Question about Samsung N150 Netbook
Netbook keeps dropping Wireless Connection
I have had this Netbook a couple of days. It is a refurb so hopefully this is not the problem. Everything else works okay, but, the internet will randomly drop out and then says no internet connection available. Then reconnect 20 seconds later, the issue being it did this 4 times in the space of 10 minutes. Hope someone can help, many thanks Daniel
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 109 Answers
I'd remove the internet connection entirely and then reinstall it - there may have been a Microsoft update that your ISP patch doesn't recognize. Also try going to speedtest.net and take a look at how fast your computer is pinging to the ISP if it is slow contact your ISP they may be able to do a signal refresh to your IP address. Delete the browser history and clear your cache as well. restart the computer
Posted on Jan 11, 2013
It sees my connection and it connects and then it drops, and then it connects and then it drops, back and forth..
How's your signal strength?
If the signal isn't the problem, you might find that it helps to shut down your PC and your router, unplug them for five minutes, and then start everything up again. Mind you, this might work, but you don't want to have to do it several times a day. So there are a couple of other possibilities to try...
How many other things is your PC trying to do, especially via USB? I know they say you can connect 127 USB devices at once, but many PCs start to 'act confused' if you connect more than four or five USB devices. Try the adapter without any other devices connected and see if it performs better. If you're into multitasking (simultaneously running a printer, MP3 player, wireless adapter, external hard drive, speaker set, number pad and missile launcher), then you may have to compromise.
Hope that helps a bit. Good luck!
Oct 10, 2010 | Linksys WPC54G Wireless-G Notebook Adapter...
Wired connection randomly drops
Since the wireless works fine on your router, then it is possible that there is a problem either on your ethernet cable or on the port of the belkin router.
Try a different ethernet cable. (Ethernet cable is the one that is connected from your computer to the router.) If you don't have a spare cable, you can directly connect the computer to the modem, just to isolate the issue and determine if it is the cable or the computer itself.
If you have determined that the cable is working fine, then try a different port on the router.
I hope this helps!
Jul 24, 2010 | Belkin F5D7234-4 Router
I have my D-Link DIR-616 C1 connected t my desktop computer. I have AT&T high speed internet and it is connected through the router. Everything works fine with the desktop. My problem is with my...
you will need to add the wireless network manually.
First you will need to remove the network from the prefered network list. I believe the Operating system on the computer is XP. and the security on the wireless network is WEP. make sure that you are typing the correct network key.
Click here for more information about routers and network
Feb 11, 2010 | D-Link DIR-615 Wireless Router
Laptop keeps losing wireless connection
make sure the wep key you apply it is correct.just reconfgure the wireless connection.
Dec 31, 2009 | Dell Inspiron 6000 Notebook
Cannot connect to the router
Right click the network icon in the system tray. Click "repair."
If that doesn't work.Power off netbook, router, modem...
Turn on router. Then Modem. Then netbook in that order waiting 1 minute interval between each.
Everything should be functioning ok.
Dec 21, 2009 | Linksys WRT54G2 Wireless Router
I have my DIR-655 hooked up and has been working for months and now within the last couple of months I keep dropping connection about every 10 to 15 minutes all day long. Some days it works so-so and the...
try to upgrade the firmware of the router.
That may help you.
For that you will need to download the firmware from the manufacturer's web site.
Access the router set up.
Click Here for step by step solution
Nov 02, 2009 | D-Link Xtreme N DIR-655 Wireless Router
DSL connection keeps dropping off. Going to RED
well!! I have an answer for you.your comp is loosing the IP address.do this when you can go online. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center,click on view status,goto propertiesand double click on internet protocol(tcp/ip) or IPv4.type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. ypur connection won`t drop after this.
Jul 10, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
2Wire 1800HG keeps losing connection
However as you said Desktop works fine and this seems to be issue with Wireless Netwrok card of your Laptop try to upgrade drivers of the Wireless netword card opf your laptop and this may possibly resolve the problem..
Apr 08, 2009 | 2wire 1800HG Router (RG1800HG00)
Dropped Wireless connection on Aspire One 8.9" Netbook
make sure your isp is suppling your 2nd ip address...
Dec 25, 2008 | Acer Aspire One Netbook 8.9" Notebook
Samsung N150 Netbook Logo
90 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
