dryer on top of it. A lot of people don't like this idea, because they feel it wrecks the look of the existing floor. I have seen homeowners, install a reinforcement this way and add paint, trim molding, and even tile to give it that "supposed to be there" look.
You may get mixed reviews about this, but I have seen it work for homeowners. Plus, its a less expensive option than hiring a contractor to firm up your sub-flooring or joists.
I hope you find this information informative and helpful. If you have questions, please let me know.
on Dec 13, 2009 | Washing Machines
An extreme vibration in spin cycle. It makes the
Because front load washers are VERY HEAVY, they shake if you have a wooden floor. If your front loader sits on concrete and it still shakes, then you have to make sure all is balanced. If it still shakes, then inside the system there are shock absorbers that need to be checked.
Nov 12, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Vibrates during spin cycle
front loaders are made to sit on concrete they probably didnt tell you when you purchased it if its on wood floor not much you can do
Jul 05, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Vibration during spin cycle - "walking" across floor
dear sir/mam
please check the floor level of your washer by using the spirit level,if there is difference please adjust the level by screwing the legs of the washer,then vibration will be stopped.
Jun 01, 2009 | Whirlpool Inglis IP4400 Washer
Severe vibration during spin cycle
reduce the amount of cloth and make sure the cloth don't fix in one corner
Mar 23, 2009 | LG WM-2277HW Front Load Washer
Washer vibrates during spin cycle
Front loaders have to be situated on solid flooring such as a basement or they will vibrate.
http://tclaundryrepair.com/
Feb 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Out of balance drum WM2277HW?
More than likely it did not get reinstalled right after the move. All four of the leveling legs must be firmly touching the floor. If one is even the thickness of a piece of paper off the floor it will start to rock during spin and the problem just amplifies itself. Make sure it's perfectly level and that all the feet are firmly on the floor.
Jul 28, 2008 | LG WM-2277HW Front Load Washer
Vibration
You may need to reinforce the floor.
Is it on the first or second floor?
May 03, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Lg Tromm wm2277hw
Try Ke shake away pads. i found them at lowes for $30. Solved my problem with a front load pedestal. Shook the pictures off the wall in the room next door. Best money I ever spent.
Jan 28, 2007 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WM1812C Front Load Washer Logo
168 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
