Question about Pool & Spa
Sprinkler pump makes loud noise when it is running, how to fix?
Pump runs but makes a loud noise when it is running.
  • Norm Blais Jan 18, 2013
    Ended up replacing pump and motor.
  • 372 Answers
Typically this sound indicates bearings going out. Usually this means replacing the motor, or may be repairable depending on size and make.
Posted on Jan 13, 2013
5 Suggested Answers
john224
  • 1378 Answers
SOURCE: when running it makes a loud continuous loud noise
Your bearing are failing. Replacing them and the seal at a local electric motor repair shop will likely cost around $50.
Posted on Jun 14, 2009
  • 3 Answers
SOURCE: pump motor makes loud noise when pump comes on
If this is a high pitched sound, then this sounds like you have bearings that are starting to go out.  There is not much that you can do to prevent eventual failure.
The only other option that I see is that there is something causing friction inside the pump between the impeller and diffuser.
Posted on Jan 12, 2009
john224
  • 1378 Answers
SOURCE: when running it makes a loud noise
  • 4 Answers
SOURCE: My pump whines very loud while running? Any
check the motor bearings,(take the pump apart from the motoer should 4 bolt,,,, then wiggle the shaft should not move at all.) then look at the impeller to see how worn it is or if it is touching any part of the houseing.
Posted on Jun 29, 2009
Why does my pump loose pressure
Sounds like your not using enough water, and or your pipes to sprinkler is to to small, causing pump to build up to cut off head. I cant lay my hands on a performance chart for your pump, but 60 psi cut off and 20 on sounds about right. Try running another tap when your sprinkler is running, and see if this keeps your pump running
Mar 25, 2015 | Utilitech 1-HP Cast Iron Convertible Jet...
Pool pump makes a loud noise
bad bearings change pump and motor
May 14, 2014 | Waterway Impeller Pump 2HP SD WW
Calling pentair
I am assuming it is several years old and has given a lot of good service. It is probably one of two things, it is getting air in the suction line causing it to cavitate or it is wearing out and ready for a rebuild.
Oct 13, 2013 | Myers Pump QP10-3
Fuel pump noise 2005 Buell xb9sx
That is the fuel pump doing its job of pumping. If it stops making noise, it stopped pumping, and no gas is getting into your motor. Your bike will not run without a running fuel pump. :)
Apr 14, 2010 | 2005 Buell Lightning CityX XB9SX
1-1/2 hp sprinkler pump hangs up and just hums sometime
The impeller and or bearings are seized. You may have to force the impeller loose (breaking it to get the unit apart). See if you can obtain the bearings and impeller and shaft seal before attempting the overhaul. Be aware that the hardware attaching the motor to the pump housing may need lubrication before attempting to remove.
Apr 06, 2010 | Pool & Spa
I have 1 and 1/2 horsepower sprinkler pump that wont prime. As soon as the end piece fills, it will empty if I open the end to the sprinkler.
I don't know what is your system set up. However, the system set up should be the following;
1. Your 1-1/2HP sprinkler pump must be installed at
a fix location nearest the water source. (Complete
with power and plumbing lines.)
2. At the end of the suction line is a vertical check
valve with strainer.
3. The suction pipeline must be connected to the
suction port of the pump.
4. At the discharge port, a flow control valve tee must
be installed. The flow control valve tee top is
covered with a plug, which serves as the priming
port when opened.
5. After the flow control valve, connect a short nipple
so that you can put a gate valve to stop the water
flow or allow the water to flow. You may connect
a pressure tank at this point or you may connect
the pressure hose going to the sprinkler.
6. To prime the pump, open the plug at the flow
control top. Fill it full with water, replace the
priming port plug.
7. Turn the flow control valve to full closed position.
8. From full close position, switch the power on.
9. The pump now run on and off due the pressure
switch setting. Slowly open the flow control valve
such that the water pressure remains steady.
10. Take note of the pressure.
11. Shut the power off, and connect the sprinkler
pump hose.
12. Put the power back on, and allow the pump to
run with the sprinkler.
Under this set up, you can run the sprinklers when your pump is running. Hope this will solve problem.
Dec 08, 2009 | Plumbing
My hayward northstar pump makes a loud noise when
If you have a crack in your basket you may have a clogged impeller. With the power off reach back into the pump through the pump pot with a long screwdriver and feel around. If it feels spongey it there you have a clog. Take the serew driver an use an oceleting motion in a counter clockwise direction this should loosen the clog then reach in with a long set of thin pliers and pull the clog out. This should fix your problem and once water is flowing your pump should quiet down.
Sep 29, 2009 | Hayward 1.5 Hp Northstar High Performance...
When running it makes a loud continuous loud noise
Jun 02, 2009 | Polaris 380: Polaris Booster Pump
When running it makes a loud noise
Jun 02, 2009 | Polaris Pb460 Polaris Booster Pump...
Aqualisa Aquastream shower noise from pump/motor ?
aquastuream loud noise?motor/pump
Mar 30, 2009 | Home
Pool & Spa Logo
1,165 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
