Question about Honda 3000 Watt Portable Generator
How do i replace the starter rope on my 3000 - Honda 3000 Watt Portable Generator
    President:
  • 2,976 Answers
Remove the rope housing, wrap the new rope on by hand, replace the housing.
Posted on Jan 16, 2013
How to fix recoil starter?
It appears that the recoil spring is broken or has come away from its anchor position. It means opening the unit (usually 4 screws) and re-seating the recoil spring and rewinding the recoil spring so that it will recoil the starter rope with the correct tension. It may take a few attempts to get it right. If you do get it right, don't over-extend the starter rope when starting the washer. Someone was over-zealous!
May 11, 2014 | Troy-Bilt XP 3000 PSI 2.7 GPM Gas Pressure...
Starter rope replacement
recoil spring has slipped out of the hole.pull your starter rope out of the wind up mechanism, insert the spring latch on both ends and put back into housing. with a piece of 3/4 square stock or something the will fit mthe hole start to wind the mechanism spring up tight. with apair vishgrips lock it down so it does not move. insert your starter rope anr release the visegrips. the springwii recoil and pull the rope in.cut off excess rope. good luck
Oct 17, 2012 | Little Wonder 6032 10 Inch Pro Lawn Edger,...
Starter cord
remove top starter assy. cut grip from old rope ease rope into spool,
when slack remove center screw and carefully pull out spool, tie knot in rope and thread into spool, wind rope [make sure correct size rope]
around spool until full,carefully turn spool into spring 1 turn then replace screw. put rope into notch on spool and wind up 3-6 turns,
replace grip
May 19, 2012 | Mantis 2-Cycle Tiller
Pull cord will not rewind
  • 1
    Turn the Homelite chainsaw so that the bar and chain are laying flat and the starter cover is facing up. Loosen the four starter cover screws by unscrewing them counterclockwise with the screwdriver.
  • 2
    Take the starter cover off of the engine. Turn the starter cover over to work on the pull starter. Pull the rope out about 6 to 8 inches.
  • 3
    Twist a loop into the end of the rope. Insert the intersection of the two ropes into the notch on the upper flange of the pulley. Rotate the loop back and forth until you notice the recoil spring has disengaged. Unwind the rope from the pulley. Cut off any old rope if you need to replace it with a new rope.
  • 4
    Unscrew the screw holding the pulley to the starter cover using the screwdriver. Take the pulley off the starter cover. Turn the pulley over and remove the recoil spring cassette from inside the pulley.
  • 5
    Inspect the spring inside the cassette to see if it is damaged or overstretched. Replace the recoil spring cassette if it is broken. Lubricate the post on the starter cover using about a dime-sized amount of engine grease.
  • 6
    Put the recoil spring cassette back into the pulley. Set the pulley onto the starter cover and tighten the screw down with the screwdriver. Wind the starter rope back around the pulley in a clockwise direction.
  • 7
    Leave about 6 to 8 inches of rope unwound. Form another loop at the end and insert the loop into the notch on the pulley. Rotate the loop back and forth until you notice the tension is set on the recoil spring.
  • 8
    Remove the loop and place the starter cover back over the engine. Pull the rope out 6 inches and tighten the starter cover's screws using the screwdriver. Release the rope and it should automatically retract
  • hope this helps
    John
    Sep 09, 2011 | Homelite Garden
    Rope broke
    Starter rope is sold at home centers like Lowes and Homedepot. It is important to buy the same thickness of rope so that an ample amount will fit into rewind spool(starter rope is sold by size from 3.5 to 6.5) . Remove the starter cover /fan cover if the starter is riveted to fan cover (or just remove the pull rewind if bolted on). With cover removed, notice how the rope enters thru bushing and ties onto spool. Visualize in which direction the spool turns when you pull the rope. This is the direction that you will be winding the spool. Fish out the old rope and wind the spool in the direction mentioned above. The spool will get tighter as you wind. When the spool will not wind another turn, back-off one turn and align hole in spool to bushing on cover. Insert rope thru bushing into hole and tie knot (any knot that will not obstruct motor parts). At this point allow the rewind to take-in the rope to stop at handle. Test your work. The rope will break if you try to start the washer under load. Press trigger on wand to release pressure. Also the rope is stressed when the operator has a very long strong arm and pulls out the rope to bottom out at the knot. Good luck with your repair
    Aug 04, 2011 | Briggs & Stratton 3000 PSI Pressure Washer
    Need to relace starter rope
    Remove the cover from the side of the blower that contains the pull start. This usually involves removing the self-tapping screws that join the two halves of the blower housing together.
  • 2
  • Remove the broken rope from the starter pulley. Usually the rope is attached to the pulley with a simple overhand knot; just grab the knot and pull the rope back through the hole in the pulley. Sometimes the rope is attached to the pulley with a staple or some other fastener, which you'll have to remove first.
  • 3 Remove the handle from the replacement rope, if it's already attached.
  • 4 Thread the end of the rope opposite the handle through the hole in the starter pulley, working from the inside of the pulley (the side facing in toward the engine).
  • 5 Fasten the rope to the pulley. If it attaches with a knot, simply tie an overhand knot, pull it tight and trim off any excess rope sticking out of the knot. If it attaches with a fastener, replace the fastener.
  • 6 Wrap the rope counterclockwise around the pulley until the pulley is full; this usually involves one or two wraps.
  • 7 Thread the free end of the rope through the hole in the blower housing.
  • 8 Replace the blower housing and screw it in place.
  • 9 Trim off excess rope, leaving about 6 inches of rope protruding from the blower housing.
  • 10 Attach the handle to the starter rope. This typically involves threading the rope through one or two holes in the handle and securing with an overhand knot.
  • Read more: How Do I Replace a Pull String on a Hand Held Blower? ' eHow.com http://www.ehow.com/how_6920861_do-string-hand-held-blower_.html#ixzz1DKqEmA1w
    Feb 07, 2011 | Homelite Garden
    I have a honda generator but i change the cordon starter and now i dont now how ensable it, i need a diagrama of this
    What you need to do is first remove the new cord that you installed.
    (This next process is best performed by 2 people)
    Pre-wind the spool gently COUNTER CLOCKWISE until the spring prevents further winding. Have the 2nd person grip the spool so that it does ot unwind. Back off the spool until the re-wind rope hole is aligned with the outer cover rope guide. Insert the new rope through the outer cover rope guide hole and into the spool hole. Pull the new rope through the spool hole and tie a single small knot. Pull the knot into the hole. 2nd person releases the spool and the rope will rewind into the re-coil assy.
    Aug 04, 2010 | Honda 3000 Watt Portable Generator
    The starter rope on my 14PZ push mower broke. How
    The starter rope on my Masport push mower broke. How do I replace the rope and/or starter?
    Sep 27, 2009 | Garden
    Starter cord will not rewind after being replaced. The string will rewind in the housing before it is attached to the motor but not after being attached. How do you pre wind the springs?
    What I do is the following:
    Remove the old rope ( what is left of it)
    Wind the starter rope pulley about 8 or 9 complete revolutions after I am confident that the spring has engaged the starter pulley
    Hold the pulley in place ( align the rope hole in the pulley with hole in the starter housing
    Insert the rope and tie a knot, pull the rope back tight against the pulley
    Pull the rope all the way out and hold slight tension on the rope and release the tension on the pulley but still holding the starter housing
    Starter spring should pull rope into housing... good luck
    Sep 08, 2009 | Garden
    Honda 3000 Watt  Portable Generator Logo
    53 people viewed this question
    Top Honda Electrical Supplies Experts
    John Trevino
    Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
