Robertshaw thermostat is blowing cold air when on heat and wont shut off
I have tried everything I can think of. I took out the batteries and hit the reset button and even set it to off. But the heater keeps blowing cold air and wont shut off. Please anyone, help.
3 Suggested Answers
gargac
  • 39 Answers
SOURCE: Unless we set the thermostat
Check and make sure the filter is clean. This sounds like a restriction in the system. If the unit has central cooling make sure ther indoor evaporator coil is clean at the furance.The unit may be cycling the burners on and off at the high heat limit , fan/limit control. You can also eliminate the thermostst from the furance. Turn power off at the furnace and disconnect the wiring from the thermostat. Jumper the red and white wire together. Turn the furnace back on. The furance should run in the heating mode. Try this and see if the problem is still there.
Posted on Jan 27, 2011
heatman101
  • 43501 Answers
SOURCE: My gas heater keeps blowing
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
Posted on Feb 03, 2011
Over heating 2001 Ford F-250
if there was air truck wud be overheatn-no liquid wud b movin once the air hits the pump--it blows cold cause the heatr core probly bad or the channel doors not workin rite---leak is from bad radiator or engine gaskets--a leak test must be performed to verify----a
Feb 13, 2014 | Cars & Trucks
Our Robertshaw 4220-RT works great durring the day, keeps apartment cool at set temperature. Late at night it does not shut down when it gets to its lower 1 degree differential setting. The airconditioner...
hi
the sensing ( sensor ) within the unit is mostly clogged up with fluff as the fun intakes the cold air ( of the room ) and pushers the cooler air back into the room . the system have filters behind the flutes ( made of fibres you can blow them with air blower then can be re used ) it within this area where the sensor is located
Jan 02, 2018 | Shaw Robert RS-9420 Thermostat
Heat Pump - blows heat to set temp, then off, then kicks on to blow cold
Heat pumps defrost which is the AC mode, if the heat strip isnt working during a defrost, the air will be cold, A heat pump only feels warm if the heat strips are on too! the refrigeration cycles heat output is much less sensible to our 98F skin. heat pumps that satisfy a room setpoint are working at least, all heat pumps feel drafty to most.
Oct 28, 2012 | Honeywell Programmable Thermostat Heater
My ducted heating continually blows cold air thru
Well, if need be, turn the breaker off. Turn it on when you need heat. Sounds like the fan relay is sticking or something if that sort. Is the tstat fan selector on auto?
Jun 17, 2017 | Heating & Cooling
No heat just warm air
I think you are on top of your problem,,you dont need any one elses advice.
Complete rebuild of the cooling and heating system,, simple.
Jan 19, 2009 | 2001 Oldsmobile Alero
Central heating HVAC blows cold air -
is there a light or source of heat near t stat or low battery in tstat
Jan 04, 2009 | Intertherm P3RA-048K Air Conditioner
Heater wont heat.
on the back side of the door you took off it sould tell you what the flashes mean, make sure you put door back right or it will not run,
Nov 29, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
294 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
