Question about Envision EN-5400 15" LCD Monitor
What is envision en5400 monitor power supply output voltage and amp
2 Suggested Answers
  • 814 Answers
SOURCE: My Envision 7100 Stop Working
These are all some component failure problem in the monitor circuits. This may have been caused by faulty components or overheating of the components causing intermittent or permanent failure of some components in the circuits.This causes the feedback circuits to sense incorrect voltages or currents in the circuits and turn on the protection circuit. It may also cause total failure of the power supply circuit and a loss of power to the monitor. These units should be returned to dealers for servicing. Hope this helps you .
Posted on Apr 14, 2009
How can i find a power cord to fit this monitor? The one I have is not getting power to it . It was tested by Best buy.
Most monitors have the same type power cord. You can order them cheap off of Amazon and eBay.
Heres on that should work: http://www.amazon.com/Cables-Go-03134-Universal-IEC320C13/dp/B00005113L/ref=sr_1_1?ie=UTF8&qid=1298845316&sr=8-1
Feb 27, 2011 | Envision EN 9110 19" Flat Panel LCD...
My monitor is unresponsive. Does not power on anymore. Does anyone have any troubleshooting ideas?
If your monitor uses a power supply (the brick that plugs into the wall, and then a smaller cord plugs into the monitor), then it's more likely the power supply that's gone out than the monitor itself.
Find someone with a multimeter to check the output voltage on the power supply. There will be a label on the power supply that says what the DC voltage (VDC) is supposed to be. If the meter shows no voltage when the power supply is plugged into the wall, then you just need a new power supply.
Do not try using another power supply as a substitute unless it is a specific match to your monitor. They vary widely by output voltage, etc. and using the wrong one could fry your monitor.
Hope that's helpful.
Jan 14, 2011 | Dell E207WFP LCD Monitor
LCD EN 7500 THIS HAVE SONG AND NOT IMAGE
Need to check the caps in power supply, fuse and transistor/IC/transformers in the inverter circuits, it can also be bad lamps assemblies.
See example of failed 7410 due to bad caps. Post back for furhter help.
http://s807.photobucket.com/albums/yy352/budm/Envision%20EN7410E/
Service manual: http://elektrotanya.com/?q=showresult&megnev=Envision%20&megnev2=%20EN%207500%20&kategoria=&kat2=all
Apr 27, 2010 | MPC Computers Envision EN 7500 17" Flat...
Blink s blue light envision g218a
The blinking blue light indicates your power supply has blown out. The heat buildup in the case has caused parts called capacitors to blow and short the power supply causing the blinking. We offer a repair service for $30 plus return shipping. If you wan to do the repair yourself you will need to open the back of the monitor and look for the bulging capacitors. To see what the bad capacitors look like go to our site at: www.ccl-la.com Replace any bulging caps that you see and you should be back going. You will need to use high temp capacitors marked 105c. If you have any questions about the repair or repair service just let us know at the address below.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Dec 07, 2009 | Envision G218A1 22 inch Monitors
Jan 09, 2009 | Envision EN-7100e 17" Flat Panel LCD...
Got flat screen as a gift
This monitor requires a power supply with a POSITIVE tip polarity.
Monitor requires 12 Volt DC @ 3.3 Amps output.
Make sure voltage is 12 Volts DC [absolute requirement]
Power Supply can have greater than 3.3 Amp capacity. More amp capacity increases price, so I wouldn't go for more than 5 Amps [minimum 3300 milliAmps, 5000 milliAmps will be more than adequate].
Put a surge protector on your computer and monitor to extend their life....better yet, a power conditioning battery backup system, that can supply constant voltage, to compensate line voltage when A/C, furnace, or other major appliance kicks on.
May 04, 2008 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
Envision EN7410e monitor
Just fixed mine. Maybe it's a few years late. Hope you guys still have the display. It's the power supply board. I've just replaced 4 bulge capacitors near one edge of the PS. They are 2x1000uF 10V, 1x470uF 25V & 1x470 10V. I salvaged my parts from an old CRT monitor. Hey you can go green with your repairs too!
Apr 25, 2008 | Envision EN7410 17" LCD Monitor
Envision EN-5400 15" LCD Monitor Logo
44 people viewed this question
Top Envision Computers & Internet Experts
Cleverer2
castletech
castletech
Jim Goldsmith
Jim Goldsmith
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
