Question about TDK Sound cube audio system iPod/iPhone music while c
How do I Adjust the alarm volume control on tdk icubic clock radio?
  • Stuart Jan 19, 2013
    When my clock radio comes on in the morning it quickly increases to full volume. I only want it to be a lower volume at about half way.. Is there any way of pre-setting this on the iCube?
ZX clock radio: How dor i control the volume of the alarm ? How do i swtich from buzzer to radio for wake up?
I have owned several radio alarm clocks and I have found them all fairly intuitive to operate - no instructions needed, though sometimes it takes a short time of playing around to fill in the operating details.
The alarm buzzer is generated by the audio part of the radio and so those clock radios that do have a buzzer with adjustable volume it is controlled by the radio volume control. In this case it is usually the case that falling asleep to the radio with the volume turned down results in not being woken next morning because the alarm isn't loud enough.
Switching from radio alarm to buzzer is usually intuitive but in the absence of instructions there will be a limited number of switch combinations to play around with.
Nov 07, 2017 | The Audio Players & Recorders
How does one change the radio volumn for the alarm on a Onn model ONB14AV201? When the alarm comes on it's very loud. When i play the radio i can change the volumn but i can't find a sequence that sets the...
ONB14AV201 alarm clock with gradual wake alarm function. Radio alarm sound level will start from 0-15 within 12 to 15 second when alarm on. You can adjust the radio alarm volume by press the "ALM2/VOL-" or "ALM2/VOL+" buttons. The manual not mention the radio alarm sound level can be preset.
Feb 26, 2015 | Audio Players & Recorders
How can i change the alarm volumn on the radio on onn ONB14AV201
ONB14AV201 alarm clock with gradual wake alarm function. Radio alarm sound level will start from 0-15 within 12 to 15 second when alarm on. You can adjust the radio alarm volume by press the "ALM2/VOL?" or "ALM2/VOL+" buttons.
Feb 25, 2015 | Audio Players & Recorders
I have model ONA13AV501. And I cannot adjust the volume on the alarm..I can not find the directions in the guide - pg 10. please instruct
The alarm volume is rarely adjustable but if it has the option of using the radio for wake-up instead, you can set this as you wish.
Feb 03, 2015 | Audio Players & Recorders
I need a manual for the TDK dual alarm clock radio model Ta4211BK
I cannot find the manual online. But if you will go to the TDK Facebook page some one ther got a copy from them. Go there an see if you can get a response. They did it once I dont see why not again.
Jan 28, 2015 | Audio Players & Recorders
How do I change radio volume on the alarm?
This clock is supposed to have an automatically "increasing" volume feature (starts off low, gets louder over a minute or so).
If not sufficient, look on the top right side of the clock, there should be an up/down volume control. It is a black oval-shaped button with a picture of a sound speaker in the middle. Push it upward to increase volume and downward to decrease volume. Unfortunately, you have to have a flashlight or light on to see it because none of the controls are illuminated.
Dec 02, 2013 | Sharper Image Sound Soother White Noise...
How do I set the clock on my LG LPC1000 Music player & set an alarm
setting the clock: 1. Press the DISP and by press and hold for more then 1 second. 2. Press the >>' to adjust the hour. 3. Press the '<< to adjust the minute.
checking the clock: You can see the clock pressing the DISP (DISP. on the remote control).
Adjusting the beep sound 1 Press the SEL for more then 2 seconds "BEEP ALL" or "BEEP 2ND" appear 2. Press the VOL+/- (Press the VOLUME A V on the remote control) to select beep sound. BEEP ALL: When any button is pressed, beep sound. BEEP 2ND: When a key is long pressed (1sec), beep sound.
Answer taken from LG documentation
As for the alarm. I found no documentation that you can set an alarm on your car radio.
Jun 17, 2011 | LG LAC-M3600R CD Player
I can't get the alarm to go off as the radio.
To turn off, hold down the mode button until the alarm/radio symbols disappear. To turn off nap, hold down nap button. Is the alarm volume controlled by the radio volume?
Oct 29, 2008 | RCA RP3711 Clock Radio
TDK icubic controls not controlling ipod
my icubic is stuck on a radio station which says mw then the station then khz
i dont no how to change it back to i can listen to fm radio. can u plzz help me!!
Jun 01, 2008 | Audio Players & Recorders
Alarm Volume
THE ALARM BEEP IS SET TO ONE VOLUME MODE ONLY THE RADIO VOLUME IS THE ONLY ONE YOU CAN CONTROL UNLESS YOU HAVE A HIGH AND LOW SWITCH THEN JUST SWITCH TO LOW.
Jan 23, 2007 | GE 7-4897 Clock Radio
TDK Sound cube audio system iPod/iPhone music while c Logo
60 people viewed this question
Top TDK Audio Players & Recorders Experts
Josh Whitehead
Josh Whitehead
Are you a TDK Audio Player and Recorder Expert? Answer questions, earn points and help others
