Question about Harman Kardon JBL Flip black
JBL Flip won't turn on
It was working fine yesterday. When I push the power button, nothing happens. Sometimes I get the solid red light when plugged in, but even that light turns off after a while. The Flip still won't turn on when plugged in. Is there a way to reset the device?
  • Rune Faaberg Jul 16, 2013
    Did you figure this problem out. My flip just died on me. It does not respond when plugged in.
    New Friend:
This doesnt help. how can i get back on?
Posted on May 30, 2015
2 Suggested Answers
SOURCE:
  • 12962 Answers
SOURCE: JBL flip only plays while connecting to the mains
Seems the battery has gone bad prematurely. Charging circuits have to be good since the unit works fine off the adapter plugged into the mains.
Posted on Mar 31, 2014
TV does not turn on? (Relay problem?)
The power supply could be failing intermittently. That's why it sometimes works and sometimes doesn't. Also, the relay could be erratic.
May 26, 2014 | Funai Magnavox 40" Class 1080p 60hz LCD...
Lenovo thinkpad t400 laptop wont open
try changing the keyboard because switch is on keyboard and use adapter to plug and test
Mar 25, 2014 | Computers & Internet
I have an lg plasmas model # 42pc5d-uc the tv is not turning on. When I push the power button the red light flashes a few times I hear a click & nothing happens it goes back to a solid red light...
All put the name in with the model. Its a LG .Your power supply is down. This could be capitator or transitor bad if the caps are swelled up replace them with the same value .
Mar 01, 2011 | Televison & Video
Won't Start No lights flashing does nothing when I hit the power button
Try taking out battery and plug in power. If it works, battery is faulty.
If not, try taking out your hard disk plug in power, if it works, hard disk is faulty.
Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
May 08, 2009 | Dell Vostro 1500 Notebook
2Wire 473 router problem
Take the modem and plug it into a GFCI outlet. You can find one in the bathroom or the kitchen.
If the power light comes on solid green and the dsl comes on red then the modem is good. Was it plugged into a power strip by the computer? If so, plug it straight into a wall outlet.
If the power light comes on solid red then the modem has hardware failure. I would contact your ISP and have them replace it if it is still underwarranty.
Mar 23, 2009 | 2wire (1000-400108-001) Router
TV will not Turn On.
same thing,tv won,t come on,unplug the tv, nothing at all,just yesterday my tv was fine, this is the first time this has ever happen
Mar 13, 2009 | Samsung HC-P4363W 43 in. TV/DVD Combo
AKAI 32" LCD HDTV WILL NOT TURN ON
The only solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Nov 27, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
GE omuse 97985
I know.....I have to ask...you've checked the batteries right? OK. Check the cable on the back to mahe sure it's still plugged in firmly. If you push the button on the transceiver, it should start blinking. Then hold the button on the bottom of the mouse until the light on the transceiver is solid. Let me know what happens. If this solves the peoblem PLEASE rate as fixed. If not, DON'Y RATE YET. Just add a comment letting me know what happened and I'm here to help you further. Thanks toba. Let me know.
Jeff
May 16, 2008 | GE 97985 Mouse
Compaq Presario 4400us
Either the new power supply you purchased is not functioning correctly. But, assuming it is now that you are getting some form of power to your PC, it is very likely the motherboard. Whatever fried your old power supply (or it could have just been the power supply itself) most likely fried your motherboard in the process. Probably not the CPU since the MB can't even post.
Jun 21, 2007 | Compaq (388746-001)...
Harman Kardon JBL Flip black Logo
10,615 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Don Hart
Laser Plus Computers...
Level 1 Expert
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
